  <title>R-pod Owners Forum : 2018 Off-grid R-Pod 180 - $17,000</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Campers Flea Market : 2018 Off-grid R-Pod 180 - $17,000</description>
  <pubDate>Fri, 06 Nov 2026 23:37:02 +0000</pubDate>
  <lastBuildDate>Sun, 03 Mar 2019 20:06:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12625</WebWizForums:feedURL>
   <title>2018 Off-grid R-Pod 180 - $17,000 : Your gonna love this one if you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12625&amp;PID=121195#121195</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7540" rel="nofollow">Planopod</a><br /><strong>Subject:</strong> 12625<br /><strong>Posted:</strong> 03 Mar 2019 at 8:06pm<br /><br />Your gonna love this one if you want to camp in the national parks or off the grid.<div><br></div><div>Has many upgrades:</div><div><br></div><div>120 amp hour lithium batteries. These last for days compared to stock. With the included 100w solar panel - you may never have to plug in. I have camped at Big Bend NP for a week and never ran out of power! All of the other campers around me couldn’t even run their furnaces on the cold nites because they didn’t have enough power. They were charging their IPhones in my R-Pod!</div><div><br></div><div>100w solar. Plugs into the factory plug on the side off the R-Pod and is programmed for 14.4v lithium charging.</div><div><br></div><div>Upgraded tires for improved lateral stability and decreased sway. Plus increased cords to reduce punctures on those back road adventures.</div><div><br></div><div>Undercarriage spare tire storage. Frees up the rear adapter for a bike rack and it makes the R-Pod look better.</div><div><br></div><div>AC start assist. Yep, you can run the AC on 2000w generator. This is very cool - literally. Will prove it to you when you come visit to look at it.</div><div><br></div><div>Jack-e-up removable tongue jack. Gets the jack out of the way so your tailgate can be opened when the R-Pod is attached. Very handy and saves the tailgate from getting damaged.</div><div><br></div><div>Onboard voltage meter that lets you know how much power you have at a glance.&nbsp;</div><div><br></div><div>All of the lights are LED saving even more power!</div><div><br></div><div>Blue ox sway control. This a must for safety and well suited for a mid-size SUV to tow this R-Pod.</div><div><br></div><div>1000v inverter. Great for running the those must have items out in the wild.</div><div><br></div><div>Full cover - never been used because it is stored in a building.</div><div><br></div><div>Many other smaller modifications to make this R-Pod very usable.</div><div><br></div><div>Perfectly maintained by and engineer - in case you hadn’t guessed already. I have come up with fixes even the factory hasn’t thought of. You get the benefit of all fo them.&nbsp;</div><div><br></div><div>All of the new R-Pod bugs have been worked out. This saves you all of the trips to dealer getting things fixed! I have a comprehensive list of all of them and the repairs.&nbsp;</div><div><br></div><div>Everything is in very good condition. I’m going to work on pictures to show all of this and more. Please be patient.</div><div><br></div><div>If you need help on how to use or understand any of this, I’m a phone call away!</div><div><br></div><div><br></div>]]>
   <pubDate>Sun, 03 Mar 2019 20:06:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12625&amp;PID=121195#121195</guid>
