  <title>R-pod Owners Forum : rubber seal front to back</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : rubber seal front to back</description>
  <pubDate>Thu, 29 Oct 2026 21:18:02 +0000</pubDate>
  <lastBuildDate>Sat, 07 Mar 2020 08:50:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13426</WebWizForums:feedURL>
   <title>rubber seal front to back :  I have a small 1/2 inch cut...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13426&amp;PID=129705#129705</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9992" rel="nofollow">Wirat</a><br /><strong>Subject:</strong> 13426<br /><strong>Posted:</strong> 07 Mar 2020 at 8:50am<br /><br />I have a small 1/2 inch cut in one spot of mine and I patched it over with some black silicone. Since it's all plastic. I'll keep this info in my war chest for later... I was also told that you buy the trim in one long piece and replace it all as one long piece (as lostagain's post suggests). I'm just not sure how easy that new trim would slide in or if it would be an "inch by inch" battle the entire way...]]>
   <pubDate>Sat, 07 Mar 2020 08:50:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13426&amp;PID=129705#129705</guid>
   <title>rubber seal front to back :  You can buy the material you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13426&amp;PID=129691#129691</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 13426<br /><strong>Posted:</strong> 06 Mar 2020 at 3:26pm<br /><br />You can buy the material you need on Amazon. &nbsp;Here's a sample: &nbsp;<div><a href="http://www.amaz&#111;n.com/s?k=rv+flexible+mold+trim&amp;i=automotive&amp;ref=nb_sb_noss" target="_blank">https://www.amazon.com/s?k=rv+flexible+mold+trim&amp;i=automotive&amp;ref=nb_sb_noss</a><br><div>Just pull out the old and put in new. &nbsp;It's best to have it nice and warm so it bends easily and snaps into place.</div></div>]]>
   <pubDate>Fri, 06 Mar 2020 15:26:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13426&amp;PID=129691#129691</guid>
   <title>rubber seal front to back : On my 172 RP, I was putting enternabond...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13426&amp;PID=129690#129690</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 13426<br /><strong>Posted:</strong> 06 Mar 2020 at 2:17pm<br /><br /><font size="3" face="Arial, Helvetica, sans-serif">On my 172 RP,&nbsp; I was putting enternabond tape on the spoiler and saw where there are two broken spots in the rubber gasket that runs from the bottom front up over the RV and back down the back. It is the top outer edge molding gasket.&nbsp; The rubber has turned hard and brittle.&nbsp; Is there a fix or do I have to take it to the dealer?&nbsp; This RV is a 2017 and I think I got a Monday or Friday made camper.</font>]]>
   <pubDate>Fri, 06 Mar 2020 14:17:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13426&amp;PID=129690#129690</guid>
