  <title>R-pod Owners Forum : Outside sprayer attachment</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Outside sprayer attachment</description>
  <pubDate>Wed, 23 Sep 2026 23:55:15 +0000</pubDate>
  <lastBuildDate>Fri, 27 Mar 2020 09:14:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13460</WebWizForums:feedURL>
   <title>Outside sprayer attachment : That worked. You were right. It...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130086#130086</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10100" rel="nofollow">Ron W</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 27 Mar 2020 at 9:14am<br /><br />That worked. You were right. It got a little easier to connect after I did it a few times. Really had to push hard. Thank you😄]]>
   <pubDate>Fri, 27 Mar 2020 09:14:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130086#130086</guid>
   <title>Outside sprayer attachment : Thanks I&#226;&#8364;&#8482;ll try that. Maybe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130085#130085</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10100" rel="nofollow">Ron W</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 27 Mar 2020 at 8:55am<br /><br />Thanks I’ll try that. Maybe I didn’t push hard enough.]]>
   <pubDate>Fri, 27 Mar 2020 08:55:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130085#130085</guid>
   <title>Outside sprayer attachment : It&amp;#039;s a quick connect connection....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130083#130083</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10066" rel="nofollow">RoverPod</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 27 Mar 2020 at 7:02am<br /><br />It's a quick connect connection. You need to slide the collar back and push the connector from the blue hose into the port. You need to PUSH really hard.]]>
   <pubDate>Fri, 27 Mar 2020 07:02:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130083#130083</guid>
   <title>Outside sprayer attachment : Thanks for the attempt! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130072#130072</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10100" rel="nofollow">Ron W</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 26 Mar 2020 at 7:53pm<br /><br />Thanks for the attempt!]]>
   <pubDate>Thu, 26 Mar 2020 19:53:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130072#130072</guid>
   <title>Outside sprayer attachment : ok, you got me... this is an option...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130068#130068</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7163" rel="nofollow">Kup-Pod</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 26 Mar 2020 at 7:22pm<br /><br />ok, you got me... this is an option I don't have so it's beyond my wisdom! :-)<div>Sorry about that!<img src="https://www.rpod-owners.com/smileys/smiley9.gif" border="0" alt="Embarrassed" title="Embarrassed" /></div>]]>
   <pubDate>Thu, 26 Mar 2020 19:22:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130068#130068</guid>
   <title>Outside sprayer attachment : The new 190 comes with a sprayer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130067#130067</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10100" rel="nofollow">Ron W</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 26 Mar 2020 at 7:19pm<br /><br />The new 190 comes with a sprayer hose and the attachment is on the opposite side from the shower. The hose won’t connect?]]>
   <pubDate>Thu, 26 Mar 2020 19:19:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130067#130067</guid>
   <title>Outside sprayer attachment : If nothing has changed from recent...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130066#130066</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7163" rel="nofollow">Kup-Pod</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 26 Mar 2020 at 7:09pm<br /><br />If nothing has changed from recent years, I don't think there should not be anything to connect per se, perhaps the small push valve on the shower head is not open?]]>
   <pubDate>Thu, 26 Mar 2020 19:09:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130066#130066</guid>
   <title>Outside sprayer attachment : Have a new 2020 r pod 190. Can&#226;&#8364;&#8482;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130065#130065</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10100" rel="nofollow">Ron W</a><br /><strong>Subject:</strong> 13460<br /><strong>Posted:</strong> 26 Mar 2020 at 7:07pm<br /><br />Have a new 2020 r pod 190. Can’t figure out how to connect the outside sprayer?]]>
   <pubDate>Thu, 26 Mar 2020 19:07:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13460&amp;PID=130065#130065</guid>
