  <title>R-pod Owners Forum : Slide out Power Requirements?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Slide out Power Requirements?</description>
  <pubDate>Thu, 24 Sep 2026 02:13:09 +0000</pubDate>
  <lastBuildDate>Thu, 16 May 2019 10:19:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12837</WebWizForums:feedURL>
   <title>Slide out Power Requirements? : +1There are troubleshooting steps...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123907#123907</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 16 May 2019 at 10:19am<br /><br /><div>+1</div><div>There are troubleshooting steps available to check whether the converter is operating. First thing to check though is the two 40A fuses in the middle of the power panel. Those blow to protect the converter if the battery is connected with reverse polarity. <br></div><div><br></div><div><a href="http://wfcoelectr&#111;nics.com/wp-c&#111;ntent/uploads/2015/11/New-Flow-Chart-for-WF-8900-Series.pdf" target="_blank">WFCO troubleshooting Chart.</a><br></div>]]>
   <pubDate>Thu, 16 May 2019 10:19:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123907#123907</guid>
   <title>Slide out Power Requirements? :   Originally posted by ImagerI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123902#123902</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 16 May 2019 at 9:13am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Imager</strong></em><br /><br />I have a rpod 180 I have 110 volts but no 12 volts plugged into house 110</td></tr></table> Your converter is not converting, and your battery may be gone as well.]]>
   <pubDate>Thu, 16 May 2019 09:13:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123902#123902</guid>
   <title>Slide out Power Requirements? : I have a rpod 180 I have 110 volts...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123897#123897</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9305" rel="nofollow">Imager</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 16 May 2019 at 7:25am<br /><br />I have a rpod 180 I have 110 volts but no 12 volts plugged into house 110]]>
   <pubDate>Thu, 16 May 2019 07:25:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123897#123897</guid>
   <title>Slide out Power Requirements? : Is there any body out there that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123896#123896</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9305" rel="nofollow">Imager</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 16 May 2019 at 7:23am<br /><br />Is there any body out there that has 110 volts but no 12 volts? I have a rpod 180 and went to prepare for a trip but no lights battery dead although plugged in ti 110 at the house]]>
   <pubDate>Thu, 16 May 2019 07:23:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123896#123896</guid>
   <title>Slide out Power Requirements? : I doubt a big battery will do...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123878#123878</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 15 May 2019 at 5:55pm<br /><br />I doubt a big battery will do anything about high frequency noise from the charger, that will just pass it by as its in parallel with the charger and loads. A choke would do a much better job if there was a problem. Voltage surges yes, it would likely help with those. But a small battery like a motorcycle one would do that as well.&nbsp;]]>
   <pubDate>Wed, 15 May 2019 17:55:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123878#123878</guid>
   <title>Slide out Power Requirements? : The battery does serve one other...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123874#123874</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 15 May 2019 at 4:16pm<br /><br />The battery does serve one other useful purpose even if you're not boondocking: it acts as a big capacitor to filter DC. The converter uses a DC-to-DC converter after rectifying the AC, which still has some noise on it without something to filter it. The battery will also help protect against DC power on/off spikes.]]>
   <pubDate>Wed, 15 May 2019 16:16:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123874#123874</guid>
   <title>Slide out Power Requirements? :  The slide works just fine directly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123854#123854</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 15 May 2019 at 6:09am<br /><br />The slide works just fine directly on the 12V charger with no battery at all installed. In that sense it does work on shore power (as long as your charger is operating properly).&nbsp;<div><br></div><div>If you always had shore power at your campsites, never used the trailer during the day while on the road,&nbsp; and never used your fridge on 12V the only reason&nbsp; (a good one) to have a battery in an rPod is to operate the emergency breakaway braking system. All your other 12V stuff will run from the charger directly.</div><div><br></div><div>To run the breakaway system a little motorcycle start battery or the equivalent would be more than sufficient. Or you could just get a breakaway kit with an integrated battery.&nbsp;</div>]]>
   <pubDate>Wed, 15 May 2019 06:09:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123854#123854</guid>
   <title>Slide out Power Requirements? : I don&amp;#039;t know if I gave anyone...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123851#123851</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 14 May 2019 at 8:57pm<br /><br /><div>I don't know if I gave anyone the impression that I thought the slide works on shore power.&nbsp; It's pure 12v.&nbsp; But, if a battery is low or even dead, plugging into shore power will almost certainly and instantly put 12v into and out of the battery (through the converter/charger), allowing the slide to function. <br></div><div><br></div><div>TT<br></div>]]>
   <pubDate>Tue, 14 May 2019 20:57:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123851#123851</guid>
   <title>Slide out Power Requirements? : We operate our 179 slideout on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123847#123847</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8268" rel="nofollow">Ben Herman</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 14 May 2019 at 6:04pm<br /><br />We operate our 179 slideout on battery power all the time - even when boondocking (but we use a solar panel to keep it charged up). Shore power is not necessary to operate the slide with a fully charged battery.]]>
   <pubDate>Tue, 14 May 2019 18:04:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123847#123847</guid>
   <title>Slide out Power Requirements? :  Originally posted by StephenHWhile...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123831#123831</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 14 May 2019 at 10:46am<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />While you can simply detach the negative terminal wire, You may want to put in a battery cut-off switch to use when it will be unattended for a few days. That will prevent the parasitic power draws of the LP/CO detector and the TV booster if it is left turned on along with the refrigerator and thermostat. If the battery. Also, if it is a flooded cell battery with caps, check the electrolyte level and add distilled water if needed, then charge. Take the battery to an auto parts place, Sears, Walmart, or Batteries + Bulbs. All of these will test the battery for you. I used it recently to verify that my batteries were still OK after inadvertently allowing them to run low on water.<br /><br /></td></tr></table> <br />I purchased a load meter for my batteries so that I can know immediately if the batteries are going bad. I use two 6V golf cart batteries in series; the load meter I bought has indicated ranges for 6V and 12V batteries.<br /><br /><a href="https://smile.amaz&#111;n.com/gp/product/B000AMBOI0/" target="_blank">https://smile.amazon.com/gp/product/B000AMBOI0/</a>]]>
   <pubDate>Tue, 14 May 2019 10:46:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123831#123831</guid>
   <title>Slide out Power Requirements? : While you can simply detach the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123792#123792</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 13 May 2019 at 10:38am<br /><br />While you can simply detach the negative terminal wire, You may want to put in a battery cut-off switch to use when it will be unattended for a few days. That will prevent the parasitic power draws of the LP/CO detector and the TV booster if it is left turned on along with the refrigerator and thermostat. If the battery. Also, if it is a flooded cell battery with caps, check the electrolyte level and add distilled water if needed, then charge. Take the battery to an auto parts place, Sears, Walmart, or Batteries + Bulbs. All of these will test the battery for you.]]>
   <pubDate>Mon, 13 May 2019 10:38:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123792#123792</guid>
   <title>Slide out Power Requirements? :  The Rpod had been in dry storage...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123775#123775</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9025" rel="nofollow">IrishDream</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 13 May 2019 at 8:26am<br /><br />The Rpod had been in dry storage for just over 2 days, this following a 4 day stay at a local KOA, where of course we were plugged into shore power.<div><br></div><div>I’m thinking the battery’s dead. &nbsp;As indicated above, there’s a good chance the dealer installed an old battery, since nothing was left on the past couple of days. &nbsp;Also, no problem with TV wiring.</div><div><br></div><div>Because we live in a subdivision, we store around the corner from our home. The storage location does not have shore power, but I can get power to it. &nbsp;Assuming I can get the slide out to operate, I’ll check the battery level and replace if needed. &nbsp;If that’s needed, I suspect the dealership, as mentioned above, may have installed an old battery. Thereafter, I will pull the battery and keep it charged at home so that it’s ready to go when we are.</div><div><br></div><div>Thanks again for all your help!</div>]]>
   <pubDate>Mon, 13 May 2019 08:26:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123775#123775</guid>
   <title>Slide out Power Requirements? : How long has the R-pod been in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123762#123762</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 12 May 2019 at 8:38pm<br /><br />How long has the R-pod been in storage? Even 3-4 weeks would be enough to deplete the battery enough to potentially cause problems. If you're not bringing the R-pod home, you might want to pull the battery and bring it home to charge it up. Do check the water level, and when you're sure you have a fully charged battery, take it back to the R-pod and try that slide-out.<div><br></div><div>FYI, the slide-out runs on 12V, regardless of whether you're plugged into shore power or not.&nbsp;</div>]]>
   <pubDate>Sun, 12 May 2019 20:38:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123762#123762</guid>
   <title>Slide out Power Requirements? : Yep, low battery. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123761#123761</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 12 May 2019 at 8:36pm<br /><br /><div>Yep, low battery.</div><div><br></div><div><br></div>]]>
   <pubDate>Sun, 12 May 2019 20:36:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123761#123761</guid>
   <title>Slide out Power Requirements? : Jack,By stating you are receiving...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123756#123756</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 12 May 2019 at 6:31pm<br /><br /><div>Jack,</div><div>By stating you are receiving an error message on your refer I am led to believe your battery is quite low on power.&nbsp; By taking a reading with a volt meter you will find this out.&nbsp; Also, plug your 179 into your house using the heavy duty cord supplied or if that isn't long enough we all have extension cords laying around, use that and see if that will take care of the problem, it should.&nbsp; Just don't try using any power hungry items while using a cheap extension like your A/C, furnace or microwave.&nbsp; If battery is low use a good trickle charger (2 amps or so) to bring it back up slowly to full charge.<br></div>]]>
   <pubDate>Sun, 12 May 2019 18:31:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123756#123756</guid>
   <title>Slide out Power Requirements? : There are reasons the battery...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123755#123755</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 12 May 2019 at 6:29pm<br /><br /><div>There are reasons the battery could be low; I'd try plugging in to shore power, which through the converter will bring the available DC to 12, actually 13.8 v, pretty much instantly.&nbsp; Check the slide then.&nbsp; If it still doesn't work, check for a blown fuse.</div><div><br></div><div>If the battery is low, try to figure out why.&nbsp; You may not have charged it while driving to your storage space, depending on your TV wiring.&nbsp; Check the battery itself.&nbsp; Could be your dealer put an old battery on your Pod.</div><div><br></div><div>There are phantom draws on the battery.&nbsp; The propane detector, the control board for the fridge (the fridge will kill the battery really quickly if you leave it on 12v), the television antenna booster, maybe another thing or two.&nbsp; It's generally a good idea to leave the Pod plugged in during storage, if possible, or disconnect the battery.&nbsp; Leaving it plugged in is, in my opinion, the best option.&nbsp; The onboard converte/charger does a great job of maintaining the battery.</div><div><br></div><div>If, and this isn't all that likely, your battery is dead, you probably need to talk to your dealer, but you may want to replace it with two x 6v golfcart batteries if you think you'll be doing a lot of bondocking.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Sun, 12 May 2019 18:29:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123755#123755</guid>
   <title>Slide out Power Requirements? : Just went to piddle a bit with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123754#123754</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9025" rel="nofollow">IrishDream</a><br /><strong>Subject:</strong> 12837<br /><strong>Posted:</strong> 12 May 2019 at 6:08pm<br /><br />Just went to piddle a bit with our brand new Rpod 179 that is currently in temp storage as of just 3 days ago.<br /><br />Tried to open the slide out to no avail.  Would have thought the 12 volt battery would have had sufficient reserve to do so.  If that’s not the case, guess I’m not going remote camping anytime soon.<br /><br />Should the slide out have been able to open using the power supplied by the battery attached to the trailer?  The lights and radio worked fine, but the refrigerator gave me an error warning when I tried to see if the battery would operate same.<br /><br />Or do I need more power, say from a 120 volt electrical supply?<br /><br />Your comments and suggestions, as always, are greatly appreciated.<br /><br /><br />Jack]]>
   <pubDate>Sun, 12 May 2019 18:08:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12837&amp;PID=123754#123754</guid>
