  <title>R-pod Owners Forum : R Pod 179 new owner</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : R Pod 179 new owner</description>
  <pubDate>Thu, 24 Sep 2026 04:32:59 +0000</pubDate>
  <lastBuildDate>Mon, 15 Apr 2019 06:42:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12752</WebWizForums:feedURL>
   <title>R Pod 179 new owner :   Originally posted by BobGThanks.....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122894#122894</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 15 Apr 2019 at 6:42am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by BobG</strong></em><br /><br />Thanks.. I wonder if with the easy start i could not use my Coleman.. Thanks again</td></tr></table><div><br></div><div>I would think probably no. My Honda 2K will run the A/C but nothing else simultaneously.&nbsp; The a/c takes about 15 amps which is right at the max for an 1850 watt genny. So with he easystart it will probably start on the generator but trip off as soon as the a/c compressor builds up back pressure. You could try it one time though, once you get the easystart installed.&nbsp;</div>]]>
   <pubDate>Mon, 15 Apr 2019 06:42:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122894#122894</guid>
   <title>R Pod 179 new owner : Greetings:I do not use it to run...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122834#122834</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8314" rel="nofollow">crankster78</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 13 Apr 2019 at 8:34am<br /><br /><div>Greetings:</div><div><br></div><div>I do not use it to run the air.&nbsp; It does everything else very well.&nbsp; The only RF noise I've had is with the converter in the pod.&nbsp; I replaced it with the better one and no longer have a problem.&nbsp; Inverters operate at high frequency and down convert it to 60 cycle sine wave, which&nbsp; is the best for any electronics.&nbsp; I change oil after every use. &nbsp;</div><div><br></div><div>73's</div><div><br></div><div>Crankster78 2015 R179</div>]]>
   <pubDate>Sat, 13 Apr 2019 08:34:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122834#122834</guid>
   <title>R Pod 179 new owner : I am sure i will start a Ham thread...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122823#122823</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9274" rel="nofollow">BobG</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 12 Apr 2019 at 11:57am<br /><br />I am sure i will start a Ham thread&nbsp;]]>
   <pubDate>Fri, 12 Apr 2019 11:57:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122823#122823</guid>
   <title>R Pod 179 new owner : KR0K does your Honda run your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122822#122822</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9274" rel="nofollow">BobG</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 12 Apr 2019 at 11:47am<br /><br />KR0K does your Honda run your AC? I put my IC-7000 in the camper with a Myantenna longwire.. I have a fiber glasss mast I can hoist up about 25' Look forward to doing some DX<div><br></div>]]>
   <pubDate>Fri, 12 Apr 2019 11:47:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122822#122822</guid>
   <title>R Pod 179 new owner : Maybe we should start a ham radio...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122821#122821</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 12 Apr 2019 at 10:06am<br /><br />Maybe we should start a ham radio thread, share ideas. In fact, I refer to my r-pod locally on the air as my 'radio-pod'....<div><br></div><div><img src="https://www.rpod-owners.com/smileys/smiley23.gif" border="0" alt="Geek" title="Geek" /><br></div>]]>
   <pubDate>Fri, 12 Apr 2019 10:06:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122821#122821</guid>
   <title>R Pod 179 new owner : Greetings:I am a ham also. My...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122819#122819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8314" rel="nofollow">crankster78</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 12 Apr 2019 at 8:50am<br /><br /><div>Greetings:</div><div>I am a ham also.&nbsp; My call is KR0K and I live in MN.&nbsp; When I bought my 179, I had the dealer install a wireway cover into the extension by the bed.&nbsp; That allows me to run the coax and ground out though the opening.&nbsp; When not in use it closes up tight.&nbsp; I'm mainly on HF and have a CrankIR portable antenna that works well.&nbsp; I've really enjoyed my 2015 179. Prior to buying it I owned a R-171.&nbsp; I travel by myself so I installed a twin size innerspring mattress and put a shelf behind it.&nbsp; I tow it behind a F-150 with a 125,000 miles on it&nbsp; I usually stay in State parks but go to a couple of antique steam and farm shows where I dry camp.&nbsp; I have a 2000 watt Honda inverter which I've used for about 12 years and it still runs great.&nbsp; You get what you pay for.&nbsp; Hondas are expensive but they last a long time.&nbsp; I use the Honda for field day also.</div><div><br></div><div>Safe travels and good propagation</div><div><br></div><div>73's</div><div><br></div><div>Crankster78</div>]]>
   <pubDate>Fri, 12 Apr 2019 08:50:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122819#122819</guid>
   <title>R Pod 179 new owner : Welcome and congratulations. I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122814#122814</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 10:08pm<br /><br />Welcome and congratulations. I hope you have many great adventures and make many wonderful memories doing so with your RPod 179. We've enjoyed ours very much and I have made a number of modifications to make it even more to our liking. It is a great little trailer.]]>
   <pubDate>Thu, 11 Apr 2019 22:08:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122814#122814</guid>
   <title>R Pod 179 new owner :         Anything with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122812#122812</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 9:46pm<br /><br />Anything with 'inverter' in the name will include some kind of high speed switching power supply or buck/boost voltage converters and those all generate noise.<div><br></div><div>Distance helps, but this RF noise can also propagate along the extension cord from the genset that's 50 feet away. And even standard non-inverter generators can make a racket on HF, esecially 80 and 40 meters.</div><div><br></div><div>Many MPPT solar controllers are also noisy, most PWM controllers are less noisy, I've had good luck with Morningstar and Renogy PWM types. In fact, the Morningstar Pro-Star PWM-15 that I have is 'telco' rated with an internal jumper for making the unit even quieter by reducing the switching speed. The Victron MPPT controller I have is quite noisy.</div><div><br></div><div>Also, laptop chargers and phone chargers can be very noisy on HF and VHF. Be ready to install some ferrites!</div><div><br></div><div>BTW if you find you have local noise that ruins your listening ability on HF, either at home or on the road, and you have internet, you can always 'cheat' and use a web-based SDR receiver:</div><div><br></div><div><a href="http://www.websdr.org/" target="_blank">http://www.websdr.org/</a></div><div><br></div><div>I especially like this one:</div><div><br></div><div><a href="http://websdr1.utahsdr.org/" target="_blank">http://websdr1.utahsdr.org/</a></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 11 Apr 2019 21:46:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122812#122812</guid>
   <title>R Pod 179 new owner : Yikes, well can shut that down...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122808#122808</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9274" rel="nofollow">BobG</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 7:03pm<br /><br />Yikes, well can shut that down will on the radio.. I was wondering about that.. One of the reasons for the 200 watt solar panels...&nbsp;]]>
   <pubDate>Thu, 11 Apr 2019 19:03:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122808#122808</guid>
   <title>R Pod 179 new owner : Just be aware that inverter generators...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122805#122805</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 6:18pm<br /><br />Just be aware that inverter generators create a LOT of hash on HF.&nbsp;]]>
   <pubDate>Thu, 11 Apr 2019 18:18:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122805#122805</guid>
   <title>R Pod 179 new owner : Thanks.. I wonder if with the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122804#122804</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9274" rel="nofollow">BobG</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 5:19pm<br /><br />Thanks.. I wonder if with the easy start i could not use my Coleman.. Thanks again]]>
   <pubDate>Thu, 11 Apr 2019 17:19:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122804#122804</guid>
   <title>R Pod 179 new owner : Welcome!  The generator you first...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122803#122803</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 5:15pm<br /><br />Welcome!<br /><br />The generator you first mentioned would run the TV quite easily. The second generator you mentioned would likely run the AC if you add an EasyStart device to the AC.<br /><br /><a href="https://www.microair.net/products/easystart-364-3-t&#111;n-single-phase-soft-starter-for-air-c&#111;nditi&#111;ners?variant=30176048267" target="_blank">https://www.microair.net/products/easystart-364-3-ton-single-phase-soft-starter-for-air-conditioners?variant=30176048267</a>]]>
   <pubDate>Thu, 11 Apr 2019 17:15:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122803#122803</guid>
   <title>R Pod 179 new owner : I just got my first R Pod. Tons...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122802#122802</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9274" rel="nofollow">BobG</a><br /><strong>Subject:</strong> 12752<br /><strong>Posted:</strong> 11 Apr 2019 at 5:03pm<br /><br />I just got my first R Pod. Tons of questions, but most will work themselves out.. Next week I am installing the 200 watt Renogy Solar panels as part of my power system.. I am also looking at generators.. I have a Coleman Powermate 1850 that is quiet, but not sure it will run the TV and probably will not start the AC unit..The AC unit for the most part will not be a big issue living in Oregon on the coast.. But there might be a time.. So I have been looking at inverter generators.. A local shop has the Energizer eZV2000P for $499.00. It is Parallel capable and seems to get some good reviews. Does anyone have experience with this product.. Also would on it's own work the AC? I am a HAM Radio operator amd look forward to making this my portable Ham Shack...]]>
   <pubDate>Thu, 11 Apr 2019 17:03:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12752&amp;PID=122802#122802</guid>
