  <title>R-pod Owners Forum : Fresh Water Tank Drain</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Fresh Water Tank Drain</description>
  <pubDate>Sat, 24 Oct 2026 00:28:43 +0000</pubDate>
  <lastBuildDate>Wed, 24 Jul 2019 11:24:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13045</WebWizForums:feedURL>
   <title>Fresh Water Tank Drain : Bueno! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125907#125907</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9056" rel="nofollow">Motor7</a><br /><strong>Subject:</strong> 13045<br /><strong>Posted:</strong> 24 Jul 2019 at 11:24am<br /><br />Bueno!]]>
   <pubDate>Wed, 24 Jul 2019 11:24:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125907#125907</guid>
   <title>Fresh Water Tank Drain : I pulled the drain plug and found...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125897#125897</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7485" rel="nofollow">NAP1947</a><br /><strong>Subject:</strong> 13045<br /><strong>Posted:</strong> 23 Jul 2019 at 3:49pm<br /><br />I pulled the drain plug and found that the screen filter for our garden watering system to be a snug fit resulting in a 2” screen riser above the floor of the tank. &nbsp;A touch of silicone seal to ensure the filter will work loose when bouncing down the road and the and the floater is no longer an issue.<div>Thanks.</div>]]>
   <pubDate>Tue, 23 Jul 2019 15:49:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125897#125897</guid>
   <title>Fresh Water Tank Drain : Great idea. Will see what I can...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125792#125792</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7485" rel="nofollow">NAP1947</a><br /><strong>Subject:</strong> 13045<br /><strong>Posted:</strong> 18 Jul 2019 at 7:09pm<br /><br />Great idea. &nbsp;Will see what I can do with that.<div>Cheers and thanks</div>]]>
   <pubDate>Thu, 18 Jul 2019 19:09:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125792#125792</guid>
   <title>Fresh Water Tank Drain : I&amp;#039;d leave it in there. Find...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125787#125787</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9056" rel="nofollow">Motor7</a><br /><strong>Subject:</strong> 13045<br /><strong>Posted:</strong> 18 Jul 2019 at 12:45pm<br /><br />I'd leave it in there. Find a section of PVC or pex pipe that fits snugly in the drain hole. Drill some holes in it then shove it into the drain hole while draining. That will keep that plastic disc from blocking the drain.Remove it when empty.]]>
   <pubDate>Thu, 18 Jul 2019 12:45:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125787#125787</guid>
   <title>Fresh Water Tank Drain : Been a while since I have needed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125761#125761</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7485" rel="nofollow">NAP1947</a><br /><strong>Subject:</strong> 13045<br /><strong>Posted:</strong> 17 Jul 2019 at 6:38pm<br /><br />Been a while since I have needed the boards expertise and I could not find the issue with a search.<div>We are enjoying the 179 immensely, had one 8000 Km trip and quite a few 2 &amp; 3 day trips closer to home.</div><div>I have what appears to be a hole cutout from the fresh water tank installation moving around in the tank and blocking the drain hole when trying to empty and/or clean the tank.</div><div>I can see it and feel it but it is too large to remove through the drain.</div><div>Looking for ideas before I drop the tank.</div><div>Thanks</div>]]>
   <pubDate>Wed, 17 Jul 2019 18:38:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13045&amp;PID=125761#125761</guid>
