  <title>R-pod Owners Forum : Emergency Exit Window</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Emergency Exit Window</description>
  <pubDate>Sat, 24 Oct 2026 02:03:22 +0000</pubDate>
  <lastBuildDate>Mon, 07 Oct 2019 21:15:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12748</WebWizForums:feedURL>
   <title>Emergency Exit Window : Unfortunately, I can&amp;#039;t see...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127515#127515</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 07 Oct 2019 at 9:15pm<br /><br />Unfortunately, I can't see what you are describing. It sounds like something got pinched in there when it was open and bent the metal hinge, but I don't know. Is there any way you can bend it back?]]>
   <pubDate>Mon, 07 Oct 2019 21:15:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127515#127515</guid>
   <title>Emergency Exit Window : No, but the hinge metal is slightly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127512#127512</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9690" rel="nofollow">poohbill</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 07 Oct 2019 at 5:57pm<br /><br />No, but the hinge metal is slightly warped.]]>
   <pubDate>Mon, 07 Oct 2019 17:57:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127512#127512</guid>
   <title>Emergency Exit Window : Is there something in the way...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127506#127506</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 07 Oct 2019 at 3:46pm<br /><br />Is there something in the way preventing it from shutting properly?]]>
   <pubDate>Mon, 07 Oct 2019 15:46:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127506#127506</guid>
   <title>Emergency Exit Window : The window hinge on our 2016 trailer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127505#127505</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9690" rel="nofollow">poohbill</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 07 Oct 2019 at 3:34pm<br /><br />The window hinge on our 2016 trailer sprung the first time I opened it and now won't seal against the gasket on the front top corner. Gorilla tape is our only protectant until I can install a new window into the frame.]]>
   <pubDate>Mon, 07 Oct 2019 15:34:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=127505#127505</guid>
   <title>Emergency Exit Window : https://www.youtube.com/watch?v=-aRyCjzyF5E  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122772#122772</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 3:31pm<br /><br />https://www.youtube.com/watch?v=-aRyCjzyF5E]]>
   <pubDate>Wed, 10 Apr 2019 15:31:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122772#122772</guid>
   <title>Emergency Exit Window : That&amp;#039;s a good idea too...I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122771#122771</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 2:57pm<br /><br />That's a good idea too...I might do the same thing.&nbsp;]]>
   <pubDate>Wed, 10 Apr 2019 14:57:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122771#122771</guid>
   <title>Emergency Exit Window : We use our emergency window for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122770#122770</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 2:31pm<br /><br /><div>We use our emergency window for additional ventilation.&nbsp; We made an interior screen that covers the entire window. It attaches to the frame with velcro-the hook side is sewn to the screen and the loop side is glued to the window frame.&nbsp; We had to remove the window valence board in order to permanently install the screen. We open both emergency red handles and prop the window open about 10" with a small piece of 3/4"x 10" pvc pipe.&nbsp; It works great.</div><div>Vann<br></div>]]>
   <pubDate>Wed, 10 Apr 2019 14:31:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122770#122770</guid>
   <title>Emergency Exit Window :      Originally posted by...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122769#122769</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 1:47pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br />&nbsp; All three of our camper r-pod, Vibe and Vista we have always opened the emergency window for extra ventilation.&nbsp;</div><div><br></div><div>{snip}</div><div><br></div><div>&nbsp;Also the emergency windows have had screens so they are made to be opened for the option of ventilation.</td></tr></table></div><div><br></div><div><br></div>Yip! Thanks, I went out there and sure enough, the window pops open with a hinge up top. You can't really see the hinge from the outside, its just a bar or ridge of aluminum.&nbsp;<div><br></div><div>And yes, it has a sliding section of glass, and a screen too.</div><div><br></div><div>Now I just need to fabricate a little 'prop-rod' so I can leave it part way open during light rain....who needs one of them fancy-shmancy Class A's?</div><div><br></div><div><img src="https://www.rpod-owners.com/smileys/smiley17.gif" border="0" alt="T&#111;ngue" title="T&#111;ngue" /><br></div>]]>
   <pubDate>Wed, 10 Apr 2019 13:47:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122769#122769</guid>
   <title>Emergency Exit Window :  Originally posted by podwerkzIf...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122768#122768</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 1:37pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by podwerkz</strong></em><br /><br />If I modified the hinges of the grab handle, it might not be as secure when the pod is rolling down the road...but I will look at it again.</td></tr></table> <br /><br />You'd only need to modify them on the side toward the door and not by much. They should still hold against most wind currents. You could travel with the handle swung back instead of forward, although I understand some people's desire to make the handle an extra door security feature while traveling down the road.]]>
   <pubDate>Wed, 10 Apr 2019 13:37:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122768#122768</guid>
   <title>Emergency Exit Window :    All three of our camper r-pod,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122764#122764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 12:05pm<br /><br />&nbsp; All three of our camper r-pod, Vibe and Vista we have always opened the emergency window for extra ventilation. The arm that pushes window out locks or latched in place and keeps widow held open. All three campers the emergency windows have been hinged at the top they haven't fell to the ground. Maybe the newer r-pods have a different emergency window. I would look at the top of the window to see if it has a hinge. Also the emergency windows have had screens so they are made to be opened for the option of ventilation.]]>
   <pubDate>Wed, 10 Apr 2019 12:05:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122764#122764</guid>
   <title>Emergency Exit Window : If I modified the hinges of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122763#122763</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 11:41am<br /><br />If I modified the hinges of the grab handle, it might not be as secure when the pod is rolling down the road...but I will look at it again.]]>
   <pubDate>Wed, 10 Apr 2019 11:41:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122763#122763</guid>
   <title>Emergency Exit Window :  Originally posted by JhollerI&amp;#039;m...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122761#122761</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 11:12am<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Jholler</strong></em><br /><br />I'm not sure about the window, but try opening the door with the grab handle closed. I was surprised myself at how easy it is to push the handle out of the way.</td></tr></table> <br /><br />If the grab handle doesn't swing out, then you can grind down some material on the handle hinges to get it to move with minimal force.]]>
   <pubDate>Wed, 10 Apr 2019 11:12:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122761#122761</guid>
   <title>Emergency Exit Window : I&amp;#039;m not sure about the window,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122758#122758</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8563" rel="nofollow">Jholler</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 10:27am<br /><br />I'm not sure about the window, but try opening the door with the grab handle closed. I was surprised myself at how easy it is to push the handle out of the way.]]>
   <pubDate>Wed, 10 Apr 2019 10:27:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122758#122758</guid>
   <title>Emergency Exit Window :        It has a sticker...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122757#122757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 12748<br /><strong>Posted:</strong> 10 Apr 2019 at 9:11am<br /><br />It has a sticker that says: 'OPEN ONLY IN CASE OF EMERGENCY'<div><br></div><div>Obviously that is an emergency window, but is there a seal or something that breaks when you open it?</div><div><br></div><div>Does it fall on the ground when opened?</div><div><br></div><div>I dont want to just force it open to find out that I broke something, but it would be nice to know if it can be opened and then closed again with no damage.&nbsp;</div><div><br></div><div>You know that big nice folding entry handle by the door?</div><div><br></div><div>If some jokester decided to swing that handle across the camper door while the person inside is asleep, it will make it difficult to open that door, so that makes me wonder, if that happened, can I crawl out the Emergency Exit without damaging the window itself?&nbsp;</div><div><br></div><div>I'm a big guy, so yeah, I could kick open the door, but I'd hate to bust that grab handle, but I would have to if I wanted to exit, which I'm sure I would!</div><div><br></div><div>BTW this emergency window is 6 feet across from the main exit, but about 12 feet from the bed. Makes no sense to me. In my old motorhome, the Emergency Exit was very close to the bed.</div><div><br></div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Wed, 10 Apr 2019 09:11:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12748&amp;PID=122757#122757</guid>
