  <title>R-pod Owners Forum : New R-pod’s 7-pin connector won’t fit</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : New R-pod’s 7-pin connector won’t fit</description>
  <pubDate>Sat, 24 Oct 2026 03:15:47 +0000</pubDate>
  <lastBuildDate>Sat, 09 Nov 2019 07:21:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13269</WebWizForums:feedURL>
   <title>New R-pod’s 7-pin connector won’t fit :   Originally posted by AtulYes,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128055#128055</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7667" rel="nofollow">Olddawgsrule</a><br /><strong>Subject:</strong> 13269<br /><strong>Posted:</strong> 09 Nov 2019 at 7:21am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Atul</strong></em><br /><br />Yes, its app on my iPhone did that pairing rather easily. However the problem is physical connection. In any case, the dealer has now replaced the connector cable to a compatible one. So hopefully the problem has been solved.&nbsp;</td></tr></table><div><br></div><div>Very good!&nbsp;</div>]]>
   <pubDate>Sat, 09 Nov 2019 07:21:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128055#128055</guid>
   <title>New R-pod’s 7-pin connector won’t fit : Yes, its app on my iPhone did...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128052#128052</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9888" rel="nofollow">Atul</a><br /><strong>Subject:</strong> 13269<br /><strong>Posted:</strong> 08 Nov 2019 at 8:30pm<br /><br />Yes, its app on my iPhone did that pairing rather easily. However the problem is physical connection. In any case, the dealer has now replaced the connector cable to a compatible one. So hopefully the problem has been solved.&nbsp;]]>
   <pubDate>Fri, 08 Nov 2019 20:30:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128052#128052</guid>
   <title>New R-pod’s 7-pin connector won’t fit : Don&amp;#039;t have one, but did you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128037#128037</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7667" rel="nofollow">Olddawgsrule</a><br /><strong>Subject:</strong> 13269<br /><strong>Posted:</strong> 08 Nov 2019 at 10:05am<br /><br />Don't have one, but did you get to pairing mode? Curious if it's running at all?]]>
   <pubDate>Fri, 08 Nov 2019 10:05:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128037#128037</guid>
   <title>New R-pod’s 7-pin connector won’t fit : Hi all,I have bought a new 2020...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128035#128035</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9888" rel="nofollow">Atul</a><br /><strong>Subject:</strong> 13269<br /><strong>Posted:</strong> 08 Nov 2019 at 8:58am<br /><br /><div><span style="-webkit-text-size-adjust: auto; : rgb251, 251, 253;">Hi all,</span></div><div><span style="-webkit-text-size-adjust: auto; : rgb251, 251, 253;"><br></span></div><span style="-webkit-text-size-adjust: auto; : rgb251, 251, 253;">I have bought a new 2020 R-pod 190, but while taking delivery last night, I ran into a problem with its 7-pin connector.&nbsp;</span><div><span style="-webkit-text-size-adjust: auto; : rgb251, 251, 253;"><br></span></div><div><span style="-webkit-text-size-adjust: auto; : rgb251, 251, 253;">The problem is that the R-pod’s connector did not fit into my tow vehicle’s CURT Bluetooth brake controller. &nbsp;The connector just did not go fully in, and did not latch in.&nbsp;</span><div style="-webkit-text-size-adjust: auto;"><br></div><div style="-webkit-text-size-adjust: auto;">The brake controller itself seems to be ok. &nbsp;Earlier I have used the same brake controller with a 2018 R-pod 182g without a problem. &nbsp;Another RV’s connector also did fit into the brake controller. However, the connector of none of the R-pods on the lot fit into it.&nbsp;<span style=": rgb251, 251, 253;">The tech from dealership tried multiple times.&nbsp;</span>So the problem seems to be specific to Rpod.</div><div style="-webkit-text-size-adjust: auto;"><br></div><div style="-webkit-text-size-adjust: auto;">Has anyone else noticed this problem with 2020 model’s connectors?</div><div style="-webkit-text-size-adjust: auto;"><br></div><div style="-webkit-text-size-adjust: auto;">Thanks,</div><div style="-webkit-text-size-adjust: auto;"><br></div><div style="-webkit-text-size-adjust: auto;">- Atul</div><div style="-webkit-text-size-adjust: auto;"><br></div><div style="-webkit-text-size-adjust: auto;"><br></div></div>]]>
   <pubDate>Fri, 08 Nov 2019 08:58:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13269&amp;PID=128035#128035</guid>
