  <title>R-pod Owners Forum : Problem with hot water heater on propane.</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Problem with hot water heater on propane.</description>
  <pubDate>Sat, 24 Oct 2026 16:55:28 +0000</pubDate>
  <lastBuildDate>Sat, 15 Jun 2019 22:57:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12943</WebWizForums:feedURL>
   <title>Problem with hot water heater on propane. : ^ this. It&amp;#039;s faked me out...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12943&amp;PID=124882#124882</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8563" rel="nofollow">Jholler</a><br /><strong>Subject:</strong> 12943<br /><strong>Posted:</strong> 15 Jun 2019 at 10:57pm<br /><br />^ this. It's faked me out a time or two also.<br />]]>
   <pubDate>Sat, 15 Jun 2019 22:57:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12943&amp;PID=124882#124882</guid>
   <title>Problem with hot water heater on propane. : Dumb question but is the water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12943&amp;PID=124848#124848</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12943<br /><strong>Posted:</strong> 15 Jun 2019 at 2:38am<br /><br />Dumb question but is the water already hot from the electric element? If so the propane side’s thermostat won’t be calling for heat.<br /><br />Here is Suburban’s manual. There’s a troubleshooting flowchart for the dsi system on pg 19. You’ll need a multimeter. Have fun!<br /><br />http://waterheatertimer.org/pdf/Suburban_Water_Heater_Service_Manual.pdf]]>
   <pubDate>Sat, 15 Jun 2019 02:38:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12943&amp;PID=124848#124848</guid>
   <title>Problem with hot water heater on propane. : My hot water heater does not ignite...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12943&amp;PID=124844#124844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9107" rel="nofollow">Rockwren</a><br /><strong>Subject:</strong> 12943<br /><strong>Posted:</strong> 14 Jun 2019 at 10:32pm<br /><br />My hot water heater does not ignite on propane. It worked a few weeks ago now only on electric.  Doesn’t click like it’s igniting. Propane is on and there is water in tank. Anyone have any ideas?]]>
   <pubDate>Fri, 14 Jun 2019 22:32:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12943&amp;PID=124844#124844</guid>
