  <title>R-pod Owners Forum : Trip planning tools</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Trip planning tools</description>
  <pubDate>Fri, 23 Oct 2026 21:42:40 +0000</pubDate>
  <lastBuildDate>Wed, 15 May 2019 09:52:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12846</WebWizForums:feedURL>
   <title>Trip planning tools : If you&amp;#039;re concerned about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123861#123861</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12846<br /><strong>Posted:</strong> 15 May 2019 at 9:52am<br /><br />If you're concerned about ingress/egress with the trailer into dead end streets/parking lots/gas stations you can also use google maps in "satellite" view to plan your exits before you end up stuck down a blind alley somewhere.&nbsp;]]>
   <pubDate>Wed, 15 May 2019 09:52:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123861#123861</guid>
   <title>Trip planning tools : I use Google Maps and utilize...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123859#123859</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7610" rel="nofollow">Jeepinator</a><br /><strong>Subject:</strong> 12846<br /><strong>Posted:</strong> 15 May 2019 at 9:45am<br /><br />I use Google Maps and utilize the “Add a stop” function to customize the route. &nbsp;However I’ve not found a way to save the custom route to Google. &nbsp;But, you can “share” the route (copy the link) and save it for later or share it with others. &nbsp;<div><br></div><div>Be aware that as you are driving the route, Google may change it on the fly to accommodate for traffic etc. &nbsp;It will briefly prompt you to accept the new route but will change it if you don’t reject the change. This can be a problem if you are trying to avoid parkways, propane-free tunnels etc.</div><div><br></div><div>I also use Allstays Camp &amp; RV to find places to stay such as campgrounds, rest areas and Walmarts.</div>]]>
   <pubDate>Wed, 15 May 2019 09:45:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123859#123859</guid>
   <title>Trip planning tools : i like the &amp;#034;ultimate campground&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123842#123842</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3036" rel="nofollow">texman</a><br /><strong>Subject:</strong> 12846<br /><strong>Posted:</strong> 14 May 2019 at 3:29pm<br /><br />i like the "ultimate campground" app for checking out campsites.&nbsp; i typically plan my route with google maps.&nbsp; But, i don't go cross-country, just usually 4-6 hour trips.&nbsp; recreation.gov is good for the campsites as well around here.&nbsp;]]>
   <pubDate>Tue, 14 May 2019 15:29:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123842#123842</guid>
   <title>Trip planning tools : I&amp;#039;ve used the Good Sam Club...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123841#123841</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2821" rel="nofollow">Happy Tripping</a><br /><strong>Subject:</strong> 12846<br /><strong>Posted:</strong> 14 May 2019 at 3:22pm<br /><br />I've used the Good Sam Club trip planner for years but, of course, they had to change it, and not for the better. Ideally, I'd have a planner where I could change route possibilities without losing the original route and have a good choice of rv campsites.<div><br></div><div>What is the best route planner, or at least, a satisfactory one?</div>]]>
   <pubDate>Tue, 14 May 2019 15:22:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12846&amp;PID=123841#123841</guid>
