  <title>R-pod Owners Forum : Spare Tire Bracket</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Spare Tire Bracket</description>
  <pubDate>Wed, 23 Sep 2026 23:12:22 +0000</pubDate>
  <lastBuildDate>Wed, 27 May 2020 22:48:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13588</WebWizForums:feedURL>
   <title>Spare Tire Bracket :    Here&amp;#039;s how I did it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131667#131667</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 13588<br /><strong>Posted:</strong> 27 May 2020 at 10:48pm<br /><br /><div><font size="3">Here's how I did it on a 2013 RP 172. It may not fit the newer 178 but you may get some ideas. I did use a E2 WDH and it all fit. I don't recall problems turning sharply if going forward. Backing may have required some caution but that always does. From my much earlier post:</font><br></div><div><br></div><div><!--if gte mso 9>    <!--><!--if gte mso 9>   Normal  0          false  false  false    EN-US  X-NONE  X-NONE        <!--><!--if gte mso 9>        <!--><!--if gte mso 10> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0in;	line-height:115%;	mso-pagination:widow-orphan;	font-size:12.0pt;	font-family:"Times New Roman","serif";}<!--><div><font size="3">When we bought our 172 we ordered the factory recommendedbike rack for the rear. This displaced the spare tire. I didn’t want to give upinterior storage space so I devised a way to mount the tire on the tongue. Thiswas a bit of a task since the tongue already had two batteries, two propanetanks, and an equalizer hitch. However, it worked out well.</font></div><div><br></div><div><img src="uploads/1573/IMG_0215-20.jpg" height="519" width="388" border="0" /><br></div><div><br></div><div><br></div><div><!--if gte mso 9>    <!--><!--if gte mso 9>   Normal  0          false  false  false    EN-US  X-NONE  X-NONE        <!--><!--if gte mso 9>        <!--><!--if gte mso 10> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0in;	line-height:115%;	mso-pagination:widow-orphan;	font-size:12.0pt;	font-family:"Times New Roman","serif";}<!--><div><font size="3">The job begins with a Swagman model 64025 RV Bumper Adapter,available from Amazon:</font></div><font size="3"></font><div> <font size="3"><a href="http://www.amaz&#111;n.com/Swagman-RV-2-Bumper-Adaptor/dp/B00174ZHGU/ref=sr_1_5?ie=UTF8&amp;qid=1352492512&amp;sr=8-5&amp;keywords=swagman" target="_blank">http://www.amazon.com/Swagman-RV-2-Bumper-Adaptor/dp/B00174ZHGU/ref=sr_1_5?ie=UTF8&amp;qid=1352492512&amp;sr=8-5&amp;keywords=swagman</a></font></div><font size="3"></font><div><font size="3">This adapter is designed for a 4” square bumper so some workis required to mount it on the 2”x3” RPOD frame tubing. The attachment boltsare replaced with ½ x 4 ½ inch class 8 high strength bolts, flat washers, andlocking nuts to accommodate the 3” frame depth. Two new 9/16” holes, spaced 3”center-to-center from two of the existing holes, are drilled in the top andbottom plates to accommodate the 2” frame width. I would have preferredstainless, but stainless is not as strong as the class 8 bolts so I went withSAE ½ inch bolts and locking nuts. I did replace the 10 mm hex set screw boltwith stainless, but be warned, it is metric. The starting kit is shown below:</font></div><div><font size="3"><br></font></div><div><img src="uploads/1573/IMG_0204-20.jpg" height="388" width="519" border="0" /><br></div><div><br></div><div><br></div><div><!--if gte mso 9>    <!--><!--if gte mso 9>   Normal  0          false  false  false    EN-US  X-NONE  X-NONE        <!--><!--if gte mso 9>        <!--><!--if gte mso 10> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0in;	line-height:115%;	mso-pagination:widow-orphan;	font-size:12.0pt;	font-family:"Times New Roman","serif";}<!--><div><font size="3">The Swagman adapter provides a 2 inch receiver and the FRsupplied tire carrier requires a 1.25 inch receiver. I used the reducer sleevethat came with the bike carrier, but similar devices are available elsewhere.</font></div><font size="3"></font><div> </div><font size="3"></font><div><font size="3">The results are shown below. The adapter just fits, but itfits:</font></div><div><br></div><div><img src="uploads/1573/IMG_0205-20.jpg" height="388" width="519" border="0" /><br></div><div><br></div><div><img src="uploads/1573/IMG_0207-20.jpg" height="519" width="388" border="0" /><br></div><div><br></div><div><img src="uploads/1573/IMG_0222-40.jpg" height="1037" width="775" border="0" /><br></div><br></div></div><div><font size="3">EDIT: Amazing. That old stuff is still on this server. Here's a link to my original post.&nbsp; <a href="http://www.rpod-owners.com/forum_posts.asp?TID=3132&amp;KW=spare+tire&amp;PID=29715&amp;title=t&#111;ngue-mounted-spare-tire-&#111;n-172#29715" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=3132&amp;KW=spare+tire&amp;PID=29715&amp;title=tongue-mounted-spare-tire-on-172#29715</a></font><br></div><br></div>]]>
   <pubDate>Wed, 27 May 2020 22:48:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131667#131667</guid>
   <title>Spare Tire Bracket : FR wants you to limit how much...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131660#131660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 13588<br /><strong>Posted:</strong> 27 May 2020 at 9:53pm<br /><br /><div>FR wants you to limit how much weight you put on the rear receiver, and the further back from the frame them more the weight is multiplied, especially over bumps.&nbsp; It's generally not considered a good idea to put bikes back there.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Wed, 27 May 2020 21:53:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131660#131660</guid>
   <title>Spare Tire Bracket : You can get mounting brackets...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131650#131650</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 13588<br /><strong>Posted:</strong> 27 May 2020 at 6:55pm<br /><br />You can get mounting brackets that attach to the tongue rails, but it doesn't work. &nbsp;There isn't enough room to when you back up and you end up hitting the tire. &nbsp;I tried it and ended up throwing away the bracket. &nbsp;Thankfully, it was really cheap.&nbsp;]]>
   <pubDate>Wed, 27 May 2020 18:55:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131650#131650</guid>
   <title>Spare Tire Bracket :  There is an under the trailer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131647#131647</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13588<br /><strong>Posted:</strong> 27 May 2020 at 5:25pm<br /><br />There is an under the trailer spare tire mounting solution some on the forum have used, I haven't personally heard of a tongue mount for the spare. There is a over the tongue bike mount system too, which allows you to keep your spare aft. Depending on the hitch capacity of your tow vehicle, and how many bikes you're mounting, keeping weight forward is good to reduce load on the trailer axle and to reduce the risk of sway. Even with an anti sway system, you want to try to keep the tongue weight above 10-11% of trailer weight at all times for safety. Think of the anti sway system as having both a belt and suspenders.&nbsp;]]>
   <pubDate>Wed, 27 May 2020 17:25:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131647#131647</guid>
   <title>Spare Tire Bracket : We are new to the R-Pod life,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131640#131640</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10230" rel="nofollow">jjfennfam</a><br /><strong>Subject:</strong> 13588<br /><strong>Posted:</strong> 27 May 2020 at 9:15am<br /><br />We are new to the R-Pod life, but excited to get out and use ours. We have a 2014 R-Pod 178 which is virtually new, for some reason. My question is a way to mount a spare tire on the tongue so that we can keep the rear receiver for a bike rack. The equalizer system we have is the Centerline system. Wondering how I can mount on the tongue and still access the bracket to mount the side bar stabilizers. Any thoughts on a swivel mount for the spare? Appreciate any thoughts, suggestions or links to a great solution.]]>
   <pubDate>Wed, 27 May 2020 09:15:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13588&amp;PID=131640#131640</guid>
