  <title>R-pod Owners Forum : 176T Modifications - removing tent?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Dealer Reviews and Comments : 176T Modifications - removing tent?</description>
  <pubDate>Sat, 07 Nov 2026 05:05:03 +0000</pubDate>
  <lastBuildDate>Fri, 24 Apr 2020 15:41:22 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13497</WebWizForums:feedURL>
   <title>176T Modifications - removing tent? : Thank you! We are now leaning...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130613#130613</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 24 Apr 2020 at 3:41pm<br /><br />Thank you! &nbsp;We are now leaning towards a 176 not a 176T. &nbsp;This is all good info!]]>
   <pubDate>Fri, 24 Apr 2020 15:41:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130613#130613</guid>
   <title>176T Modifications - removing tent? :   Originally posted by offgrid  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130595#130595</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 24 Apr 2020 at 9:02am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by PhoebeTheDog</strong></em><br /><br />Thanks and yes. The weight issue is the reason we like the rpods. The nobos are not what we are looking afor. Yes i did verify the 176 t’a are out of production but we are going to see a new one still at a lot near us, so i suspect that will answer a lot of our questions!</td></tr></table><div><br></div><div>It sounds like you have thought this through. One thing to watch out for on the 176t is that the gray and fresh water tanks are behind the axle. As water is very heavy, that makes it easy to end up with too much weight in the rear of the trailer. That is very dangerous as the tongue weight winds up too low and you can get sway. especially with a light tow vehicle. I would be careful never to fill both the fresh water and gray water tank at the same time. And if you buy one, load it including water and get a tongue and total weight so you know what you have. Don't go below 10% on the tongue weight,. preferably higher. And get an antisway system.</div><div><br></div><div>Do take a close look at whether you can slide the tent out of the keder rail and also how the bottom is hinged so you can remove that without having an unsightly mess.&nbsp; If you don't want to make up a screen yourself my suggestion would be to find a company that makes up custom screens and windows for boats and see what their thoughts are.</div><div><br></div><div>Good luck and hope to see you back on the forum soon!</div></td></tr></table>]]>
   <pubDate>Fri, 24 Apr 2020 09:02:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130595#130595</guid>
   <title>176T Modifications - removing tent? :   Originally posted by PhoebeTheDogThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130594#130594</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 24 Apr 2020 at 9:00am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by PhoebeTheDog</strong></em><br /><br />Thanks and yes. The weight issue is the reason we like the rpods. The nobos are not what we are looking afor. Yes i did verify the 176 t’a are out of production but we are going to see a new one still at a lot near us, so i suspect that will answer a lot of our questions!</td></tr></table><div><br></div><div>It sounds like you have thought this through. One thing to watch out for on the 176t is that the gray and fresh water tanks are behind the axle. As water is very heavy, that makes it easy to end up with too much weight in the rear of the trailer. That is very dangerous as the tongue weight winds up too low and you can get sway. especially with a light tow vehicle. I would be careful never to fill both the fresh water and gray water tank at the same time. And if you buy one, load it including water and get a tongue and total weight so you know what you have. Don't go below 10% on the tongue weight,. preferably higher.&nbsp;</div><div><br></div><div>Do take a close look at whether you can slide the tent out of the keder rail and also how the bottom is hinged so you can remove that without having an unsightly mess.&nbsp; If you don't want to make up a screen yourself my suggestion would be to find a company that makes up custom screens and windows for boats and see what their thoughts are.</div><div><br></div><div>Good luck and hope to see you back on the forum soon!</div>]]>
   <pubDate>Fri, 24 Apr 2020 09:00:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130594#130594</guid>
   <title>176T Modifications - removing tent? :  Furpod, Most impressive video...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130587#130587</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 23 Apr 2020 at 8:24pm<br /><br />Furpod,&nbsp; Most impressive video setting up the r-dome. &nbsp; I have been doing mine for almost 9 years and I guess i must move slower than you, my time is closer to 15 minutes.&nbsp; Maybe I am taking 5 minutes to hook up the 6 suction cups, not!]]>
   <pubDate>Thu, 23 Apr 2020 20:24:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130587#130587</guid>
   <title>176T Modifications - removing tent? : Thanks and yes. The weight issue...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130567#130567</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 23 Apr 2020 at 1:35pm<br /><br />Thanks and yes. The weight issue is the reason we like the rpods. The nobos are not what we are looking afor. Yes i did verify the 176 t’a are out of production but we are going to see a new one still at a lot near us, so i suspect that will answer a lot of our questions!]]>
   <pubDate>Thu, 23 Apr 2020 13:35:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130567#130567</guid>
   <title>176T Modifications - removing tent? : If you want to tow with your Ridgeline...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130548#130548</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 23 Apr 2020 at 6:24am<br /><br />If you want to tow with your Ridgeline then you'll need to stay with a trailer that is well under 5000 lbs fully loaded. This is where FR's (and the other manufacturer's) specs are very misleading. Their NoBo 19 series states "under 5000" but that is empty, no way you can safely tow one of those with your Honda.&nbsp;<div><br></div><div>I have a Highlander, same tow rating as your Ridgeline, and my 179 weighs in at about 3800 fully (but carefully) loaded. I wouldn't tow anything heavier. Note that the 5000 lb ratings on the tow vehicles are with nothing else except a driver in them.&nbsp;<div><br></div><div>The 176T falls within the Ridgeline's capabilites too, if you load carefully and don't try to take a ton of stuff with you in the truck. The 16 series Nobo's are heavier than the 176T so I doubt you'll be comfortable towing that with your current vehicle.&nbsp;</div><div><br></div><div>There appear to be some 2020 176T's around so you should still be able to get one, and don't be afraid of getting a used travel trailer. So many of them are used only once or twice but long enough to get the workmanship bugs sorted out (TT's are notorious for workmanship issues), so for thousands less you can get an essentially new vehicle that's better than when it left the factory.&nbsp;</div></div>]]>
   <pubDate>Thu, 23 Apr 2020 06:24:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130548#130548</guid>
   <title>176T Modifications - removing tent? : Hmm..interesting. Will check them...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130541#130541</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 2:52pm<br /><br />Hmm..interesting. &nbsp;Will check them out]]>
   <pubDate>Wed, 22 Apr 2020 14:52:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130541#130541</guid>
   <title>176T Modifications - removing tent? :  Honestly, for what you seem...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130540#130540</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 2:51pm<br /><br /><div>Honestly, for what you seem to want, you might look at one of the smallest toy haulers. I have seen them down in the 19 foot length. The NoBo has a couple, they are made in the same facility, and by the same people, as R-Pod.. My wife and I have looked pretty hard at the 10.6<br><br><a href="http://forestriverinc.com/rvs/travel-trailers/no-boundaries" target="_blank">NoBo..</a><br></div><div><br></div>]]>
   <pubDate>Wed, 22 Apr 2020 14:51:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130540#130540</guid>
   <title>176T Modifications - removing tent? : ruh roh....Thank you! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130539#130539</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 2:47pm<br /><br />ruh roh....<div><br></div><div>Thank you!</div>]]>
   <pubDate>Wed, 22 Apr 2020 14:47:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130539#130539</guid>
   <title>176T Modifications - removing tent? :   Originally posted by PhoebeTheDogAwesome!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130538#130538</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 2:47pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by PhoebeTheDog</strong></em><br /><br />Awesome! &nbsp;Great thoughts. &nbsp;I just wanted get other's opinions and thank you for yours. &nbsp;Last q: Any ideas who to contact at Forrest River to verify how the current model is configured (i.e.tent and tent bed). &nbsp; Also I was thinking it seems like a tent could need to be replaced so I figure there must be a relatively easy way to remove. &nbsp; &nbsp;Sorry for so many questions! &nbsp;Maybe this info is on this forum elsewhere</td></tr></table>The search function is not always intuitive. For example, when you search, the default for results is posts six months old and newer. If you select the "Advanced Search" option, you can expand the search range to include older topics. This is handy to find information that may have been mentioned sometime in the past, but not within the past six months.<br>]]>
   <pubDate>Wed, 22 Apr 2020 14:47:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130538#130538</guid>
   <title>176T Modifications - removing tent? : If you go to FR&amp;#039;s website,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130537#130537</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 2:46pm<br /><br />If you go to <a href="http://forestriverinc.com/rvs/travel-trailers/r-pod-west-coast?Regi&#111;nSelected=1" target="_blank">FR's website</a>, they have a listing of all current models and specs.<br><br>Looking though.. it appears the 176T is out of production, which isn't surprising considering how little demand there was for them.<br>]]>
   <pubDate>Wed, 22 Apr 2020 14:46:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130537#130537</guid>
   <title>176T Modifications - removing tent? : Awesome! Great thoughts. I just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130536#130536</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 2:37pm<br /><br />Awesome! &nbsp;Great thoughts. &nbsp;I just wanted get other's opinions and thank you for yours. &nbsp;Last q: Any ideas who to contact at Forrest River to verify how the current model is configured (i.e.tent and tent bed). &nbsp; Also I was thinking it seems like a tent could need to be replaced so I figure there must be a relatively easy way to remove. &nbsp; &nbsp;Sorry for so many questions! &nbsp;Maybe this info is on this forum elsewhere]]>
   <pubDate>Wed, 22 Apr 2020 14:37:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130536#130536</guid>
   <title>176T Modifications - removing tent? : Yeah, some parts or Norcal might...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130535#130535</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 12:49pm<br /><br />Yeah, some parts or Norcal might be OK for bugs much of the time, but even there you can have problems. Even at the beach you can get tons of kelp fies sometimes. When I lived in Santa Cruz and had a Westy bus I still used a screen in the rear hatch.&nbsp;&nbsp;<div><br></div><div>If the tent is held in by a keder rail then it should slide out.&nbsp; Then, unscrew and remove the hinge for the bed bottom. Leave the keder rail in place and you could sew up a flat screen to slide into the rail in place of the tent.&nbsp; Save all the stuff and put it back when you sell. Should work.&nbsp;</div>]]>
   <pubDate>Wed, 22 Apr 2020 12:49:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130535#130535</guid>
   <title>176T Modifications - removing tent? : Here is a pic of a tiny Happier...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130534#130534</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 11:14am<br /><br />Here is a pic of a tiny Happier Camper that shows sort of what we are looking https://www.google.com/search?q=happier+camper+open+back&tbm=isch&ved=2ahUKEwiagdmvtvzoAhUXg6wKHWy1BLkQ2-cCegQIABAC&oq=happier+camper&gs_lcp=ChJtb2JpbGUtZ3dzLXdpei1pbWcQARgAMgIIKTICCAAyAggAMgIIADICCAAyAggAOgUIIRCrAjoECB4QCjoHCCEQChCrAjoFCCkQqwI6BggAEAUQHjoECAAQGDoGCCkQBxAeOgQIKRADOgQIKRAYOgQIKRBDOgQIABBDUMmmAViyigJgipICaA1wAHgCgAGHAYgB2CCSAQUxMS4yOJgBAKABAbABWA&sclient=mobile-gws-wiz-img&ei=62ygXtrfBZeGsgXs6pLICw&bih=619&biw=375&prmd=sivn#imgrc=KDsumZXDKM66rM<br />]]>
   <pubDate>Wed, 22 Apr 2020 11:14:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130534#130534</guid>
   <title>176T Modifications - removing tent? : Thanks for the suggestions. We...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130533#130533</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 11:11am<br /><br />Thanks for the suggestions. We definitely dont like the dome as what we are looking for is a dinette in the back with the opening there, not a tent setup.  Interested in what you are saying about the “keder rail at the top” though.  If i understand we could unscrew the keder rail, unsnap the snaps and it would come off?&nbsp;&nbsp;&nbsp;<br />Ideally we couls go to a dealer and see one but there are none in stock anywhere close to is so i appreciate your<br />Feedback. ]]>
   <pubDate>Wed, 22 Apr 2020 11:11:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130533#130533</guid>
   <title>176T Modifications - removing tent? :   The tent is held on by keder...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130531#130531</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 10:47am<br /><br />The tent is held on by keder rail and snaps, as I recall.. I have worked on, or helped with hundreds of Pods over the years, only 2 176Ts that I recall. No one wanted to remove it, generally trouble with the keder rail insert at the top.<br><br>As was said above, the dome may get you what you want..<br><br>The dome is, to most, fairly easy. It took me about 10 minutes, solo, to put it up or take down.&nbsp;<br><div><br></div><div>A few years ago my wife just sat and videoed me setting it up. Usually takes the dogs for a walk while I set up camp, once in place and leveled up...<br><br><a href="http://www.youtube.com/watch?v=l03M5OWxufE&amp;feature=youtu.be" target="_blank">Dome set up.. </a><br></div>]]>
   <pubDate>Wed, 22 Apr 2020 10:47:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130531#130531</guid>
   <title>176T Modifications - removing tent? : Thanks for your reply!  Yes i...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130529#130529</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 10:39am<br /><br />Thanks for your reply!  Yes i get it that the resale value may not be there, bit frankly not concerned about this.  You raise some good points.  We are on the west coast north of San Francisco and are fortunate enough not to have bugs, however when camping  elsewhere we would create some kind of screen to use.  We really like the idea of being able to open up the entire back for the view and fresh air.  Do you know how easy/difficult it may be to just remove the tent?  How is it secured?&nbsp;&nbsp;&nbsp;Thanks for any feedback!]]>
   <pubDate>Wed, 22 Apr 2020 10:39:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130529#130529</guid>
   <title>176T Modifications - removing tent? : As rare as 176Ts are.. I would...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130528#130528</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 22 Apr 2020 at 10:37am<br /><br /><div>As rare as 176Ts are.. I would not want to do anything not "returnable to stock", so to speak.</div><div><br></div><div>I know of no one who has done such a thing as you are suggesting, but most definitely agree that the dome option should give you everything that it seems to me you are looking for.. but of course only you know what you are trying to accomplish. <br></div><div><br></div><div>That said, I also agree that finding a used one to start is probably the best idea, though when it comes to 176Ts.. taking any one you can find may be your only real option... <br></div>]]>
   <pubDate>Wed, 22 Apr 2020 10:37:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130528#130528</guid>
   <title>176T Modifications - removing tent? : If you want to make a major change...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130508#130508</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 21 Apr 2020 at 4:04pm<br /><br />If you want to make a major change like that I'd suggest starting with a used trailer. Hybrid trailers appeal to a specific group of customers and you would be basically eliminating them as resale customers if and when you wanted to resell your trailer. Also, perhaps anywhere but certain areas of the West Coast, folks wouldn't consider doing what you are suggesting because the trailer would be full of bugs eating you alive all night....A hybrid really opens up very nicely even if you leave the flexible walls and screens intact, why not try that first and see if it meets your needs for having an open to the air camping experience? Or you could also consider getting a rdome which you can set up as an open air environment if you want to.&nbsp;<div><br></div><div><br><div><br></div></div>]]>
   <pubDate>Tue, 21 Apr 2020 16:04:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130508#130508</guid>
   <title>176T Modifications - removing tent? : We are very interested in purchasing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130507#130507</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10146" rel="nofollow">PhoebeTheDog</a><br /><strong>Subject:</strong> 13497<br /><strong>Posted:</strong> 21 Apr 2020 at 2:50pm<br /><br />We are very interested in purchasing a new 176T. &nbsp;We like the 176T model instead of the 176, not so much for the tent or the additional bed that comes with it, but that the back side completely opens up.&nbsp;<div>&nbsp;We are thinking of removing the tent and the fold out "floor" of the tent and just being able to close and open the back side while sitting in the dinette with the back door completely open. &nbsp;Has any one else done this? Also, since the back side does not have a window on this model we were thinking of putting an after-market window in where the 'tire' is (keep the tire in our truck) Any thoughts/ideas on this would be appreciated!</div>]]>
   <pubDate>Tue, 21 Apr 2020 14:50:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13497&amp;PID=130507#130507</guid>
