  <title>R-pod Owners Forum : RP190 Frame Damage?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : RP190 Frame Damage?</description>
  <pubDate>Fri, 23 Oct 2026 22:19:52 +0000</pubDate>
  <lastBuildDate>Fri, 05 Jul 2019 06:22:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12998</WebWizForums:feedURL>
   <title>RP190 Frame Damage? : Great!   Re the ceiling strips,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125425#125425</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 05 Jul 2019 at 6:22am<br /><br />Great! <br /><br />Re the ceiling strips, take a look at the video link, it shows the roof construction. You should have an inch thickness to play with, so if you use 1/2 or 5/8 staples or brads you should not penetrate the outer fiberglass layer. If you use an air stapler be sure to do some testing first elsewhere to get the pressure right. I’d suggest using some flexible adhesive as well when you reattach. ]]>
   <pubDate>Fri, 05 Jul 2019 06:22:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125425#125425</guid>
   <title>RP190 Frame Damage? : I lucked out!  Checked the frame...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125416#125416</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8348" rel="nofollow">Geocleve</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 04 Jul 2019 at 5:21pm<br /><br />I lucked out!  Checked the frame and it’s level. The only damage was the rear brace where the stabilizers attach. Will probably have to bend the bumper back or weld a new bumper support. Still trying to figure out how to reattach the ceiling strips. Thinking about using staples,  but worried I might pop one through the roof. Really appreciate all the input! ]]>
   <pubDate>Thu, 04 Jul 2019 17:21:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125416#125416</guid>
   <title>RP190 Frame Damage? :   Originally posted by wthoms2000Curious:...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125377#125377</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 03 Jul 2019 at 6:22am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by wthoms2000</strong></em><br /><br />Curious: what do the very flat exterior walls look like? No waviness?<br><br>Good luck!</td></tr></table><div><br></div><div>I think that is a very good point regarding taking a close look at the walls of the trailer. The walls are stiffer than the steel frame so will try to support the load as the frame deflects. They are lightly constructed (check out this video) so they are probably going to show damage before the frame does. Look for both flatness and wrinkling on the exterior and also for the the interior and exterior wall surfaces becoming detached. Also, look for the bottom of the walls becoming detached (lifted) from the floor.&nbsp;</div><div><br></div><div><a href="https://www.youtube.com/watch?v=QXNYA73rCNE" target="_blank">https://www.youtube.com/watch?v=QXNYA73rCNE</a><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Wed, 03 Jul 2019 06:22:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125377#125377</guid>
   <title>RP190 Frame Damage? : Curious: what do the very flat...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125376#125376</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6969" rel="nofollow">wthoms2000</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 03 Jul 2019 at 1:07am<br /><br />Curious: what do the very flat exterior walls look like? No waviness?<br /><br />Good luck!]]>
   <pubDate>Wed, 03 Jul 2019 01:07:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125376#125376</guid>
   <title>RP190 Frame Damage? : No problem, as a retired engineer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125374#125374</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 02 Jul 2019 at 9:37pm<br /><br />No problem, as a retired engineer it helps me keep my brain exercised.<div><br></div><div>I'm optimistic for you, steel is very tolerant of deflection, and I don't think your rails were that much over stressed if any. You're far from the first person to forget and leave the rear jacks down while raising the tongue jack.&nbsp;<div><br></div><div>Good luck and please keep us posted.&nbsp;</div></div>]]>
   <pubDate>Tue, 02 Jul 2019 21:37:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125374#125374</guid>
   <title>RP190 Frame Damage? : I&#226;&#8364;&#8482;ll be doing some measurements...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125373#125373</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8348" rel="nofollow">Geocleve</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 02 Jul 2019 at 9:15pm<br /><br />I’ll be doing some measurements tomorrow. Thank you for taking the time to run the numbers! <br />Hoping for the best, but expecting the worst. ]]>
   <pubDate>Tue, 02 Jul 2019 21:15:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125373#125373</guid>
   <title>RP190 Frame Damage? :  Since I have the rpod frame...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125371#125371</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 02 Jul 2019 at 8:32pm<br /><br />Since I have the rpod frame structural data set up in a spreadsheet I ran your case where you were basically supporting the trailer frame from the ends. Assuming your trailer weight was 3500 lbs and the trailer box itself doesn't add any support to the frame, I get a deflection (sag) of about 4 inches in the center and an bending stress about 20% over the design limit for steel and about 75% of ultimate yield stress.&nbsp;<div><br></div><div>4 inches is a lot of deflection, so surprise that trim started popping off. Did you happen to notice the sag you were getting when you heard the popping noises?&nbsp;</div><div><br></div><div>Bottom line is that you were most likely at or a bit&nbsp; over the limits for how much stress you would want to put on an rPod frame. The good news is that steel deflects a lot and comes back straight until it reaches its yield point, which will occur somewhere around the stress you put on it. Once it yields it will hold a permanent sag, so, as furpod suggests, see if your frame is straight now or not.&nbsp;</div><div><br></div><div>The finish materials that came loose did so because they were not able to deflect as much as the steel, but not being structural they can be reattached.&nbsp;</div><div><br></div><div>Thanks for posting this because it should help make it clear to all of us why the leveling jacks are not intended to be used to actually take the weight of the trailer. Even if the jacks themselves can handle it the frame cannot.&nbsp;</div>]]>
   <pubDate>Tue, 02 Jul 2019 20:32:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125371#125371</guid>
   <title>RP190 Frame Damage? : thank you! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125370#125370</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8348" rel="nofollow">Geocleve</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 02 Jul 2019 at 6:35pm<br /><br />thank you! ]]>
   <pubDate>Tue, 02 Jul 2019 18:35:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125370#125370</guid>
   <title>RP190 Frame Damage? : there is no way for anyone here,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125365#125365</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 02 Jul 2019 at 5:11pm<br /><br />there is no way for anyone here, to help you there. Without actually being onsite to inspect the trailer.. we can only guess..<br><br>What I would do, is park the camper on level ground, and level it. With no stabes down, just chalked and level, use a measuring tape and string, pulled along the frame, to check for distortion or bends.<br>]]>
   <pubDate>Tue, 02 Jul 2019 17:11:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125365#125365</guid>
   <title>RP190 Frame Damage? : I need some advice on whether...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125359#125359</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8348" rel="nofollow">Geocleve</a><br /><strong>Subject:</strong> 12998<br /><strong>Posted:</strong> 02 Jul 2019 at 3:09pm<br /><br />I need some advice on whether or not I might have damaged the frame on my rpod 190.<br />On our last camping trip I forgot to retract the stabilizer jacks on the rear of the camper before jacking up the front  to install my e2 WD hitch bars. When I heard the frame popping,  I stopped lifting the camper and later noticed that some of the interior roof furring strips had popped off the ceiling. They are easy to reattach, but I am worried that I might have done some serious damage to the frame. I am also noticing that the slide out is closing louder than usual too. Any thoughts would be appreciated. Hoping I’m just being paranoid.  <img src="https://www.rpod-owners.com/smileys/smiley5.gif" border="0" align="middle" /> ]]>
   <pubDate>Tue, 02 Jul 2019 15:09:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12998&amp;PID=125359#125359</guid>
