  <title>R-pod Owners Forum : Slideout crank?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Slideout crank?</description>
  <pubDate>Fri, 23 Oct 2026 23:45:12 +0000</pubDate>
  <lastBuildDate>Sun, 30 Jun 2019 20:04:05 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12978</WebWizForums:feedURL>
   <title>Slideout crank? : Correct, a 2018 has the schwintek...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125325#125325</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12978<br /><strong>Posted:</strong> 30 Jun 2019 at 8:04pm<br /><br />Correct, a 2018 has the schwintek system.. whole other animal.]]>
   <pubDate>Sun, 30 Jun 2019 20:04:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125325#125325</guid>
   <title>Slideout crank? :   Originally posted by tony...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125315#125315</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8870" rel="nofollow">teampitt</a><br /><strong>Subject:</strong> 12978<br /><strong>Posted:</strong> 30 Jun 2019 at 4:36pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by tony rpod 180</strong></em><br /><br />I have a 2018 RPod 180, I looked behind the panel below the drawers and there isn't a crank nut, just plumbing, wiring, and the controller for the slide.&nbsp; Is there an emergency fix in the case that our slide ever fails to operate?</td></tr></table> <br></div><div>There's no crank on the newer models. You have to disconnect the motors. They are behind the seals.</div><div><br></div><div>https://www.youtube.com/watch?v=xojUdPDWNS0&amp;list=PLWPLWpc5h68EOSqx8JhhL0HXty8570W6x<br></div>]]>
   <pubDate>Sun, 30 Jun 2019 16:36:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125315#125315</guid>
   <title>Slideout crank? : I have a 2018 RPod 180, I looked...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125308#125308</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8698" rel="nofollow">tony rpod 180</a><br /><strong>Subject:</strong> 12978<br /><strong>Posted:</strong> 30 Jun 2019 at 3:07pm<br /><br />I have a 2018 RPod 180, I looked behind the panel below the drawers and there isn't a crank nut, just plumbing, wiring, and the controller for the slide.&nbsp; Is there an emergency fix in the case that our slide ever fails to operate?]]>
   <pubDate>Sun, 30 Jun 2019 15:07:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125308#125308</guid>
   <title>Slideout crank? : yes it does. at the base of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125179#125179</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12978<br /><strong>Posted:</strong> 24 Jun 2019 at 6:35pm<br /><br />yes it does. at the base of the kitchen cabinets, there are two removable panels. The one under the drawers needs to be removed, behind it you will see a 3/4 inch "nut".. that is the manual crank point.]]>
   <pubDate>Mon, 24 Jun 2019 18:35:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125179#125179</guid>
   <title>Slideout crank? : Does anyone know if the 2013 /...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125176#125176</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9479" rel="nofollow">NewBees</a><br /><strong>Subject:</strong> 12978<br /><strong>Posted:</strong> 24 Jun 2019 at 3:51pm<br /><br />Does anyone know if the 2013 / 177 model has an emergency manual crank for the slideout? No issues at the moment, but want to be prepared just in case :)<div><br></div><div>Thanks!</div>]]>
   <pubDate>Mon, 24 Jun 2019 15:51:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12978&amp;PID=125176#125176</guid>
