  <title>R-pod Owners Forum : De winterizing</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : De winterizing</description>
  <pubDate>Sat, 24 Oct 2026 03:39:20 +0000</pubDate>
  <lastBuildDate>Tue, 05 Nov 2019 10:43:01 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13264</WebWizForums:feedURL>
   <title>De winterizing : Thanks for the help. I think next...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127996#127996</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9810" rel="nofollow">Jarhead</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 05 Nov 2019 at 10:43am<br /><br />Thanks for the help. I think next time I’ll just use air]]>
   <pubDate>Tue, 05 Nov 2019 10:43:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127996#127996</guid>
   <title>De winterizing : The &amp;#034;Blow out&amp;#034; method...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127992#127992</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8642" rel="nofollow">Woodmiester</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 05 Nov 2019 at 8:08am<br /><br />The "Blow out" method works very well! &nbsp;It doesnt matter if there is a small amount of water or moisture in the lines, as long as it can freely expand as it freezes. &nbsp;You run into problems when the lines are full of water then freezes and the expanding ice has nowhere to go except through the lines or fittings. &nbsp;<div>One thing: &nbsp;when using this method, don't forget your toilet and any outside water outlets!</div>]]>
   <pubDate>Tue, 05 Nov 2019 08:08:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127992#127992</guid>
   <title>De winterizing :   Originally posted by JarheadGotcha....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127989#127989</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 05 Nov 2019 at 7:23am<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Jarhead</strong></em><br /><br />Gotcha.  So as long as I close the hot and cold to the heater  I can leave the middle cne alone right ?</td></tr></table> <br></div><div><br></div><div>NO.. you have to use the middle one. It is part of the "bypass circuit" <br></div><div><br></div><div>At this time your top and bottom valves should be closed, AND, the middle valve should be open, allowing the anti freeze to flow around, or bypassing, the WH. <br></div><div><br></div><div>When you want to use the WH come spring, you have to open the top and bottom valves to allow water to flow into and through the WH. <br></div><div>If you do not close the center valve, some water will still bypass the WH.. Cold water. Unheated water. Unhappy to hit you in the shower water... <br></div><div><br></div>]]>
   <pubDate>Tue, 05 Nov 2019 07:23:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127989#127989</guid>
   <title>De winterizing : Can&amp;#039;t say for other configurations,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127988#127988</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 05 Nov 2019 at 6:50am<br /><br />Can't say for other configurations, but on our older 172, when we winterize there are 3 valves that have to be opened/closed; two bypass valves are turned to keep the water out of the water heater and the middle one opened so the cold water can get into the hot water pipes. &nbsp;When you winterize with antifreeze the idea is to fill all the waterlines and valves with the antifreeze solution, but not the water heater. &nbsp;There is also a valve where the water pump is that needs to be turned to allow the pump to draw the antifreeze that you need to turn back when done.<div><br></div><div>When you want to de-winterize, the idea is to thoroughly flush out all the antifreeze with fresh water. &nbsp;To do that, you don't change the valve settings. &nbsp;Once flushed, then you can go back and change the valves to allow water to flow through the water heater, including the middle valve.</div><div><br></div><div>Personally, I've never tried the blow it out method. &nbsp;The antifreeze method is easy and the antifreeze solution is cheap, so I take the path of least resistance and have the confidence I've gotten enough of the water out and replaced with antifreeze to be sure nothing will freeze. &nbsp;Many people really like the blow out method and have had good success with it. &nbsp;I worry about not getting all the water out of things like toilet valves and don't to have to replace something like that b/c it had enough water left in it to crack it when the system froze. &nbsp;But my worry is probably misplaced. &nbsp;</div>]]>
   <pubDate>Tue, 05 Nov 2019 06:50:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127988#127988</guid>
   <title>De winterizing : Gotcha.  So as long as I close...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127986#127986</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9810" rel="nofollow">Jarhead</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 04 Nov 2019 at 10:42pm<br /><br />Gotcha.  So as long as I close the hot and cold to the heater  I can leave the middle cne alone right ?]]>
   <pubDate>Mon, 04 Nov 2019 22:42:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127986#127986</guid>
   <title>De winterizing : The in and out valves stop water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127985#127985</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 04 Nov 2019 at 10:04pm<br /><br /><div>The in and out valves stop water getting in the water heater.&nbsp; The one in the middle let the water go from the cold side to the hot side (and all of your faucets) without going through the water heater.&nbsp; If you don't close the in and out valves water will still get into the water heater, although some won't.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Mon, 04 Nov 2019 22:04:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127985#127985</guid>
   <title>De winterizing : Also I noticed the hot water heater...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127984#127984</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9810" rel="nofollow">Jarhead</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 04 Nov 2019 at 7:36pm<br /><br />Also I noticed the hot water heater has a shut off at both the hot and cold,(top and bottom of the tank) And then another one as well is this a by-pass.  What’s it purpose?]]>
   <pubDate>Mon, 04 Nov 2019 19:36:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127984#127984</guid>
   <title>De winterizing : Right, keep the HW bypassed until...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127983#127983</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 04 Nov 2019 at 7:23pm<br /><br /><div>Right, keep the HW bypassed until you flush your pink antifreeze out.&nbsp; I did it that way the first year of ownership on a 177 back in 2011.&nbsp; Was really frustrated about the nasty taste in the lines the following spring, took a few tries of lemon juice, white cider vinegar and baking soda sitting in the lines for about a week to get rid of the 'flavor' left from the antifreeze.&nbsp; Many people don't drink from their FW tanks so this isn't an issue but for us who do, it was a big problem, especially for those of us who have great tasting well water.&nbsp; I have a hard time drinking bottled water, to me it tastes weird.&nbsp; However when in third world countries there are no other options except to get really, really sick.</div><div><br></div><div>Since that first year doing it the traditional way using antifreeze in the lines we have opted to use pressurized air to blow out all lines and then use a total of 16 oz. RV antifreeze for our 3 traps (2 sink, 1 shower) and a little for the toilet to keep the seal moist.&nbsp; Live in northern Michigan and get some really cold weather, no issues or leaks in the last 7 years.<br></div>]]>
   <pubDate>Mon, 04 Nov 2019 19:23:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127983#127983</guid>
   <title>De winterizing : i winterizing using pink stuff...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127982#127982</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9810" rel="nofollow">Jarhead</a><br /><strong>Subject:</strong> 13264<br /><strong>Posted:</strong> 04 Nov 2019 at 6:09pm<br /><br />i winterizing using pink stuff by passing water heater and pumping it into lines via water pump.  When I go to de winterize I will won’t to keep the hot water heater by passed until I flush the pink stuff out of the lines correct?]]>
   <pubDate>Mon, 04 Nov 2019 18:09:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13264&amp;PID=127982#127982</guid>
