  <title>R-pod Owners Forum : Anode rod replacement</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Anode rod replacement</description>
  <pubDate>Fri, 23 Oct 2026 20:41:19 +0000</pubDate>
  <lastBuildDate>Mon, 18 Mar 2019 11:43:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12661</WebWizForums:feedURL>
   <title>Anode rod replacement : They are made of one of two materials:...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121701#121701</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 18 Mar 2019 at 11:43am<br /><br />They are made of one of two materials: magnesium or aluminum. Magnesium is more effective but disintegrates more quickly as a result. I would advise sticking with magnesium, considering how inexpensive the rods are compared to a new water heater.]]>
   <pubDate>Mon, 18 Mar 2019 11:43:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121701#121701</guid>
   <title>Anode rod replacement : Thank you. Enjoy camping. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121695#121695</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4649" rel="nofollow">Lazy Goose</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 18 Mar 2019 at 9:55am<br /><br />Thank you. Enjoy camping.]]>
   <pubDate>Mon, 18 Mar 2019 09:55:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121695#121695</guid>
   <title>Anode rod replacement : length matters but as Ben Herman...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121694#121694</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6047" rel="nofollow">ArenaBlanca</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 18 Mar 2019 at 9:53am<br /><br />length matters but as Ben Herman said they are very common. I get mine at a local plumbing supply store.]]>
   <pubDate>Mon, 18 Mar 2019 09:53:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121694#121694</guid>
   <title>Anode rod replacement : Replacing the anode rod can you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121693#121693</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4649" rel="nofollow">Lazy Goose</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 18 Mar 2019 at 9:46am<br /><br />Replacing the anode rod can you use a generic one or does it have to be Suburban? ]]>
   <pubDate>Mon, 18 Mar 2019 09:46:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121693#121693</guid>
   <title>Anode rod replacement : Unless it&amp;#039;s just a wire,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121688#121688</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 18 Mar 2019 at 7:56am<br /><br />Unless it's just a wire, it's still working.<br><div><br></div><div><a href="https://postimg.cc/p9Fcfn5S" target="_blank"><img src="https://i.postimg.cc/xdxrSvf9/23Anode_rods_-_removed_Oct_2012_-_removed_Jan_20.jpg" border="0" /></a><br></div>]]>
   <pubDate>Mon, 18 Mar 2019 07:56:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121688#121688</guid>
   <title>Anode rod replacement : Thanks so much. Happy camping....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121679#121679</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4649" rel="nofollow">Lazy Goose</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 17 Mar 2019 at 8:20pm<br /><br />Thanks so much. Happy camping.]]>
   <pubDate>Sun, 17 Mar 2019 20:20:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121679#121679</guid>
   <title>Anode rod replacement : Don&amp;#039;t replace it prematurely....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121586#121586</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 16 Mar 2019 at 9:42am<br /><br /><div>Don't replace it prematurely.&nbsp; It can look like holy crap and still be doing its job as well as when it was new.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Sat, 16 Mar 2019 09:42:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121586#121586</guid>
   <title>Anode rod replacement :   Originally posted by Lazy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121583#121583</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8268" rel="nofollow">Ben Herman</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 16 Mar 2019 at 8:27am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Lazy Goose</strong></em><br /><br />Hi All, I have a 2016 pod 179. I need a new anode rod, can anony give me a part number I know it's Suburban. <br>Thank you</td></tr></table><div><br></div><div>Even can be found in my local Tru Value Hardware store. Very common, standardized part.</div>]]>
   <pubDate>Sat, 16 Mar 2019 08:27:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121583#121583</guid>
   <title>Anode rod replacement :  It&amp;#039;s a standard part.You...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121580#121580</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8870" rel="nofollow">teampitt</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 16 Mar 2019 at 6:48am<br /><br /><div>It's a standard part.</div><div><br></div><div>You can Google "Suburban anode rod" and come up with several purchasing options.<br></div><div><br></div><div>https://www.campingworld.com/suburban-anode-rod-replacement-42180.html</div><div>https://www.amazon.com/Suburban-232767-Water-Heater-Anode/dp/B003VAYRNM</div><div>https://www.walmart.com/ip/Suburban-232767-Anode-Magnesium-Rod/110564857<br></div>]]>
   <pubDate>Sat, 16 Mar 2019 06:48:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121580#121580</guid>
   <title>Anode rod replacement : Hi All, I have a 2016 pod 179....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121571#121571</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4649" rel="nofollow">Lazy Goose</a><br /><strong>Subject:</strong> 12661<br /><strong>Posted:</strong> 15 Mar 2019 at 9:06pm<br /><br />Hi All, I have a 2016 pod 179. I need a new anode rod, can anony give me a part number I know it's Suburban. <br />Thank you ]]>
   <pubDate>Fri, 15 Mar 2019 21:06:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12661&amp;PID=121571#121571</guid>
