  <title>R-pod Owners Forum : Sansui Television</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Sansui Television</description>
  <pubDate>Fri, 23 Oct 2026 23:45:17 +0000</pubDate>
  <lastBuildDate>Sun, 11 Aug 2019 08:39:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13019</WebWizForums:feedURL>
   <title>Sansui Television : I did connect the RV TV to another...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=126367#126367</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9336" rel="nofollow">MT19RANGER</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 11 Aug 2019 at 8:39am<br /><br />I did connect the RV TV to another antenna that is able to receive signals in a shop from another TV set up and it still couldn't find channels.&nbsp; I'll bring another flat screen TV into the RV and troubleshoot to see if it's the booster or the TV HD OTA tuner.&nbsp;&nbsp;]]>
   <pubDate>Sun, 11 Aug 2019 08:39:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=126367#126367</guid>
   <title>Sansui Television :   Originally posted by MT19RANGERMy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=126329#126329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 09 Aug 2019 at 6:20pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by MT19RANGER</strong></em><br /><br />My over the air channels stopped working after one weekend of use too.&nbsp; It programmed just fine w/ the booster on and found all the channels in the area, now it won't find a single one.&nbsp; I've tried another antenna too that works from another television in the shop and it still no longer finds channels.&nbsp; My HDMI input works great I've got a splitter going to my Dish and Roku so I'm using them for now.&nbsp; I figure it's just the cheap &lt;$150 television tuner that don't work and I'll take back to the dealer (4+ hours away here in Montana) and have them warranty it prior to the 1 year is up and if I find any other issues they can warranty them too.&nbsp; &nbsp;&nbsp;</td></tr></table> The antenna amplifier might be your issue.]]>
   <pubDate>Fri, 09 Aug 2019 18:20:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=126329#126329</guid>
   <title>Sansui Television : My over the air channels stopped...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=126323#126323</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9336" rel="nofollow">MT19RANGER</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 09 Aug 2019 at 3:39pm<br /><br />My over the air channels stopped working after one weekend of use too.&nbsp; It programmed just fine w/ the booster on and found all the channels in the area, now it won't find a single one.&nbsp; I've tried another antenna too that works from another television in the shop and it still no longer finds channels.&nbsp; My HDMI input works great I've got a splitter going to my Dish and Roku so I'm using them for now.&nbsp; I figure it's just the cheap &lt;$150 television tuner that don't work and I'll take back to the dealer (4+ hours away here in Montana) and have them warranty it prior to the 1 year is up and if I find any other issues they can warranty them too.&nbsp; &nbsp;&nbsp;]]>
   <pubDate>Fri, 09 Aug 2019 15:39:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=126323#126323</guid>
   <title>Sansui Television : There are 2 coaxial connection...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125480#125480</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9198" rel="nofollow">mdballou</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 08 Jul 2019 at 12:06am<br /><br />There are 2 coaxial connection on the wall to the left of the TV. 1 is the antenna, other goes to the outside of the camper. TV has only 1 connection. Switch the connection on the wall. ]]>
   <pubDate>Mon, 08 Jul 2019 00:06:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125480#125480</guid>
   <title>Sansui Television : Check the input source. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125477#125477</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7746" rel="nofollow">crw8sr</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 07 Jul 2019 at 9:58pm<br /><br />Check the input source.]]>
   <pubDate>Sun, 07 Jul 2019 21:58:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125477#125477</guid>
   <title>Sansui Television : It is possible that something...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125472#125472</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 07 Jul 2019 at 8:20pm<br /><br /><div>It is possible that something was not hooked up correctly, but first things first. I have not tried cable, but from my understanding, if you are connected to the cable input on the side of the RPod, you should not turn the antenna booster on. Check to make sure it is off. If there is a red light showing, it is on.</div><div>On the television, did you check to see that the source was set to scan cable channels or is it set to scan antenna channels? Double-check the input source on the television.</div><div><br></div><div>Also, it is possible that the cable is not working. Just because you have a wire connected does not mean that the wire is live with a signal. I'm not sure how you would verify that though.<br></div><div><br></div><div>Hopefully, someone else can provide more input. Those are the basics though.</div><div><br></div><div>Also, welcome! <br></div>]]>
   <pubDate>Sun, 07 Jul 2019 20:20:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125472#125472</guid>
   <title>Sansui Television : I cant get our television to work....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125468#125468</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9283" rel="nofollow">walygator</a><br /><strong>Subject:</strong> 13019<br /><strong>Posted:</strong> 07 Jul 2019 at 7:42pm<br /><br />I cant get our television to work. It comes on &amp; we've went thru all of the setups many times. Always starts with "Run Auto Channel Search". Doesn't find any channels. We hooked up to Cable in a RV park but no success. Is there an external switch somewhere to switch from Cable to Antenna?]]>
   <pubDate>Sun, 07 Jul 2019 19:42:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13019&amp;PID=125468#125468</guid>
