  <title>R-pod Owners Forum : Shower Curtain</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Shower Curtain</description>
  <pubDate>Fri, 23 Oct 2026 19:50:45 +0000</pubDate>
  <lastBuildDate>Tue, 12 Mar 2019 21:07:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12608</WebWizForums:feedURL>
   <title>Shower Curtain : I replaced mine with a generic...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121466#121466</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7297" rel="nofollow">MIK</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 12 Mar 2019 at 9:07pm<br /><br />I replaced mine with a generic one off amazon. Secured one end to the wall using the original mounting rail and let the other side just hang free. It's slightly wider than the original and works well. As a bonus, a slight chemical smell that bothered me for a while disappeared after replacing the curtain.&nbsp;<div><br><div><div>http://www.rpod-owners.com/forum_posts.asp?TID=12424</div></div></div>]]>
   <pubDate>Tue, 12 Mar 2019 21:07:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121466#121466</guid>
   <title>Shower Curtain : Ok thank you - that&#226;&#8364;&#8482;s what I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121017#121017</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9157" rel="nofollow">tilee77</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 25 Feb 2019 at 12:49pm<br /><br />Ok thank you - that’s what I guessed 🙄. It’s not broken just turned yellowish from use but since I’m slightly OCD wanted to get it changed out after purchasing it.  Thanks for the advice 😊]]>
   <pubDate>Mon, 25 Feb 2019 12:49:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121017#121017</guid>
   <title>Shower Curtain : Is it damaged? or do you just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121016#121016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 25 Feb 2019 at 12:45pm<br /><br /><div>Is it damaged? or do you just want something "different" ?</div><div><br></div><div>It's called a "neo angle" shower. Finding factory replacement parts will probably have to be done through FR. Finding a complete replacement, or optional curtain, will be a little more difficult I suspect. <br></div>]]>
   <pubDate>Mon, 25 Feb 2019 12:45:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121016#121016</guid>
   <title>Shower Curtain : There should be a terminal screw...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121001#121001</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9056" rel="nofollow">Motor7</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 25 Feb 2019 at 6:48am<br /><br />There should be a terminal screw to remove at the end of the track to slide them all out. If not, then each track ring holding the curtain will have to be taken apart.&nbsp;]]>
   <pubDate>Mon, 25 Feb 2019 06:48:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=121001#121001</guid>
   <title>Shower Curtain : Thanks but the curtain in the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120990#120990</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9157" rel="nofollow">tilee77</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 23 Feb 2019 at 8:09pm<br /><br />Thanks but the curtain in the 180 is fixed on rails top and bottom and fixed against a runner each side? ]]>
   <pubDate>Sat, 23 Feb 2019 20:09:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120990#120990</guid>
   <title>Shower Curtain : Wallyworld has a large assortment....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120989#120989</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8294" rel="nofollow">Awchief</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 23 Feb 2019 at 5:43pm<br /><br />Wallyworld has a large assortment.&nbsp;]]>
   <pubDate>Sat, 23 Feb 2019 17:43:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120989#120989</guid>
   <title>Shower Curtain : try thisamazon 48&amp;#039; x 72&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120988#120988</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8452" rel="nofollow">Billy Bob</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 23 Feb 2019 at 4:13pm<br /><br />try this<div>amazon 48' x 72" shower curtain</div><div><br></div><div><br></div>]]>
   <pubDate>Sat, 23 Feb 2019 16:13:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120988#120988</guid>
   <title>Shower Curtain : Hi. We are new to all this but...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120987#120987</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9157" rel="nofollow">tilee77</a><br /><strong>Subject:</strong> 12608<br /><strong>Posted:</strong> 23 Feb 2019 at 12:45pm<br /><br />Hi. We are new to all this but have just purchased our first R-pod 180 and already love it!  However we would like to change out the shower curtain and cannot find out how to get a replacement.  Any advice?  Thank you in advance! ]]>
   <pubDate>Sat, 23 Feb 2019 12:45:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12608&amp;PID=120987#120987</guid>
