  <title>R-pod Owners Forum : Antenna help</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Antenna help</description>
  <pubDate>Fri, 23 Oct 2026 23:44:25 +0000</pubDate>
  <lastBuildDate>Mon, 08 Jul 2019 05:09:37 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13014</WebWizForums:feedURL>
   <title>Antenna help : Also turn that same switch (OFF)if...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125482#125482</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8594" rel="nofollow">harrypodder</a><br /><strong>Subject:</strong> 13014<br /><strong>Posted:</strong> 08 Jul 2019 at 5:09am<br /><br />Also turn that same switch (OFF)if you ever hook up to cable.]]>
   <pubDate>Mon, 08 Jul 2019 05:09:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125482#125482</guid>
   <title>Antenna help : Thanks. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125476#125476</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13014<br /><strong>Posted:</strong> 07 Jul 2019 at 9:19pm<br /><br />Thanks.&nbsp;]]>
   <pubDate>Sun, 07 Jul 2019 21:19:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125476#125476</guid>
   <title>Antenna help : Greetings:Right next to the light...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125458#125458</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8314" rel="nofollow">crankster78</a><br /><strong>Subject:</strong> 13014<br /><strong>Posted:</strong> 07 Jul 2019 at 6:31pm<br /><br /><div>Greetings:</div><div>Right next to the light is a small button, push it and it should turn off the antenna amp.&nbsp; The light will be off.&nbsp; It draws a tiny amount of current, and should not draw the battery down much faster than a normal discharge. Happy poding.&nbsp;</div><div><br></div><div>Crankster78</div>]]>
   <pubDate>Sun, 07 Jul 2019 18:31:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125458#125458</guid>
   <title>Antenna help : i have a new Rpod 189 and it has...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125451#125451</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9534" rel="nofollow">Babysaph</a><br /><strong>Subject:</strong> 13014<br /><strong>Posted:</strong> 07 Jul 2019 at 3:44pm<br /><br />i have a new Rpod 189 and it has a black antenna on it. It has a red light that never goes off and I think it is running my battery down. Any ideas on how to get it off? Thanks]]>
   <pubDate>Sun, 07 Jul 2019 15:44:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13014&amp;PID=125451#125451</guid>
