  <title>R-pod Owners Forum : Charging battery while at home?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Charging battery while at home?</description>
  <pubDate>Sat, 24 Oct 2026 20:59:11 +0000</pubDate>
  <lastBuildDate>Tue, 28 Jul 2020 16:36:37 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13834</WebWizForums:feedURL>
   <title>Charging battery while at home? : Thousand Gomens members, I never...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134554#134554</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 28 Jul 2020 at 4:36pm<br /><br />Thousand Gomens members, I never add acid to an old battery that has not been drained.  Only distilled water and actually use the dehumidifier water like Jato.]]>
   <pubDate>Tue, 28 Jul 2020 16:36:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134554#134554</guid>
   <title>Charging battery while at home? :   Originally posted by offgrid+1...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134538#134538</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10471" rel="nofollow">Phil from Maine</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 28 Jul 2020 at 12:18pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />+1 to Jato. Placing batteries on concrete is fine.&nbsp;</td></tr></table> <br></div><div><br></div><div>I stand corrected. Doing my due diligence,&nbsp; I read articles from respected sources that confirm Jato's post content.<br><span style="color: rgb62, 56, 52; font-family: Georgia, serif; font-size: 19.6px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: left; text-indent: 0px; text-trans: n&#111;ne; white-space: normal; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; : rgb255, 255, 255; text-decorati&#111;n-style: initial; text-decorati&#111;n-color: initial; display: inline !imant; : n&#111;ne;"></span></div>]]>
   <pubDate>Tue, 28 Jul 2020 12:18:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134538#134538</guid>
   <title>Charging battery while at home? : +1 to Jato. Placing batteries...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134525#134525</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 28 Jul 2020 at 10:40am<br /><br />+1 to Jato. Placing batteries on concrete is fine.&nbsp;]]>
   <pubDate>Tue, 28 Jul 2020 10:40:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134525#134525</guid>
   <title>Charging battery while at home? :   That is what I have always...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134520#134520</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 28 Jul 2020 at 9:16am<br /><br />&#091;QUOTE=Phil from Maine&#093;<div><br></div><div>That is what I have always done with my motorcycle and boat batteries and I believe that that procedure is the industry recommended procedure.&nbsp; I do however monitor the batteries as&nbsp; the Winter progresses and have been taught by others never to leave batteries on unheated concrete.</div><div>EDIT: on ground slabs whether heated or not.<br></div><div><br></div><div>There was a time when battery cases were made out of a special wood however with the advent of plastic battery case construction drastically changed sometime in the 1940's I believe.&nbsp; With wood cases, yes, you would not want to place on a concrete surface as it would discharge the battery.&nbsp; However with plastic that is no longer the case - pardon the play on words here.&nbsp; If it were a problem, my 9+ year old batteries would no longer be useful or work as well as they do.<br></div>]]>
   <pubDate>Tue, 28 Jul 2020 09:16:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134520#134520</guid>
   <title>Charging battery while at home? : StephanH is right., Don&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134499#134499</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 28 Jul 2020 at 6:09am<br /><br />StephanH is right., Don't add sulphuric acid, unless the battery was tipped over. The H2SO4 in the battery is not depleted by gassing. Only water. Adding acid will raise the specific gravity in the battery over time, which increases plate corrosion and stress during cycling. There are no battery manufacturers I have ever worked with who recommend changing the electrolyte concentration after initial filling and charging.&nbsp;]]>
   <pubDate>Tue, 28 Jul 2020 06:09:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134499#134499</guid>
   <title>Charging battery while at home? :    Originally posted by jato Our...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134497#134497</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10471" rel="nofollow">Phil from Maine</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 28 Jul 2020 at 5:43am<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by jato</strong></em><br /><br />Our flooded cell batteries are 12v Interstate group size 24, deep cycle marines.&nbsp; Since we took ownership of our 177 back in March 2011 I simply take off the ground cable when not using, doesn't take very long to do.&nbsp; Interesting mcarter to add acid with the distilled water, never heard of that.&nbsp; Just adding distilled water (from our dehumidifier) for the past 9+ years has worked well for us.&nbsp; And when we get to winter&nbsp; (northern Michigan) both batteries are removed in November and set on the concrete floor in our unheated garage.&nbsp; They each receive a 2 amp trickle charge for 24-36 hours and then 'hibernate' all winter until the following mid-late April where the process is repeated and then re-installed around May 1.&nbsp; Batteries are kept clean by washing with baking soda 2x/year. Also key is keeping an eye on the water level.</td></tr></table> <br></div><div><br></div><div>That is what I have always done with my motorcycle and boat batteries and I believe that that procedure is the industry recommended procedure.&nbsp; I do however monitor the batteries as&nbsp; the Winter progresses and have been taught by others never to leave batteries on unheated concrete.</div><div>EDIT: on ground slabs whether heated or not.<br></div><div><br></div><div><br></div>]]>
   <pubDate>Tue, 28 Jul 2020 05:43:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134497#134497</guid>
   <title>Charging battery while at home? :  Our flooded cell batteries are...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134493#134493</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 27 Jul 2020 at 8:45pm<br /><br />Our flooded cell batteries are 12v Interstate group size 24, deep cycle marines.&nbsp; Since we took ownership of our 177 back in March 2011 I simply take off the ground cable when not using, doesn't take very long to do.&nbsp; Interesting mcarter to add acid with the distilled water, never heard of that.&nbsp; Just adding distilled water (from our dehumidifier) for the past 9+ years has worked well for us.&nbsp; And when we get to winter&nbsp; (northern Michigan) both batteries are removed in November and set on the concrete floor in our unheated garage.&nbsp; They each receive a 2 amp trickle charge for 24-36 hours and then 'hibernate' all winter until the following mid-late April where the process is repeated and then re-installed around May 1.&nbsp; Batteries are kept clean by washing with baking soda 2x/year. Also key is keeping an eye on the water level.]]>
   <pubDate>Mon, 27 Jul 2020 20:45:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134493#134493</guid>
   <title>Charging battery while at home? :  Why a mix? Why not just distilled...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134492#134492</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 27 Jul 2020 at 7:12pm<br /><br />Why a mix? Why not just distilled water to make up for that which was dissociated into H2 and O2? Yes, I know water&nbsp; is H2O, but oxygen normally bonds with another oxygen atom when not bonded to anything else so 2 water molecules dissociate into 2 pair of H2 and&nbsp; one O2. The sulfuric acid does not get consumed, so you are changing the balance if you add acid and water at each filling. You are also likely cutting the capacity of the battery if you add acid along with the water.<br>]]>
   <pubDate>Mon, 27 Jul 2020 19:12:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134492#134492</guid>
   <title>Charging battery while at home? : +1 to Olddawgs.  I have the same...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134489#134489</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 27 Jul 2020 at 4:32pm<br /><br />+1 to Olddawgs.  I have the same battery my Pod came with in 2015.  The convertor stays live, I go in every few days and turn on the 12V stuff, watch the convertor go to 13.6, every month I check the water level.  Might even shut the convertor down and let battery discharge randomly.  I top it off with a battery mix of water and acid.  Works for me so far.]]>
   <pubDate>Mon, 27 Jul 2020 16:32:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134489#134489</guid>
   <title>Charging battery while at home? : I come from a belief the battery...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134485#134485</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7667" rel="nofollow">Olddawgsrule</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 27 Jul 2020 at 3:40pm<br /><br />I come from a belief the battery needs to be used. Just running &nbsp;trickle charger is your choice. If you pay attention to your battery it will last fa beyond what is normally expected. I do (well did, now LiFePo4) allow the battery to draw, then charge it. Keeping that Draw low and the recharge low balances off the chemical reaction happening nd the plates pretty darn clean..&nbsp;<div><br></div><div>I say yes do charge at home, but understand the draw/charge cycle and how to balance it.&nbsp;</div><div><br></div><div>I say this as MHO and not knowing your particular situation.. Batteries love attention and the more you give them, the longer they last.</div>]]>
   <pubDate>Mon, 27 Jul 2020 15:40:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134485#134485</guid>
   <title>Charging battery while at home? : On my 2011 R-Pod 172 there is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134480#134480</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10471" rel="nofollow">Phil from Maine</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 27 Jul 2020 at 1:33pm<br /><br />On my 2011 R-Pod 172 there is substantial parasitic battery Drain.&nbsp; I installed a battery cutoff switch on the battery case to prevent drain.&nbsp; When possible I keep the pod plugged into shore power, but when not plugged in, I use the battery cutoff switch.<div><br></div><div><h1 id="secti&#111;n_0" ="title_md" style="-webkit-tap-highlight-color: transparent; margin-right: 0px; margin-left: 0px; padding: 0px 26px; border-top: 0px; border-right: 0px; border-bottom: n&#111;ne; border-left: 0px; border-: initial; font-variant-numeric: inherit; font-variant-east-asian: inherit; font-stretch: inherit; line-height: normal; font-family: Helvetica, &quot;Nimbus Sans L&quot;, Arial, &quot;Liberati&#111;n Sans&quot;, sans-serif; font-size: 35px; vertical-align: line; : n&#111;ne; color: rgb34, 34, 34;"><br></h1></div>]]>
   <pubDate>Mon, 27 Jul 2020 13:33:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134480#134480</guid>
   <title>Charging battery while at home? :  Except for the last few weeks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134461#134461</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 26 Jul 2020 at 6:46pm<br /><br /><div>Except for the last few weeks while I've been trying out some solar alternatives, my Pod has been plugged in 24/7 since 2014. My WFCO bit the dust two years ago and I replaced it with:</div><div><br></div><div><a href="https://www.progressivedyn.com/rv/power-c&#111;nverters/inteli-power-4600-series/" target="_blank">https://www.progressivedyn.com/rv/power-converters/inteli-power-4600-series/</a></div><div><br></div><div>I run dual Duracell:</div><div><br></div><div><a href="https://www.samsclub.com/p/duracell-golf-car-battery-group-size-egc2/prod3590220" target="_blank">https://www.samsclub.com/p/duracell-golf-car-battery-group-size-egc2/prod3590220</a></div><div><br></div><div>I replaced batteries last year. They were on sale for like $100.00/battery. I figured 5 years for $200.00 was a good deal.</div><div><br></div><div>So I would say...keep it plugged in and let the charger do what it does.</div><div><br></div><div><br></div>]]>
   <pubDate>Sun, 26 Jul 2020 18:46:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134461#134461</guid>
   <title>Charging battery while at home? : For a couple years I ran my Pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134448#134448</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 26 Jul 2020 at 3:36pm<br /><br />For a couple years I ran my Pod off a 120 outlet, then had a 30A RV box set up where I park Pod.  I plug in like on a campground, Pod has become a man cave and guest house.  Visitors love it. I set rules:)]]>
   <pubDate>Sun, 26 Jul 2020 15:36:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134448#134448</guid>
   <title>Charging battery while at home? : +1. If you&amp;#039;re plugged in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134440#134440</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 26 Jul 2020 at 2:26pm<br /><br />+1. If you're plugged in at home just leave it like that and check the battery water level periodically. No need to disconnect until you want to go somewhere. That also gives you the option to keep a dehumidifier going inside if you live in a humid place and/or a small electric heater to keep things from getting really cold.&nbsp;]]>
   <pubDate>Sun, 26 Jul 2020 14:26:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134440#134440</guid>
   <title>Charging battery while at home? : Plugged into the house is great...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134437#134437</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 26 Jul 2020 at 2:16pm<br /><br /><div>Plugged into the house is great for keeping the battery charged. Periodically check the electrolyte level if you have a flooded cell battery (not needed if sealed). If you want to disconnect it, there are two ways:</div><div>1. Remove the negative battery cable when not plugged in or in use.<br></div><div>2. Install a battery cut-off switch that you can turn off when not plugged in or in use.</div><div><br></div><div>Either one will help keep the battery from being discharged by the constant draw from things like the LP/CO detector. <br></div>]]>
   <pubDate>Sun, 26 Jul 2020 14:16:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134437#134437</guid>
   <title>Charging battery while at home? : Hi folks, I&amp;#039;m new to RV&amp;#039;ing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134436#134436</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10525" rel="nofollow">Poddy</a><br /><strong>Subject:</strong> 13834<br /><strong>Posted:</strong> 26 Jul 2020 at 2:08pm<br /><br />Hi folks, I'm new to RV'ing and I'm wondering what others do with their battery while at home. Right now i'm plugged into the house and my next trip is not until next weekend. Is it necessary to have the Pod plugged in all the time or just a few days before an upcoming trip? Or maybe just a few hours every day?]]>
   <pubDate>Sun, 26 Jul 2020 14:08:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13834&amp;PID=134436#134436</guid>
