  <title>R-pod Owners Forum : Contin-us 1000 wifi upgrade</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : Contin-us 1000 wifi upgrade</description>
  <pubDate>Fri, 23 Oct 2026 08:55:58 +0000</pubDate>
  <lastBuildDate>Tue, 19 May 2020 05:40:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13558</WebWizForums:feedURL>
   <title>Contin-us 1000 wifi upgrade :  I don&amp;#039;t see anything on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13558&amp;PID=131332#131332</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13558<br /><strong>Posted:</strong> 19 May 2020 at 5:40am<br /><br />I don't see anything on the continu-us that indicates a wifi booster so not sure what you're referring to. But a wifi booster won't help with cellular coverage, it would only help if you were in a private campground that offered wifi data service but it was weak at your campsite.&nbsp;<div><br></div><div>If you want a cellular signal booster look at the weBoost product line. I have a weBoost slim and the Wilson directional antenna which I mount on an extension pole to the flange of the trailer slide while camped. It works pretty well - as long as there is a signal to boost - but&nbsp; not if you are down in a hole somewhere with no signal as olddawsrule says. If you want high bandwidth data service in the true boonies then the only real option is satellite, and mobile satellite data service is very expensive.&nbsp;&nbsp;</div>]]>
   <pubDate>Tue, 19 May 2020 05:40:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13558&amp;PID=131332#131332</guid>
   <title>Contin-us 1000 wifi upgrade : Don&amp;#039;t know what the upgrade...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13558&amp;PID=131330#131330</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7667" rel="nofollow">Olddawgsrule</a><br /><strong>Subject:</strong> 13558<br /><strong>Posted:</strong> 19 May 2020 at 5:26am<br /><br />Don't know what the upgrade is, but... A Wifi booster? Most are Cell boosters and have come a long ways since mine.<div><br></div><div>Mine is specific to bands and had to be certain it matched my cell service. Mine also will do Wifi, but different band than cell. So I ask... Is what there are offering good for both?</div><div><br></div><div>No matter if it does one or both and matches the bands you require, if you have no signal where you camp, then there is nothing to boost.&nbsp;</div>]]>
   <pubDate>Tue, 19 May 2020 05:26:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13558&amp;PID=131330#131330</guid>
   <title>Contin-us 1000 wifi upgrade : Buying a 2020 R Pod 192 that has...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13558&amp;PID=131321#131321</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10193" rel="nofollow">pbhooley</a><br /><strong>Subject:</strong> 13558<br /><strong>Posted:</strong> 18 May 2020 at 2:37pm<br /><br />Buying a 2020 R Pod 192 that has a Continu-us 1000 tv/fm antenna installed. Any advantages to upgrading to get enhanced wifi? Would this improve cell service in the boonies?]]>
   <pubDate>Mon, 18 May 2020 14:37:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13558&amp;PID=131321#131321</guid>
