  <title>R-pod Owners Forum : Fridge won&#039;t run on gas</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Fridge won&#039;t run on gas</description>
  <pubDate>Wed, 23 Sep 2026 22:01:12 +0000</pubDate>
  <lastBuildDate>Fri, 04 Sep 2020 12:40:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13610</WebWizForums:feedURL>
   <title>Fridge won&#039;t run on gas : Hey Kanikk,Just curious, what...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=135991#135991</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9509" rel="nofollow">ReluctantTraveler</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 04 Sep 2020 at 12:40pm<br /><br /><div>Hey Kanikk,</div><div><br></div><div>Just curious, what was the outcome of the fridge going out using propane? Did the dealer find anything wrong, or did it just keep working on its own?<br></div>]]>
   <pubDate>Fri, 04 Sep 2020 12:40:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=135991#135991</guid>
   <title>Fridge won&#039;t run on gas : Took everything apart. Blew it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131903#131903</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10273" rel="nofollow">Kanikk</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 8:42pm<br /><br />Took everything apart.&nbsp; Blew it clean.&nbsp; Seems to work now.&nbsp; Thank you everyone for the information and suggestions.&nbsp; I appreciate your responses.&nbsp; Call RV dealership yesterday and they said they had an opening July 8th.&nbsp; Very happy not have to wait that long!<br>]]>
   <pubDate>Tue, 02 Jun 2020 20:42:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131903#131903</guid>
   <title>Fridge won&#039;t run on gas : Well my thought is that makes...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131891#131891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 4:44pm<br /><br />Well my thought is that makes it hard to keep the beer cold.<div><br></div>]]>
   <pubDate>Tue, 02 Jun 2020 16:44:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131891#131891</guid>
   <title>Fridge won&#039;t run on gas : Dismantle, clean and put back...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131887#131887</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1045" rel="nofollow">marwayne</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 3:53pm<br /><br /><div>Dismantle, clean and put back together.</div><div><br></div><div><a href="https://postimages.org/" target="_blank"><img src="https://i.postimg.cc/6Q5Vcj9z/115-1558-Copy-LI.jpg" border="0" /></a>&nbsp;</div>]]>
   <pubDate>Tue, 02 Jun 2020 15:53:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131887#131887</guid>
   <title>Fridge won&#039;t run on gas : Curious as to the ambient temp...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131885#131885</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5324" rel="nofollow">PilotPodder</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 3:50pm<br /><br />Curious as to the ambient temp in the area behind the fridge (pull vent panel and stick a thermometer in there). There is a small possibility that if it is very hot in the compartment (it is close to 90 where I am now, and if that compartment is facing the sun, it could be very hot in there), that the sensor to keep gas flowing is thinking the heat exchanger is too hot and stopping the flow. Long-shot, but may be worth looking into.&nbsp;<div><br></div><div>Here is a link to an HVAC person explaining why a furnace won't stay lit: <a href="https://georgebrazilhvac.com/blog/why-w&#111;nt-my-gas-furnace-stay-lit" target="_blank">https://georgebrazilhvac.com/blog/why-wont-my-gas-furnace-stay-lit</a></div>]]>
   <pubDate>Tue, 02 Jun 2020 15:50:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131885#131885</guid>
   <title>Fridge won&#039;t run on gas : Yeah, I&amp;#039;ve tried to blow...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131883#131883</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10273" rel="nofollow">Kanikk</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 3:23pm<br /><br />Yeah, I've tried to blow everything out.&nbsp; Fridge works on 12V and Electric.&nbsp; The igniter clicks and I can see the flame and then it goes out...it just won't stay lit.]]>
   <pubDate>Tue, 02 Jun 2020 15:23:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131883#131883</guid>
   <title>Fridge won&#039;t run on gas : Its the fridge not the water heater...Dometic...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131881#131881</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 3:14pm<br /><br />Its the fridge not the water heater...Dometic stuff is $$$$]]>
   <pubDate>Tue, 02 Jun 2020 15:14:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131881#131881</guid>
   <title>Fridge won&#039;t run on gas :  If you go in back and open the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131880#131880</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 3:00pm<br /><br />If you go in back and open the panel, you should hear clicking. The h/w tank will make 3 attempts to light. With out getting to close (it's goes whoooosh if it lights) see if you smell propane. If you smell propane, it's probably an igniter problem. Might need a new igniter board. igniter board is less than 100 dollars on amazon&nbsp;<div><br></div>]]>
   <pubDate>Tue, 02 Jun 2020 15:00:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131880#131880</guid>
   <title>Fridge won&#039;t run on gas :  Next thing I&amp;#039;d try is vacuuming...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131879#131879</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 2:50pm<br /><br />Next thing I'd try is vacuuming out the flue and gas orofice area. Diisconnect 12V from the fridge for awhile to reset and try again. If that doesn't work then you might try this manual.&nbsp;<div><br></div><div><a href="http://bryantrv.com/docs2/docs/Service%20Manual,%20RM8xxx.pdf" target="_blank">http://bryantrv.com/docs2/docs/Service%20Manual,%20RM8xxx.pdf</a><br></div><div><br></div><div>Hope its not the control boards, those are outrageously expensive.&nbsp;</div><div><br></div><div>It does work on 120Vac and 12Vdc, right?&nbsp;</div>]]>
   <pubDate>Tue, 02 Jun 2020 14:50:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131879#131879</guid>
   <title>Fridge won&#039;t run on gas : Yes, line is purged. Ran stove...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131878#131878</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10273" rel="nofollow">Kanikk</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 2:32pm<br /><br />Yes, line is purged.&nbsp; Ran stove and gas is flowing.]]>
   <pubDate>Tue, 02 Jun 2020 14:32:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131878#131878</guid>
   <title>Fridge won&#039;t run on gas : Did you purge the line of air?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131877#131877</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 1:56pm<br /><br />Did you purge the line of air? Best thing is to turn on the stove and get it running steady, then shut it off and try the fridge again.&nbsp;]]>
   <pubDate>Tue, 02 Jun 2020 13:56:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131877#131877</guid>
   <title>Fridge won&#039;t run on gas : New RPOD owner. Fridge ignites...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131876#131876</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10273" rel="nofollow">Kanikk</a><br /><strong>Subject:</strong> 13610<br /><strong>Posted:</strong> 02 Jun 2020 at 1:06pm<br /><br /><div>New RPOD owner.&nbsp; Fridge ignites but will not stay lit.&nbsp; Thoughts?</div><div>Thanks in advance,<br></div>]]>
   <pubDate>Tue, 02 Jun 2020 13:06:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13610&amp;PID=131876#131876</guid>
