  <title>R-pod Owners Forum : 50A to 30A and 20A Y-adapter...any downsides?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : 50A to 30A and 20A Y-adapter...any downsides?</description>
  <pubDate>Sat, 24 Oct 2026 05:27:12 +0000</pubDate>
  <lastBuildDate>Wed, 15 Jan 2020 17:37:00 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13350</WebWizForums:feedURL>
   <title>50A to 30A and 20A Y-adapter...any downsides? : The Pod has a L5-30 receptacle,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128873#128873</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 15 Jan 2020 at 5:37pm<br /><br />The Pod has a L5-30 receptacle, so I can't see any reason why an inline GFCI/breaker wouldn't work without an adapter when plugged directly into the Pod and then the normal power cable plugged into it.<br /><br />offgrid makes a good point though.]]>
   <pubDate>Wed, 15 Jan 2020 17:37:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128873#128873</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? : Be careful to read the fine print...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128871#128871</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 15 Jan 2020 at 5:04pm<br /><br />Be careful to read the fine print on the inline gfci devices. They are meant to add ground fault detection and interruption to a circuit that already has a circuit breaker, so usually don’t detect overcurrent conditions, which is what we want here.  ]]>
   <pubDate>Wed, 15 Jan 2020 17:04:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128871#128871</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? :   Originally posted by TheBumI&amp;#039;ve...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128870#128870</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 15 Jan 2020 at 2:49pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TheBum</strong></em><br /><br />I've searched for 50A-&gt;30A adapters with built-in 30A circuit breakers but had no luck. Seems like a good business opportunity for someone.</td></tr></table><div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div>Got me to thinking...</div><div><br></div><div>Found this:</div><div><br></div><div><span style="color: rgb28, 28, 28; font-family: Tahoma, Geneva, sans-serif;">Cord Set &nbsp;In-line GFCI &nbsp;Voltage Rating 120 &nbsp;Amps AC 30 &nbsp;Color Yellow &nbsp;Cord Length (Ft.) 2 &nbsp;NEMA Plug Configuration L5-30P &nbsp;NEMA Receptacle L5-30R &nbsp;Reset Type Manual &nbsp;Standards UL 943 &nbsp;CSA</span></div><div><span style="color: rgb28, 28, 28; font-family: Tahoma, Geneva, sans-serif;"><br></span></div><div><a href="http://www.metsorj.com/ProductDetails.asp?ProductCode=G3B970" target="_blank">http://www.metsorj.com/ProductDetails.asp?ProductCode=G3B970</a></div><div><br></div><div>Don't know if the Plug/Receptacle configuration is RV-compatible, however.</div>]]>
   <pubDate>Wed, 15 Jan 2020 14:49:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128870#128870</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? : I&amp;#039;ve searched for 50A-&amp;gt;30A...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128869#128869</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 15 Jan 2020 at 12:14pm<br /><br />I've searched for 50A-&gt;30A adapters with built-in 30A circuit breakers but had no luck. Seems like a good business opportunity for someone.]]>
   <pubDate>Wed, 15 Jan 2020 12:14:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128869#128869</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? : 12awg is generally good for 20a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128852#128852</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 12:18pm<br /><br />12awg is generally good for 20a ampacity. <br /><br />Current limited faults (which is what we’re talking about here) can be hot to neutral or hot to ground, and can occur when the wire insulation is partially cut or abraded, or from moisture or corrosion at a plug or receptacle. You could also get a resistive (low current) fault combined with the normal load current which can put you over the conductor ampacity limit. I can’t answer regarding how common they are other than to say I’ve seen them more than once both at home and professionally and that a large portion of the electrical code deals with protection from these kind of fault conditions. The code is very strict in requiring all conductors to be protected by a fuse or cb which doesn’t allow that conductor to ever carry more current than its designed for. ]]>
   <pubDate>Tue, 14 Jan 2020 12:18:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128852#128852</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? :  Extension cord would be 12-guage....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128851#128851</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 11:51am<br /><br /><div>Extension cord would be 12-guage.&nbsp; Heater draws 7 amps (use it at 1/2 power).&nbsp; May still be a bad idea.</div><div><br></div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />...And yes in the event of a fault you absolutely can flow more than 30a in the cord...</td></tr></table><div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div>Curious...what type of fault are you referring to?&nbsp; How common are such faults?</div><div><br></div><div>The confusing thing to me is that so many folks on various forums say that it's perfectly ok to power a 30-amp rig off a 50-amp pedestal using the appropriate adapter.</div>]]>
   <pubDate>Tue, 14 Jan 2020 11:51:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128851#128851</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? : You are going to connect an extension...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128850#128850</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 11:17am<br /><br />You are going to connect an extension cord and a heater to the 20a output of the dog bone, right? The cord and heater are not rated for 50a. Where in that circuit is there overcurrent protection for that extension cord and heater? Answer: there’s not. <br /><br />As to the quote from the retired electrician, he’s wrong.  Lots of things get sold that can be dangerous. There should be a label next to your trailer receptacle that says not to connect it to a circuit which is  not limited to 30a. That label is a code requirement, it’s there for a reason.  You are violating it if you connect a 50 to 30a dog bone. And yes in the event of a fault you absolutely can flow more than 30a in the cord and the wiring between the receptacle and the distribution panel. Nothing stops that unless the current flow exceeds 50a, at which point the 50a breaker should trip. <br /><br />You asked if there was a downside so I gave you one. It’s your trailer, you are certainly free to decide to proceed anyway. No need for a debate about it. ]]>
   <pubDate>Tue, 14 Jan 2020 11:17:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128850#128850</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? :     Originally posted by offgridConceptually...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128849#128849</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 10:27am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />Conceptually it’s a similar issue but in practice it’s worse than the 50 to 30 dog bone because with the 30A you are feeding your loads through the rpod distribution panel and its circuit breakers, while with the 50 to 15a dogbone you’re going straight to your loads with no overcurrent protection at all other than the 50a breaker at the pedestal....</td></tr></table><div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div>But the R-Pod would be plugged in to the 30-amp female outlet on the Y-adapter just as if it were a simple 50 to 30 dogbone, so I guess I'm confused.&nbsp; I thought that the distribution panel would limit the current that the 195 sees to 30 amps, based on discussions I've seen related to using 50-amp to 30-amp dogbones.&nbsp; In fact I recall people indicating that 50-30 dogbones only allow 30 amps at the to pass through anyway, e.g.,</div><div><br></div><div><span style="font-size: 12.48px; : rgb240, 244, 247;"><i>I am a retired electrician and this response is wrong. Your motorhome is protected by a 30 amp breaker in the breaker box, so 50 amps could never end up on the power cord. If it was dangerous they would not sell 30 to 50 amp converters. The box in the campground is rated for 50 amps and that is the most it can deliver, but it only delivers the amount of amperage your motorhome is drawing. Since the motorhome is limited to drawing 30 amps at the most then the cord will never see more than 30 amps.</i></span></div><div><span style="font-size: 12.48px; : rgb240, 244, 247;"><i><br></i></span></div><div><a href="http://www.rvforum.net/SMF_forum/index.php?topic=20659.0" target="_blank">http://www.rvforum.net/SMF_forum/index.php?topic=20659.0</a></div><div><br></div><div>The only difference is the extra 20-amp female connector that would allow something like a space heater to be plugged in.</div>]]>
   <pubDate>Tue, 14 Jan 2020 10:27:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128849#128849</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? : Conceptually it&#226;&#8364;&#8482;s a similar...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128847#128847</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 10:07am<br /><br />Conceptually it’s a similar issue but in practice it’s worse than the 50 to 30 dog bone because with the 30A you are feeding your loads through the rpod distribution panel and its circuit breakers, while with the 50 to 15a dogbone you’re going straight to your loads with no overcurrent protection at all other than the 50a breaker at the pedestal. Personally though, I won’t use either dog bone.  <br /><br />The autotransformer provides protection from voltage surges but doesn’t provide overcurrent protection. Only a circuit breaker or fuse does that. ]]>
   <pubDate>Tue, 14 Jan 2020 10:07:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128847#128847</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? :   Originally posted by offgridYes,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128846#128846</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 9:49am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />Yes, one big downside. There is no overcurrent protection on that thing. The only thing limiting current flow is the 50A breaker at the pedestal. So, in the event of an electrical fault, up to 50A can get fed into anything connected to it, with nothing to prevent an electrical fire. IMHO that connector is an accident waiting to happen.</td></tr></table><div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div>Is that any different than using a 50-amp to 30-amp dogbone, which I understand many people do?</div><div><br></div><div>FWIW, I do use this Hughes 30-amp autoformer:</div><div><br></div><div><a href="https://hughesauto&#102;ormers.com/product/30-amp-3600-watt-booster-with-surge/" target="_blank">https://hughesautoformers.com/product/30-amp-3600-watt-booster-with-surge/</a></div><div><br></div><div><i><span style="color: rgb51, 51, 51; font-family: Helvetica, Arial, sans-serif; font-size: 14px;">The&nbsp;</span><str&#111;ng style="-sizing: border-; margin: 0px; padding: 0px; outline: 0px; color: rgb51, 51, 51; font-family: Helvetica, Arial, sans-serif; font-size: 14px;">all new</strong><span style="color: rgb51, 51, 51; font-family: Helvetica, Arial, sans-serif; font-size: 14px;">&nbsp;Hughes Autoformer 30 amp power boosting autoformer (RV2130SP) has the same performance and reliability of the RV2130 but now has advanced surge protection built in! The unit offers 2,400 Joules of surge protection. As an added feature, the surge / spike protection module is also&nbsp;</span><str&#111;ng style="-sizing: border-; margin: 0px; padding: 0px; outline: 0px; color: rgb51, 51, 51; font-family: Helvetica, Arial, sans-serif; font-size: 14px;">replaceable</strong><span style="color: rgb51, 51, 51; font-family: Helvetica, Arial, sans-serif; font-size: 14px;">. In the event of a massive spike, the surge unit will take the hit ensuring your booster and more importantly, your RV is not damaged.</span></i></div>]]>
   <pubDate>Tue, 14 Jan 2020 09:49:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128846#128846</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? : Yes, one big downside. There is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128841#128841</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 14 Jan 2020 at 7:26am<br /><br />Yes, one big downside. There is no overcurrent protection on that thing. The only thing limiting current flow is the 50A breaker at the pedestal. So, in the event of an electrical fault, up to 50A can get fed into anything connected to it, with nothing to prevent an electrical fire. IMHO that connector is an accident waiting to happen. ]]>
   <pubDate>Tue, 14 Jan 2020 07:26:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128841#128841</guid>
   <title>50A to 30A and 20A Y-adapter...any downsides? :  So in light of our 195&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128837#128837</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13350<br /><strong>Posted:</strong> 13 Jan 2020 at 3:53pm<br /><br />So in light of our 195's 12-Amp Inverter breaker (which affects all 120V outlets) I'm considering getting one of these:<div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div><a href="https://www.amaz&#111;n.com/C&#111;nntek-14963-14-50P-TT-30R-Y-Adapter/dp/B002MGSNNQ" target="_blank">https://www.amazon.com/Conntek-14963-14-50P-TT-30R-Y-Adapter/dp/B002MGSNNQ</a></div><div><br></div><div>It's a Y adapter that plugs in to a 50-amp outlet and supplies both 30 amp and 20-amp female connections.&nbsp; The 195 would plug in to the 30-amp outlet and I could run an extension cord off of the 20-amp outlet and power a space heater (or whatever) when necessary. Reviews seem to support such a use, e.g.,&nbsp;</div><div><br></div><div><span style="color: rgb17, 17, 17; font-family: &quot;Amaz&#111;n Ember&quot;, Arial, sans-serif; font-size: 13px;"><i>Perfect for my RV needs, unable to find at any dealer. Allows me to run my 30 amp RV service and a separate heavy duty line for my after market electric fireplace. Meets some campground "rules" of only using one receptacle per RV space. Massive heavy duty cord, pictures do not do it justice!</i></span></div><div><span style="color: rgb17, 17, 17; font-family: &quot;Amaz&#111;n Ember&quot;, Arial, sans-serif; font-size: 13px;"><i><br></i></span></div><div><span style="color: rgb17, 17, 17; font-family: &quot;Amaz&#111;n Ember&quot;, Arial, sans-serif; font-size: 13px;">Thoughts?</span></div>]]>
   <pubDate>Mon, 13 Jan 2020 15:53:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13350&amp;PID=128837#128837</guid>
