  <title>R-pod Owners Forum : Bedding Warranty?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Bedding Warranty?</description>
  <pubDate>Thu, 24 Sep 2026 03:45:11 +0000</pubDate>
  <lastBuildDate>Sat, 04 May 2019 07:39:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12816</WebWizForums:feedURL>
   <title>Bedding Warranty? : If you open up your mattress (it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12816&amp;PID=123486#123486</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8294" rel="nofollow">Awchief</a><br /><strong>Subject:</strong> 12816<br /><strong>Posted:</strong> 04 May 2019 at 7:39am<br /><br />If you open up your mattress (it zips open) and look at the insides you will see the problem. Many RV owners swap out the cheap crappy OEM mattresses with a quality foam mattress 8 to 10 inches. This is a popular model from Amazon. There are many others available. As soon as I brought my 19/189 home I pulled it out and replaced with the Zinus. I gave them OEM one to the local fire department.&nbsp;<div><br></div><div><a href="https://www.amaz&#111;n.com/gp/product/B00JRHI05Y/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&amp;psc=1" target="_blank">https://www.amazon.com/gp/product/B00JRHI05Y/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&amp;psc=1</a></div>]]>
   <pubDate>Sat, 04 May 2019 07:39:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12816&amp;PID=123486#123486</guid>
   <title>Bedding Warranty? : Here is a link to the warranty...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12816&amp;PID=123474#123474</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 12816<br /><strong>Posted:</strong> 03 May 2019 at 8:28pm<br /><br />Here is a link to the warranty from Forest River: <a href="http:// www.forestriverinc.com/downloads/TowableWarranty.pdf" target="_blank">&nbsp;https://www.forestriverinc.com/downloads/TowableWarranty.pdf</a><div><br></div><div>In all probability the warranty applicable to the mattress is the one from the mattress manufacturer. &nbsp;Take a look in your materials for equipment from other manufacturers that should have come with the trailer, such as the stove, water heater, etc. &nbsp;If the mattress info is not there, call FR and they should be able to put you in touch with the manufacturer to get the warranty info.</div><div><br></div><div>But, don't get your hopes up. &nbsp;Lower end lightweight trailers notoriously have lousy mattresses that won't sustain someone your weight, or anyone over 90 pounds for that matter. &nbsp;In the forum there are lots of discussion threads on alternative mattresses. &nbsp;Look for mattresses in the search function in the upper right of the page. &nbsp;It's best to go into advanced search and expand the time frame to the last year. &nbsp;Once you find the threads, you'll find lots of information about replacement mattresses.</div>]]>
   <pubDate>Fri, 03 May 2019 20:28:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12816&amp;PID=123474#123474</guid>
   <title>Bedding Warranty? : Brand new Rpod 179.  Have slept...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12816&amp;PID=123473#123473</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9025" rel="nofollow">IrishDream</a><br /><strong>Subject:</strong> 12816<br /><strong>Posted:</strong> 03 May 2019 at 7:47pm<br /><br />Brand new Rpod 179.  Have slept in it 2 nights total thus far.<br /><br />Bedding already sagging 2 inches where I sleep.  I weigh 235 pounds.  Sagging extremely visible no matter where you are in the camper.  Not at all happy with this.<br /><br />Do we have any warranty options?  This is absolutely ridiculous!<br /><br />Thanks in advance.<br /><br />Jack]]>
   <pubDate>Fri, 03 May 2019 19:47:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12816&amp;PID=123473#123473</guid>
