  <title>R-pod Owners Forum : Power Tongue Jack</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Power Tongue Jack</description>
  <pubDate>Thu, 27 Aug 2026 17:13:25 +0000</pubDate>
  <lastBuildDate>Wed, 31 Jul 2019 23:07:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13020</WebWizForums:feedURL>
   <title>Power Tongue Jack : I had the same problem. I cleaned...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=126082#126082</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8109" rel="nofollow">Blender Bob</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 31 Jul 2019 at 11:07pm<br /><br />I had the same problem. I cleaned the contacts on the inline fuse and ensure the case was screwed tight to make a good contact. Problem went away. Seems to have enough power to run the light, but not the jack before I fiddled with it. I hate partial failure problems.&nbsp;]]>
   <pubDate>Wed, 31 Jul 2019 23:07:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=126082#126082</guid>
   <title>Power Tongue Jack : Just a little update on my Lippert...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=126067#126067</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 31 Jul 2019 at 1:06pm<br /><br /><div>Just a little update on my Lippert Power Tongue Jack problem. Ended up removing the jack head and testing the motor and found it was shot. Guess the little electric motor just doesn't like to take a bath. <img src="https://www.rpod-owners.com/smileys/smiley3.gif" border="0" alt="Shocked" title="Shocked" /><br></div><div>So on the day that we were scheduled to leave on our trip I was down at my local RV dealer when it opened to purchase a new power jack ($200 gone thank you!) and install it in record time. What a way to start a trip though I learned the hard and expensive way to buy a waterproof sock cover for the jack head or put a bucket over it!&nbsp;</div>]]>
   <pubDate>Wed, 31 Jul 2019 13:06:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=126067#126067</guid>
   <title>Power Tongue Jack : Strange. Have you tried hooking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125510#125510</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 08 Jul 2019 at 10:04pm<br /><br /><div>Strange.&nbsp; Have you tried hooking it straight to a battery now that it's off?&nbsp; Now I might suggest checking your ground connection.&nbsp; Grounds can be annoyingly elusive.&nbsp; But I suspect you might be right about the motor being shot.</div><div><br></div><div>A power jack is a convenience.&nbsp; You could get by with a small hydraulic bottle jack for your trip.&nbsp; Or, depending on how that 3/4" nut was attached, if you can replace it, you can use a 1/2" drill with a 3/4" socket to turn the jack.&nbsp; That's what I do with my ol' manual tongue jack.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Mon, 08 Jul 2019 22:04:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125510#125510</guid>
   <title>Power Tongue Jack : Okay, thanks everyone for the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125508#125508</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 08 Jul 2019 at 8:40pm<br /><br />Okay, thanks everyone for the suggestions on how to get this power jack working. After the emergency nut that you can turn shattered into little pieces I took it apart and lubricated everything yesterday and got it working. Lucky me hu? Tried it this morning and it still worked and I thought I had this problem licked. This evening I backed the TV in position to hook the trailer up to it and hit the the switch to extended it and it was DOA! I'm totally perplexed so I remove the top cover to the jack and with my vice grips worked it back and forth and it moves freely but still the jack won't budge a fraction of an inch when I hit the switch. I finally in desperation took the whole jack assembly apart and laid it out on my work bench to remove the motor and lubricate it. Replaced it all and still nothing which tells me the motor is shot! So I guess in the morning I'll be racing around like a chicken without a head to find a new power tongue jack so we can get on the road and make our first reserved campsite by tomorrow evening. Wish me luck, I'll need it and then some! &nbsp;]]>
   <pubDate>Mon, 08 Jul 2019 20:40:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125508#125508</guid>
   <title>Power Tongue Jack :   Originally posted by StephenHOkay,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125503#125503</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 08 Jul 2019 at 6:35pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br /><div>Okay, here is another possibility. There may be sufficient ground to allow the LED lights to turn on, but it may be insufficient to allow the motor to run.</td></tr></table></div><div>I thought of that but the fact that the jack couldn't be turned manually discounted it for me.&nbsp; But that's a good idea generally.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Mon, 08 Jul 2019 18:35:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125503#125503</guid>
   <title>Power Tongue Jack : Okay, here is another possibility....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125501#125501</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 08 Jul 2019 at 5:51pm<br /><br /><div>Okay, here is another possibility. There may be sufficient ground to allow the LED lights to turn on, but it may be insufficient to allow the motor to run. Loosen and re-tighten the bolts holding the jack to the frame (make sure it is supported and do one at a time. If it is a ground problem, then this should help. If it still does not work, then a mechanical problem is more likely the cause. Take your manual crank and try to turn it. Does it turn or is it seized?<br></div><div><br></div><div>My jack is not by Lippert, but I do keep a soft cover on it. Since it is soft, I can work the switches through the cover so I don't have to remove it.<br></div>]]>
   <pubDate>Mon, 08 Jul 2019 17:51:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125501#125501</guid>
   <title>Power Tongue Jack : We do not have an electric tongue...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125484#125484</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8192" rel="nofollow">1nana2many</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 08 Jul 2019 at 7:15am<br /><br />We do not have an electric tongue jack, however, I have noticed a couple pictures on the site where people have placed covers over their electric jack, much like the bag over the propane bottle. Perhaps this is the reason those covers were there. Something to consider anyway. I made a outdoor cloth cover for our propane bottle because I hated how cracked up the original equipment was looking after only one year. I used a 2 gallon bucket lid inside the doubled top circle to maintain the shape. Put grommets in the bottom edge so we could use hooks to keep it in place. Sprayed it with camp dry to improve water proofing. It’s fading a little, but doing the job. We put a generator rack over the top so didn’t want to have to lift hard plastic propane covers. Hinged the metal band that goes around the bottle so it doesn’t have to be lifted either.]]>
   <pubDate>Mon, 08 Jul 2019 07:15:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125484#125484</guid>
   <title>Power Tongue Jack : Sounds like things weren&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125481#125481</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 08 Jul 2019 at 1:45am<br /><br /><div>Sounds like things weren't olied/greased often enough and rusted up. <br></div><div><br></div><div>TT<br></div>]]>
   <pubDate>Mon, 08 Jul 2019 01:45:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125481#125481</guid>
   <title>Power Tongue Jack :   Okay Guys and Gals maybe someone...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125478#125478</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 13020<br /><strong>Posted:</strong> 07 Jul 2019 at 10:44pm<br /><br /><p ="Ms&#111;normal">Okay Guys and Gals maybe someone here can give me some helpon a Lippert Power Tongue Jack. I’ve tried the search function and have come upempty which I find strange because I can’t be the only one who has or ishaving trouble with the Lippert power jack. I’ve checked their website andfound zippo, nadda, no information on troubleshooting and repair. Lucky me hu?</p><p ="Ms&#111;normal">Here is my dilemma I got ready to pull the Pod out for amonth on the road today and when I hit the power on button the LED light lite goes onwhich tells me it’s getting power, good. Then I hit the extend switch andnothing, so hit the retract side of the switch and again nothing, not good! Wentahead and checked the fuse for grins and giggles and it is okay. So now Ifigure why not try the “emergency option” of cranking the jack down or up witha rachet and ¾ inch socket on the nut on the power jack top and it won’t budgea fraction of an inch. Hey, I’ll admit I’m not the strongest guy so I get outmy breaker bar and give it a pull and guess what the nut just breaks intolittle pieces and I’m like what the #*@!</p><p ="Ms&#111;normal">I then removed the jack’s plastic cover and get out my ohmmeter and checked all the switches and all is good. Hmmm, so I then removed thetop plate that goes over the gears and to my surprise find water in pockets ofthe castings. Cleaned the water out, sprayed switches with contact cleaner, andthe gears with penetrating oil and jacked up the tongue of the trailer with abottle jack. Then using vice grip plyers, I worked the shaft that the pot metal¾ inch nut once was on back and forth until it broke free and I could turn it.I put it all back together and finally the power jack started to work but intermittentlyand I had to use the vice grips on the gear shaft that the nut was once on a coupletimes. I kept on working the jack up and down and hopefully have the jackworking now that I won’t have to be dealing with this nightmare while on ourtrip. Knock on wood!<br></p><p ="Ms&#111;normal">My question has anyone else had the same trouble with theirLippert Power Tongue Jack? If so, what did you do to resolve the problem onceand for all? Or if you didn’t resolve the problem what brand jack did you buyto replace the defective one? I do know Lippert will be getting a call from metomorrow to tell them what a sorry design their jack is and especially making anemergency retraction or extension nut out of cheap pot metal! <br></p><p ="Ms&#111;normal">Grrrrr! <img src="https://www.rpod-owners.com/smileys/smiley10.gif" border="0" alt="Star" title="Star" /><br></p><!--if gte mso 9> <o:OfficeSettings>  <o:AllowPNG/> </o:OfficeSettings><!--><!--if gte mso 9> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:TrackMoves/>  <w:Trackatting/>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixed>false</w:IgnoreMixed>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:D&#111;notPromoteQF/>  <w:LidThemeOther>EN-US</w:LidThemeOther>  <w:LidThemeAsian>X-NONE</w:LidThemeAsian>  <w:LidThemeComplex>X-NONE</w:LidThemeComplex>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>   <w:SplitPgBreakAndark/>   <w:EnableKerning/>   <w:D&#111;ntFlipMirrorIndents/>   <w:OverrideTableStyleHps/>  </w:Compatibility>  <m:mathPr>   <m:mathFont m:val="Cambria Math"/>   <m:brkBin m:val="before"/>   <m:brkBinSub m:val="&amp;#45;-"/>   <m:smallFrac m:val="off"/>   <m:dispDef/>   <m:lMargin m:val="0"/>   <m:rMargin m:val="0"/>   <m:defJc m:val="centerGroup"/>   <m:wrapIndent m:val="1440"/>   <m:intLim m:val="subSup"/>   <m:naryLim m:val="undOvr"/>  </m:mathPr></w:Word><!--><!--if gte mso 9> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false"    DefSemi="false" DefQat="false" DefPriority="99"    LatentStyleCount="376">  <w:LsdExcepti&#111;n Locked="false" Priority="0" Qat="true" Name="Normal"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 9"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 9"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 9"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footnote text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="er"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footer"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index ing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="35" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="capti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="table of figures"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="envelope address"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="envelope return"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footnote reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="line number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="page number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="endnote reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="endnote text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="table of authorities"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="macro"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="toa ing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="10" Qat="true" Name="Title"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Closing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Signature"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Semi="true"     UnhideWhenUsed="true" Name="Default Paragraph Font"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Message er"/>  <w:LsdExcepti&#111;n Locked="false" Priority="11" Qat="true" Name="Subtitle"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Salutati&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Date"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text First Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text First Indent 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Note ing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Block Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Hyper"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="FollowedHyper"/>  <w:LsdExcepti&#111;n Locked="false" Priority="22" Qat="true" Name="Str&#111;ng"/>  <w:LsdExcepti&#111;n Locked="false" Priority="20" Qat="true" Name="Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Plain Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="E-mail Signature"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Top of "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Bottom of "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Web"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Acr&#111;nym"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Address"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Cite"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Code"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Definiti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Keyboard"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Preatted"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" le"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" r"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Variable"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Table"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n subject"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="No List"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table C&#111;ntemporary"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Elegant"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Professi&#111;nal"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Subtle 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Subtle 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Ballo&#111;n Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="Table Grid"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Theme"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" Name="Placeholder Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Qat="true" Name="No Spacing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" Name="Revisi&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Priority="34" Qat="true"     Name="List Paragraph"/>  <w:LsdExcepti&#111;n Locked="false" Priority="29" Qat="true" Name="Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="30" Qat="true"     Name="Intense Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="19" Qat="true"     Name="Subtle Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="21" Qat="true"     Name="Intense Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="31" Qat="true"     Name="Subtle Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="32" Qat="true"     Name="Intense Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="33" Qat="true" Name="Book Title"/>  <w:LsdExcepti&#111;n Locked="false" Priority="37" Semi="true"     UnhideWhenUsed="true" Name="Bibliography"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="TOC ing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="41" Name="Plain Table 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="42" Name="Plain Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="43" Name="Plain Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="44" Name="Plain Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="45" Name="Plain Table 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="40" Name="Grid Table Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46" Name="Grid Table 1 Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51" Name="Grid Table 6 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52" Name="Grid Table 7 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46" Name="List Table 1 Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51" Name="List Table 6 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52" Name="List Table 7 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Menti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Smart Hyper"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Hashtag"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Unresolved Menti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Smart "/> </w:LatentStyles><!--><!--if gte mso 10> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0in;	line-height:115%;	mso-pagination:widow-orphan;	font-size:11.0pt;	font-family:"Calibri",sans-serif;	mso-ascii-font-family:Calibri;	mso-ascii-theme-font:minor-latin;	mso-hansi-font-family:Calibri;	mso-hansi-theme-font:minor-latin;	mso-bidi-font-family:"Times New Roman";	mso-bidi-theme-font:minor-bidi;}<!-->]]>
   <pubDate>Sun, 07 Jul 2019 22:44:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13020&amp;PID=125478#125478</guid>
