  <title>R-pod Owners Forum : Loss of power w battery</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Loss of power w battery</description>
  <pubDate>Thu, 24 Sep 2026 00:45:32 +0000</pubDate>
  <lastBuildDate>Sat, 01 Feb 2020 11:18:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13278</WebWizForums:feedURL>
   <title>Loss of power w battery : Yeah I decided since I just got...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129095#129095</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9992" rel="nofollow">Wirat</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 11:18am<br /><br />Yeah I decided since I just got this camper and am not too familiar with it yet, I'm just going to install one of those basic dis-connect under the battery box cover (if it fits). I'm mostly concerned about the battery going dead while in storage. As time goes on and I learn more about the rig I will venture in to something more substantial maybe mounted inside by the door (like there should be). -W<div><br></div>]]>
   <pubDate>Sat, 01 Feb 2020 11:18:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129095#129095</guid>
   <title>Loss of power w battery :   Originally posted by Jimmy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129093#129093</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 8:59am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Jimmy G</strong></em><br /><br />I’m sure it’s just a flipped switch, but with just battery(2) power,  the only thing that operates is the awning.  I need shore power to operate everything else.&nbsp;&nbsp;&nbsp;Is there some type of power cutoff switch on the vehicle.</td></tr></table><div><br></div><div>I'm sure you know this but , The radio, lights, heater, water pump, slide out, power jack, and brakes all work on battery power, as well as the awning.&nbsp; I used to remove my battery when I stored it elsewhere. If I needed power for any reason, I would just plug into my tow vehicle. But now I keep home and plug into an outside 15 amp receptacle. I had dropped my 195 off for some service last October, and it sat on their lot for a month. I was very surprised to see the battery level was still fine. Maybe if you bring one of those mobile battery jumper units down every 4-5 weeks and give it a small charge it would be fine?</div>]]>
   <pubDate>Sat, 01 Feb 2020 08:59:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129093#129093</guid>
   <title>Loss of power w battery : If the battery is in a case, especially...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129088#129088</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 7:48am<br /><br />If the battery is in a case, especially if the case is locked down, a cut-off switch is much more convenient. Disconnecting is cheaper, but less convenient. It is a matter of choice.]]>
   <pubDate>Sat, 01 Feb 2020 07:48:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129088#129088</guid>
   <title>Loss of power w battery :   Originally posted by WiratThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129087#129087</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7667" rel="nofollow">Olddawgsrule</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 7:41am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Wirat</strong></em><br /><br />Thanks for the quick reply! I will be definitely be adding one as I have to store this on a dry lot for the time being and don't want battery draining dead.</td></tr></table><div><br></div><div>Or just dis-connect it..&nbsp;</div>]]>
   <pubDate>Sat, 01 Feb 2020 07:41:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129087#129087</guid>
   <title>Loss of power w battery : Thanks for the quick reply! I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129085#129085</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9992" rel="nofollow">Wirat</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 5:53am<br /><br />Thanks for the quick reply! I will be definitely be adding one as I have to store this on a dry lot for the time being and don't want battery draining dead.]]>
   <pubDate>Sat, 01 Feb 2020 05:53:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129085#129085</guid>
   <title>Loss of power w battery : Short answer: No. I installed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129083#129083</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 5:41am<br /><br />Short answer: No. I installed one myself. See my mods for the old PB-Acid installation and the newest version for the new LiFePO4 battery installation.]]>
   <pubDate>Sat, 01 Feb 2020 05:41:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129083#129083</guid>
   <title>Loss of power w battery : I have the same question regarding...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129082#129082</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9992" rel="nofollow">Wirat</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 01 Feb 2020 at 5:08am<br /><br />I have the same question regarding the 12V cutoff switch. We just bought a used 2019 R-Pod 191 and I noticed the lights from the radio and USB port still on. I searched around for a main 12V cutoff switch to prevent the battery from draining and could not find one. Do R-Pods not come with a main power cutoff?]]>
   <pubDate>Sat, 01 Feb 2020 05:08:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=129082#129082</guid>
   <title>Loss of power w battery : Your lights, pumps, fans, etc...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=128161#128161</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 13 Nov 2019 at 11:07am<br /><br /><div>Your lights, pumps, fans, etc all work on 12v. The only thing you need shore power for is a/c, microwave, and possibly TV. If none of the 12v stuff is working on battery, then it's a fuse or wiring problem.</div><div><br></div>]]>
   <pubDate>Wed, 13 Nov 2019 11:07:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=128161#128161</guid>
   <title>Loss of power w battery : The vehicle in question is a 2020...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=128159#128159</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9895" rel="nofollow">Jimmy G</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 13 Nov 2019 at 10:26am<br /><br />The vehicle in question is a 2020 195 RPod]]>
   <pubDate>Wed, 13 Nov 2019 10:26:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=128159#128159</guid>
   <title>Loss of power w battery : I&#226;&#8364;&#8482;m sure it&#226;&#8364;&#8482;s just a flipped...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=128152#128152</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9895" rel="nofollow">Jimmy G</a><br /><strong>Subject:</strong> 13278<br /><strong>Posted:</strong> 13 Nov 2019 at 9:37am<br /><br />I’m sure it’s just a flipped switch, but with just battery(2) power,  the only thing that operates is the awning.  I need shore power to operate everything else.&nbsp;&nbsp;&nbsp;Is there some type of power cutoff switch on the vehicle. ]]>
   <pubDate>Wed, 13 Nov 2019 09:37:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13278&amp;PID=128152#128152</guid>
