  <title>R-pod Owners Forum : Thinking about an upgrade</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Thinking about an upgrade</description>
  <pubDate>Fri, 23 Oct 2026 20:52:35 +0000</pubDate>
  <lastBuildDate>Sat, 13 Apr 2019 16:23:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12756</WebWizForums:feedURL>
   <title>Thinking about an upgrade : Agree with Furpod. A 2500 (AKA...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12756&amp;PID=122860#122860</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12756<br /><strong>Posted:</strong> 13 Apr 2019 at 4:23pm<br /><br />Agree with Furpod. A 2500 (AKA 3/4 ton) should be able to handle a tongue weight north of 1000 lbs, and none of the R-pods are in that range. Also as he stated, you may like the ride better with a WDH, regardless of whether you need it or not.]]>
   <pubDate>Sat, 13 Apr 2019 16:23:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12756&amp;PID=122860#122860</guid>
   <title>Thinking about an upgrade : For your truck, weight distribution...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12756&amp;PID=122850#122850</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12756<br /><strong>Posted:</strong> 13 Apr 2019 at 2:06pm<br /><br />For your truck, weight distribution won't be an issue until about whatever point your owners manual says is the max TW without one. For our truck, it's 1500lbs.&nbsp;<br><br>Now that doesn't mean you may not like using one... For our Pod, we towed with a Expedition, 9200 tow rating 900lb TW. The 385 or so pounds tongue weight we had was no issue on paper.. BUT, using a WDH, the big Ex rode better, and smoother. If you are happy with the ride you have now with the 179, I seriously doubt you will be unhappy with the 195. If you are, or just get WDH curious, give one a try, and if you don't, you still will be well within your trucks capabilities.<br>]]>
   <pubDate>Sat, 13 Apr 2019 14:06:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12756&amp;PID=122850#122850</guid>
   <title>Thinking about an upgrade : We have a 179 and really like...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12756&amp;PID=122848#122848</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6047" rel="nofollow">ArenaBlanca</a><br /><strong>Subject:</strong> 12756<br /><strong>Posted:</strong> 13 Apr 2019 at 1:23pm<br /><br />We have a 179 and really like it!&nbsp; I currently tow with a diesel 2500 pick-up but I don't use a WDH with the R-pod.but do have sway control.<div><br></div><div>But we are enticed by the 195 because of the bed orientation and certain other features.&nbsp; I notice that the 195 is going to be a foot longer which isn't a major deal.&nbsp; The tongue weight is also supposed to be 300 lbs more according to the specifications that I saw.&nbsp; I know that the tongue weight will probably be higher when the trailer is loaded but can be effected by water tanks, etc.</div><div><br></div><div>At what point does a weight distributing hitch become really important?&nbsp; I suppose I could ask a dealer but I put more credence in the response from this forum.</div>]]>
   <pubDate>Sat, 13 Apr 2019 13:23:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12756&amp;PID=122848#122848</guid>
