  <title>R-pod Owners Forum : Lp tank Cover</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Campers Flea Market : Lp tank Cover</description>
  <pubDate>Fri, 06 Nov 2026 23:20:43 +0000</pubDate>
  <lastBuildDate>Thu, 06 Feb 2020 21:27:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13378</WebWizForums:feedURL>
   <title>Lp tank Cover : Unfortunately, the 2016 vinyl...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129180#129180</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13378<br /><strong>Posted:</strong> 06 Feb 2020 at 9:27pm<br /><br />Unfortunately, the 2016 vinyl cover does not hold up well. It is much like the spare tire cover. They do deteriorate. That is why I also went with the Camco cover although I would have preferred to get another vinyl cover. I still have the original, but it would not be something you would want.]]>
   <pubDate>Thu, 06 Feb 2020 21:27:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129180#129180</guid>
   <title>Lp tank Cover : You don&amp;#039;t happen to have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129179#129179</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 13378<br /><strong>Posted:</strong> 06 Feb 2020 at 7:11pm<br /><br />You don't happen to have the old cover do you?<div><br></div>]]>
   <pubDate>Thu, 06 Feb 2020 19:11:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129179#129179</guid>
   <title>Lp tank Cover : Our 2016 came with a vinyl cover...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129178#129178</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 13378<br /><strong>Posted:</strong> 06 Feb 2020 at 5:52pm<br /><br />Our 2016 came with a vinyl cover that I hated. I went the other way and got one of the Camco hard covers.]]>
   <pubDate>Thu, 06 Feb 2020 17:52:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129178#129178</guid>
   <title>Lp tank Cover : Thanks for the suggestion but...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129176#129176</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 13378<br /><strong>Posted:</strong> 06 Feb 2020 at 4:22pm<br /><br />Thanks for the suggestion but I got 2 from Forest River that they claimed were the correct replacement and neither fit.]]>
   <pubDate>Thu, 06 Feb 2020 16:22:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129176#129176</guid>
   <title>Lp tank Cover : You might contact Forest River...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129175#129175</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13378<br /><strong>Posted:</strong> 06 Feb 2020 at 4:18pm<br /><br />You might contact Forest River and see what their source was. That will likely be more expensive than some of the ones you can get on Amazon though. How about one of these from <a href="https://www.etrailer.com/search/20+Lb+Propane+Tank+Cover" target="_blank">eTrailer</a>?]]>
   <pubDate>Thu, 06 Feb 2020 16:18:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129175#129175</guid>
   <title>Lp tank Cover :   Looking for a soft plastic...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129174#129174</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 13378<br /><strong>Posted:</strong> 06 Feb 2020 at 1:29pm<br /><br /><div><br></div><div>Looking for a soft plastic black single LP tank cover. This will be the type that came with an R-pod back around 2015. Mine has seen better days and I do not like the hard plastic ones. You can send a PM if you wish.&nbsp; Thanks.&nbsp;</div><div><br></div><div>PS: I have tried several of the ones for sale on Amazon etc. but they are not the same.</div>]]>
   <pubDate>Thu, 06 Feb 2020 13:29:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13378&amp;PID=129174#129174</guid>
