  <title>R-pod Owners Forum : Part fell out while slideout moved</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Part fell out while slideout moved</description>
  <pubDate>Fri, 23 Oct 2026 23:45:36 +0000</pubDate>
  <lastBuildDate>Sun, 30 Jun 2019 17:08:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12993</WebWizForums:feedURL>
   <title>Part fell out while slideout moved : i think I figured this out. There...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12993&amp;PID=125317#125317</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4995" rel="nofollow">RockyMtnRPod</a><br /><strong>Subject:</strong> 12993<br /><strong>Posted:</strong> 30 Jun 2019 at 5:08pm<br /><br /><div>i think I figured this out.&nbsp; There are three "rollers" that the slide-out rolls on.&nbsp; The pin through on of those worked out of my slide-out.&nbsp; Probably took a while since its 4-5" long. Will have to check this regularly.&nbsp; i tapped it back in a tapped the end caps on tight with a small hammer - and large wrench as a backstop.&nbsp; Tapped the other two as well, just since I was under there.</div><div><br></div><div>Pod-On <img src="https://www.rpod-owners.com/smileys/smiley32.gif" border="0" alt="Clap" title="Clap" />&nbsp;</div>]]>
   <pubDate>Sun, 30 Jun 2019 17:08:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12993&amp;PID=125317#125317</guid>
   <title>Part fell out while slideout moved : Hello all,Just back from a trip....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12993&amp;PID=125313#125313</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4995" rel="nofollow">RockyMtnRPod</a><br /><strong>Subject:</strong> 12993<br /><strong>Posted:</strong> 30 Jun 2019 at 4:19pm<br /><br /><div>Hello all,</div><div><br></div><div>Just back from a trip. I opened the slideout to do some cleaning.&nbsp; It seemed a little strained.&nbsp; On the driveway I found a "pin", about 4-5 inches long with caps on each end.&nbsp; There appear to be 3 pins under the slideout normally, oriented parallel to the trailer.&nbsp; The forward one fell out.&nbsp; <br></div><div><br></div><div>Has this happened to any of you?&nbsp; Can I just try to get everything lined up and tap it back in? <br></div><div><br></div><div>Hopefully, this is a link to the photo:</div><div>https://postimg.cc/HjWgcNZL</div><div><br></div><div>Thanks, Chris<br></div>]]>
   <pubDate>Sun, 30 Jun 2019 16:19:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12993&amp;PID=125313#125313</guid>
