  <title>R-pod Owners Forum : Wdh suggestions</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Wdh suggestions</description>
  <pubDate>Sat, 24 Oct 2026 00:27:33 +0000</pubDate>
  <lastBuildDate>Sun, 18 Aug 2019 23:25:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13068</WebWizForums:feedURL>
   <title>Wdh suggestions : I too use a Fastway e2-600 lbs...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126561#126561</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 18 Aug 2019 at 11:25pm<br /><br />I too use a Fastway e2-600 lbs tongue weight square bar(which might be a bit overkill) with towing with my Tacoma truck and have been very pleased with it's performance. The key to setting it up is to get the trailer and truck level.<br>]]>
   <pubDate>Sun, 18 Aug 2019 23:25:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126561#126561</guid>
   <title>Wdh suggestions : I like my Equalizer. It works...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126550#126550</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8361" rel="nofollow">OldNeumanntapr</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 16 Aug 2019 at 11:38pm<br /><br />I like my Equalizer. It works well with my 2011 Tacoma and 2018 rPod 180.<br />Night and day difference from the standard ball hitch.]]>
   <pubDate>Fri, 16 Aug 2019 23:38:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126550#126550</guid>
   <title>Wdh suggestions : Well guys I finally fixed the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126548#126548</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 16 Aug 2019 at 9:48pm<br /><br />Well guys I finally fixed the WDH. The hitch was not adjusted right. Set back too far. I added a Reese antis way bar and it is perfect now. Thanks for the help]]>
   <pubDate>Fri, 16 Aug 2019 21:48:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126548#126548</guid>
   <title>Wdh suggestions :  Originally posted by GlueGuy  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126075#126075</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 31 Jul 2019 at 5:03pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by GlueGuy</strong></em><br /><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Babysaph</strong></em><br /><br />I ama newbie and need help for a wdh with sway control towing an Rpod 189 with my Toyota Tacoma. </td></tr></table>The Fastway <a href="https://www.etrailer.com/Weight-Distributi&#111;n/Fastway/FA94-00-0600.html" target="_blank">E2-600</a> is a good choice. This is the "round bar" version.<div></div><div>It also comes in a <a href="https://www.etrailer.com/Weight-Distributi&#111;n/Fastway/FA92-00-0600.html" target="_blank">trunnion style</a>, which is a little more expensive.</div><div></div><div>We have the round bar, and it works great.</div></td></tr></table> <br /><br />Ditto.]]>
   <pubDate>Wed, 31 Jul 2019 17:03:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126075#126075</guid>
   <title>Wdh suggestions :  Originally posted by mcarterThat...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126056#126056</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 30 Jul 2019 at 9:22pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mcarter</strong></em><br /><br />That seems low. My 178, not overloaded is at 380.</td></tr></table><div><br></div><div>+1.&nbsp;</div><div><br></div><div>279 is basically the same as the 281 lbs listed as tongue weight on the FR website for the 189. That number would be for a dry trailer, no water in any tanks or in the water heater, no battery, and nothing in the trailer at all.&nbsp; Its hard to see how that could be the actual tongue weight of a loaded trailer unless maybe the gray water tank was full or there was some other really heavy stuff loaded aft of the axle?&nbsp;</div><div><br></div><div>If that number is right then its understandable that you have sway as the empty weight of a 189 without any options , batteries, water, or other stuff is listed as 2792. A/C, battery, and water in the water heater alone are going to add a couple hundred lbs, so you would be about 9% tongue weight or less.&nbsp;</div>]]>
   <pubDate>Tue, 30 Jul 2019 21:22:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126056#126056</guid>
   <title>Wdh suggestions : May be low but that is what Forest...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126055#126055</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 30 Jul 2019 at 9:07pm<br /><br />May be low but that is what Forest River says it weighs. Seems to me if I'm weighing what I put in the trailer that would change fron trip to trip.&nbsp;]]>
   <pubDate>Tue, 30 Jul 2019 21:07:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126055#126055</guid>
   <title>Wdh suggestions : That seems low.  My 178, not overloaded...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126045#126045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 30 Jul 2019 at 4:01pm<br /><br />That seems low.  My 178, not overloaded is at 380.]]>
   <pubDate>Tue, 30 Jul 2019 16:01:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126045#126045</guid>
   <title>Wdh suggestions :    Originally posted by BabysaphMy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126039#126039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 30 Jul 2019 at 2:39pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Babysaph</strong></em><br /><br />My tongue weight for my trailer is 279 lbs. I guess I need 400</td></tr></table> Is that calculated or measured?&nbsp;<div><br></div><div>What is the full-up weight of the trailer? Multiply that by 0.11 to get an idea what it should be.</div><div><br></div><div>For example, for a gross trailer weight of 3850, the tongue should be "around" 423 lbs.</div>]]>
   <pubDate>Tue, 30 Jul 2019 14:39:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126039#126039</guid>
   <title>Wdh suggestions : My tongue weight for my trailer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126038#126038</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 30 Jul 2019 at 2:34pm<br /><br />My tongue weight for my trailer is 279 lbs. I guess I need 400]]>
   <pubDate>Tue, 30 Jul 2019 14:34:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126038#126038</guid>
   <title>Wdh suggestions : Greetings:Do a little research...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126024#126024</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8314" rel="nofollow">crankster78</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 30 Jul 2019 at 9:07am<br /><br /><div>Greetings:</div><div>Do a little research online.&nbsp; WDH come in several configurations.&nbsp; The torsion bar type using chains require you to disconnect the bars before backing up, and are priced a little lower.&nbsp; Other types use bars that slide back and forth or like my EAZ-LIFT Recurve R3 has a hitch that swivels.&nbsp; They all work, I liked this design the best. &nbsp;</div><div><br></div><div>Crankster78&nbsp; R-179</div>]]>
   <pubDate>Tue, 30 Jul 2019 09:07:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126024#126024</guid>
   <title>Wdh suggestions : Thanks buddy </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126019#126019</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 29 Jul 2019 at 9:56pm<br /><br />Thanks buddy]]>
   <pubDate>Mon, 29 Jul 2019 21:56:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126019#126019</guid>
   <title>Wdh suggestions :   Originally posted by BabysaphI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126016#126016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 29 Jul 2019 at 9:03pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Babysaph</strong></em><br /><br />I ama newbie and need help for a wdh with sway control towing an Rpod 189 with my Toyota Tacoma.&nbsp;</td></tr></table>The Fastway <a href="https://www.etrailer.com/Weight-Distributi&#111;n/Fastway/FA94-00-0600.html" target="_blank">E2-600</a> is a good choice. This is the "round bar" version.<div><br></div><div>It also comes in a <a href="https://www.etrailer.com/Weight-Distributi&#111;n/Fastway/FA92-00-0600.html" target="_blank">trunnion style</a>, which is a little more expensive.</div><div><br></div><div>We have the round bar, and it works great.</div>]]>
   <pubDate>Mon, 29 Jul 2019 21:03:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126016#126016</guid>
   <title>Wdh suggestions : What kind and size? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126015#126015</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 29 Jul 2019 at 9:02pm<br /><br />What kind and size?]]>
   <pubDate>Mon, 29 Jul 2019 21:02:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126015#126015</guid>
   <title>Wdh suggestions : +1 to crankster78 </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126010#126010</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 29 Jul 2019 at 6:41pm<br /><br />+1 to crankster78]]>
   <pubDate>Mon, 29 Jul 2019 18:41:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126010#126010</guid>
   <title>Wdh suggestions : Greetings;Buy a Weight distributing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126009#126009</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8314" rel="nofollow">crankster78</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 29 Jul 2019 at 6:30pm<br /><br /><div>Greetings;</div><div>Buy a Weight distributing hitch with sway control.&nbsp; It's worth the investment. &nbsp;</div><div><br></div><div>Crankster78 R-179</div>]]>
   <pubDate>Mon, 29 Jul 2019 18:30:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126009#126009</guid>
   <title>Wdh suggestions : I ama newbie and need help for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126007#126007</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13068<br /><strong>Posted:</strong> 29 Jul 2019 at 6:25pm<br /><br />I ama newbie and need help for a wdh with sway control towing an Rpod 189 with my Toyota Tacoma.&nbsp;]]>
   <pubDate>Mon, 29 Jul 2019 18:25:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13068&amp;PID=126007#126007</guid>
