  <title>R-pod Owners Forum : Camber</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Camber</description>
  <pubDate>Thu, 29 Oct 2026 17:44:18 +0000</pubDate>
  <lastBuildDate>Sat, 01 Aug 2020 17:32:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13856</WebWizForums:feedURL>
   <title>Camber : Same here, you got two posts going....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13856&amp;PID=134760#134760</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13856<br /><strong>Posted:</strong> 01 Aug 2020 at 5:32pm<br /><br />Same here, you got two posts going.]]>
   <pubDate>Sat, 01 Aug 2020 17:32:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13856&amp;PID=134760#134760</guid>
   <title>Camber : See my response in another thread....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13856&amp;PID=134748#134748</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13856<br /><strong>Posted:</strong> 01 Aug 2020 at 3:14pm<br /><br />See my response in another thread.]]>
   <pubDate>Sat, 01 Aug 2020 15:14:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13856&amp;PID=134748#134748</guid>
   <title>Camber : Is it me or does the driver-side...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13856&amp;PID=134746#134746</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10323" rel="nofollow">alandlearned</a><br /><strong>Subject:</strong> 13856<br /><strong>Posted:</strong> 01 Aug 2020 at 3:09pm<br /><br />Is it me or does the driver-side wheel/tire have a natural negative camber on an R-Pod 178? It even looks like it has a toe-out issue as well. The passenger side appears to be fine. If this is indeed an issue can/should it be repaired?<div><br></div><div>Al and Val&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley5.gif" border="0" alt="C&#111;nfused" title="C&#111;nfused" /><img src="https://www.rpod-owners.com/smileys/smiley5.gif" border="0" alt="C&#111;nfused" title="C&#111;nfused" />&nbsp;</div>]]>
   <pubDate>Sat, 01 Aug 2020 15:09:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13856&amp;PID=134746#134746</guid>
