  <title>R-pod Owners Forum : Wardrobe dimensions</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Wardrobe dimensions</description>
  <pubDate>Sat, 24 Oct 2026 03:44:56 +0000</pubDate>
  <lastBuildDate>Wed, 08 Jan 2020 11:02:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13342</WebWizForums:feedURL>
   <title>Wardrobe dimensions : Here&amp;#039;s a link to what we...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13342&amp;PID=128778#128778</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13342<br /><strong>Posted:</strong> 08 Jan 2020 at 11:02am<br /><br /><a href="http://www.rpod-owners.com/forum_posts.asp?TID=13170&amp;KW=shelves&amp;PID=127088&amp;title=rp179-wardrobe-shelves#127088" target="_blank">Here's a link </a>to what we did. The shelving unit we got from Home Depot was "almost" perfect except as I noted in that post.]]>
   <pubDate>Wed, 08 Jan 2020 11:02:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13342&amp;PID=128778#128778</guid>
   <title>Wardrobe dimensions : I can&amp;#039;t help with specific...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13342&amp;PID=128767#128767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 13342<br /><strong>Posted:</strong> 07 Jan 2020 at 5:42pm<br /><br /><div>I can't help with specific dimensions as my pod is also stored for the winter. However, I can offer some suggestions and pictures as to the way that we added shelves to our 179.<br></div><div>I used standard 12" wire shelving available&nbsp; at Lowe's/Home Depot. I cut each piece to the proper length in order to fit front to back.&nbsp; I added a piece of wood ripped from a 2x4 that was the correct width to make up the difference in width side to side-as I recall, it was somewhere around 1" difference-make it a tight fit.&nbsp; I stapeled this wood piece to the edge of the wire shelves using many heavy duty staples through the wire edge. There are solid 3/4"x3/4" supports in each corner of the wardrobe cabinet.&nbsp; I screwed into these corners to support the shelves. I made "pegs" from used 1/4" copper tubing as a hollow peg and used a long screw through the copper tubing to support each corner of the shelves. The shelves sit on the tubing/screw posts in each corner. Here are some pictures</div><div><a href="https://postimg.cc/FkV1rBx9" target="_blank"><img src="https://i.postimg.cc/qq9KLfhC/IMG-0541-clothes-shelves-Large.jpg" border="0" /></a></div><div><a href="https://postimg.cc/bDyq09cJ" target="_blank"><img src="https://i.postimg.cc/4dtngWWz/IMG-0559-wardrobe-door-pocket-Large.jpg" border="0" /></a></div><div>I hope this helps</div><div>Vann<br></div>]]>
   <pubDate>Tue, 07 Jan 2020 17:42:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13342&amp;PID=128767#128767</guid>
   <title>Wardrobe dimensions : Can someone provide the internal...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13342&amp;PID=128765#128765</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9054" rel="nofollow">rpodamuck</a><br /><strong>Subject:</strong> 13342<br /><strong>Posted:</strong> 07 Jan 2020 at 3:03pm<br /><br />Can someone provide the internal width and depth of the wardrobe closet for a RPOD 179?<div><br></div><div>My trailer is not accessible and want to build shelves.</div><div><br></div><div>Thanks!</div>]]>
   <pubDate>Tue, 07 Jan 2020 15:03:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13342&amp;PID=128765#128765</guid>
