  <title>R-pod Owners Forum : Hole in the side</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Hole in the side</description>
  <pubDate>Fri, 23 Oct 2026 08:55:35 +0000</pubDate>
  <lastBuildDate>Fri, 30 Aug 2019 06:58:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13145</WebWizForums:feedURL>
   <title>Hole in the side : It depends on where the hole is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13145&amp;PID=126844#126844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 13145<br /><strong>Posted:</strong> 30 Aug 2019 at 6:58am<br /><br /><div>It depends on where the hole is located.&nbsp; I have a nice hole in our pod's front metal rock guard.&nbsp; I had leaned one of the wdh bars against the a frame.&nbsp; when I lowered the tongue jack the bar punched a perfect square hole in the front. the metal rock guard is black.&nbsp; I cut a metal square&nbsp; approximately 3"x3", painted it black and screwed it over the hole after a liberal application of silicone.&nbsp; It looks like an access panel or cover that was meant to be there originally. No one but me(and my wife) ever knows.<br></div><div>Vann<br></div>]]>
   <pubDate>Fri, 30 Aug 2019 06:58:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13145&amp;PID=126844#126844</guid>
   <title>Hole in the side : It wasn&amp;#039;t hypothetical for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13145&amp;PID=126838#126838</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13145<br /><strong>Posted:</strong> 29 Aug 2019 at 9:51pm<br /><br />It wasn't hypothetical for me. I used a bit of silicone and a plastic plug that was about the same color to plug the hole. It lasted until the side was replaced at the factory with a new one after it had to go there for repairs after an accident. It was a reminder to double-check and make sure I do not use anchors that are too long.]]>
   <pubDate>Thu, 29 Aug 2019 21:51:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13145&amp;PID=126838#126838</guid>
   <title>Hole in the side : Let&amp;#039;s just say, maybe hypothetically,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13145&amp;PID=126830#126830</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7296" rel="nofollow">176turbodiesel</a><br /><strong>Subject:</strong> 13145<br /><strong>Posted:</strong> 29 Aug 2019 at 6:51pm<br /><br />Let's just say, maybe hypothetically, I put a hole through the inside of the camper and it came out the other side. How do you patch the outside of an rpod? Bondo? ]]>
   <pubDate>Thu, 29 Aug 2019 18:51:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13145&amp;PID=126830#126830</guid>
