  <title>R-pod Owners Forum : Removal of LED Running light???</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Removal of LED Running light???</description>
  <pubDate>Sat, 24 Oct 2026 20:49:27 +0000</pubDate>
  <lastBuildDate>Mon, 06 Jul 2020 19:04:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13544</WebWizForums:feedURL>
   <title>Removal of LED Running light??? : I wired ours to the license plate...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133374#133374</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7746" rel="nofollow">crw8sr</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 06 Jul 2020 at 7:04pm<br /><br />I wired ours to the license plate light.&nbsp; The camera is always on when the lights are on.&nbsp; I always drive with the vehicle lights on.]]>
   <pubDate>Mon, 06 Jul 2020 19:04:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133374#133374</guid>
   <title>Removal of LED Running light??? : ok </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133331#133331</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 05 Jul 2020 at 6:47pm<br /><br />ok]]>
   <pubDate>Sun, 05 Jul 2020 18:47:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133331#133331</guid>
   <title>Removal of LED Running light??? : Ah yeah I was trying to avoid...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133330#133330</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9459" rel="nofollow">mattb19us</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 05 Jul 2020 at 6:46pm<br /><br />Ah yeah I was trying to avoid running new wires. There's 12V running to the backup LED's and there's 5 across, so if I can tap into the middle one, that should be a good location. Just need to seal it up well afterwards.&nbsp;]]>
   <pubDate>Sun, 05 Jul 2020 18:46:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133330#133330</guid>
   <title>Removal of LED Running light??? : The main harness of the Pod....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133329#133329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 05 Jul 2020 at 6:42pm<br /><br />The main harness of the Pod.  On the front left of the Pod look and see if you have yellow wires terminated.  Those wires are connected to the seven way and are the back up light wires.  I used them when I added back up lights to my Pod.  I would use them to power a back up camera.  Take an voltmeter and verify.]]>
   <pubDate>Sun, 05 Jul 2020 18:42:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133329#133329</guid>
   <title>Removal of LED Running light??? : Which harness? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133328#133328</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9459" rel="nofollow">mattb19us</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 05 Jul 2020 at 6:37pm<br /><br />Which harness?]]>
   <pubDate>Sun, 05 Jul 2020 18:37:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133328#133328</guid>
   <title>Removal of LED Running light??? : Why not use the back up light...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133327#133327</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 05 Jul 2020 at 6:32pm<br /><br />Why not use the back up light wiring that is in the harness?  Leave your lights alone.]]>
   <pubDate>Sun, 05 Jul 2020 18:32:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133327#133327</guid>
   <title>Removal of LED Running light??? :   Originally posted by MTNewbie20Hi...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133326#133326</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9459" rel="nofollow">mattb19us</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 05 Jul 2020 at 6:28pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by MTNewbie20</strong></em><br /><br />Hi All, have been searching the site for how to remove a back running light in order to install a back up camera. Just need access to the wires there. Does the light screw on/off, pry off, what? Don't want to do any damage!<div><br></div><div>TIA!!</div></td></tr></table><div><br></div><div>Wondering about the same. I have a 195 and going to be removing the center light and adding a Furrion Vision system tomorrow</div>]]>
   <pubDate>Sun, 05 Jul 2020 18:28:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=133326#133326</guid>
   <title>Removal of LED Running light??? :  I had mine installed when I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131171#131171</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 13 May 2020 at 7:53am<br /><br />I had mine installed when I purchased it. I didn't actually see how he did it. The camera is installed about 2 inches above the center light. I don't know if he might have put a small hole under the camera area, and fished the wires out, or if he removed the light, sorry.&nbsp;]]>
   <pubDate>Wed, 13 May 2020 07:53:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131171#131171</guid>
   <title>Removal of LED Running light??? : Yes at the top but no spoiler....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131161#131161</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10098" rel="nofollow">MTNewbie20</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 12 May 2020 at 4:11pm<br /><br />Yes at the top but no spoiler.&nbsp;]]>
   <pubDate>Tue, 12 May 2020 16:11:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131161#131161</guid>
   <title>Removal of LED Running light??? : If you are talking about the ones...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131159#131159</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 12 May 2020 at 4:00pm<br /><br />If you are talking about the ones at the top, in the spoiler, they pop out.&nbsp;]]>
   <pubDate>Tue, 12 May 2020 16:00:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131159#131159</guid>
   <title>Removal of LED Running light??? : Hi All, have been searching the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131158#131158</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10098" rel="nofollow">MTNewbie20</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 12 May 2020 at 3:18pm<br /><br />Hi All, have been searching the site for how to remove a back running light in order to install a back up camera. Just need access to the wires there. Does the light screw on/off, pry off, what? Don't want to do any damage!<div><br></div><div>TIA!!</div>]]>
   <pubDate>Tue, 12 May 2020 15:18:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13544&amp;PID=131158#131158</guid>
