  <title>R-pod Owners Forum : Bike rack</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Bike rack</description>
  <pubDate>Fri, 23 Oct 2026 21:39:33 +0000</pubDate>
  <lastBuildDate>Thu, 18 Apr 2019 12:25:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12766</WebWizForums:feedURL>
   <title>Bike rack :  I second the above.Out of curiosity,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=123041#123041</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12766<br /><strong>Posted:</strong> 18 Apr 2019 at 12:25pm<br /><br />I second the above.&nbsp;<div><br></div><div>Out of curiosity, I placed a gopro camera inside my trailer facing rearwards during a short local trip and after viewing the video, I was amazed at how much the whole trailer bounces around.&nbsp;</div><div><br></div><div>You dont see this or feel this from the drivers seat, but it was enough to jar things around, especially some heavier items placed at the back, on the bed in my 171. A laptop and a solar panel lying on the bed looked like they were bouncing on a trampoline!</div><div><br></div><div>I assume the spare tire or a bike rack would get the worst of it.</div>]]>
   <pubDate>Thu, 18 Apr 2019 12:25:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=123041#123041</guid>
   <title>Bike rack : I would seriously consider not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=123039#123039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12766<br /><strong>Posted:</strong> 18 Apr 2019 at 12:11pm<br /><br />I would seriously consider not carrying your bike (or bikes) on that back receiver.&nbsp;<div><br></div><div>For one thing, the carrying capacity is very limited, AND the bikes increase the moment arm (which reduces the capacity from what you might expect). Further, putting a 2" to 1-1/4" adapter on there increases the moment arm even more.</div><div><br></div><div>Secondly, the bikes will be completely out of sight. If they come loose, or start dragging, you will not only lose your bike(s), you may injure someone (or worse).</div><div><br></div><div>Much better to pack your bikes in the back of your TV (if you have a pickup), or even inside the R-pod where they would be shielded from mud and other road debris.</div>]]>
   <pubDate>Thu, 18 Apr 2019 12:11:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=123039#123039</guid>
   <title>Bike rack : I recently purchased an Allen...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=123038#123038</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8038" rel="nofollow">Andy</a><br /><strong>Subject:</strong> 12766<br /><strong>Posted:</strong> 18 Apr 2019 at 11:50am<br /><br />I recently purchased an Allen 2 bike rack (Model 525) that we used for a 2 week trip through central Texas.&nbsp; It worked very well and has a 1-1/4 hitch with a 2" adapter so one could remove it from the rPod and put it on the truck. Our rPod has a tightening screw that helped stabilize the rack while moving.&nbsp; You may need to check on it occasionally as it did loosen up.&nbsp; I would replace the bolt with something more heavy duty so it doesn't shear off when you tighten it.&nbsp; Don't ask!<div><br></div><div>It did seem to work really well and I was glad to have the bikes on the trip.</div><div><br></div><div>Safe travels,</div>]]>
   <pubDate>Thu, 18 Apr 2019 11:50:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=123038#123038</guid>
   <title>Bike rack :    The receiver socket on the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=122983#122983</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12766<br /><strong>Posted:</strong> 17 Apr 2019 at 3:56pm<br /><br />The receiver socket on the back of my r-pod 171 has a sticker that says "Maximum Capacity 150 Pounds"<div><br></div><div>As far as the manual, here ya go:</div><div><br></div><div>&nbsp;<a href="https://forestriverinc.help/#/forestriverrv/vehicles/2019/" target="_blank">https://forestriverinc.help/#/forestriverrv/vehicles/2019/</a></div><div><br></div><div>Select your year model, then travel trailer. Depending on the year, you may have to select the model, ie: r-pod.</div><div><br></div><div>As you browse thru, you will also find some videos listed on the right side of the page in some of the sections.&nbsp;</div>]]>
   <pubDate>Wed, 17 Apr 2019 15:56:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=122983#122983</guid>
   <title>Bike rack : I am going on an extended road...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=122973#122973</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8497" rel="nofollow">AKPodGal</a><br /><strong>Subject:</strong> 12766<br /><strong>Posted:</strong> 17 Apr 2019 at 2:06pm<br /><br />I am going on an extended road trip this summer and need a bike rack for my fat tire bike.  It has to go on the hitch on the back of my RP179.  Since the spare tire is also there, I am either looking at an extension on the hitch (doesn’t sound like a real good idea to me) or just taking the tire off and stowing it in the truck bed.  I’m looking at. Saris bike rack for just one bike.  Does anyone have advice on good bike racks for the camper?  Also, does anyone know the weight limit on the back hitch?  Forest River really needs to issues comprehensive manuals on these campers.  A real shortcoming on their part, I think.  Thank goodness for the Owners Forum.<br />Deb in Alaska]]>
   <pubDate>Wed, 17 Apr 2019 14:06:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12766&amp;PID=122973#122973</guid>
