  <title>R-pod Owners Forum : Vinyl separation from ceiling</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Vinyl separation from ceiling</description>
  <pubDate>Fri, 23 Oct 2026 15:52:36 +0000</pubDate>
  <lastBuildDate>Tue, 30 Oct 2018 09:35:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12360</WebWizForums:feedURL>
   <title>Vinyl separation from ceiling :   Sounds like it was not properly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12360&amp;PID=117177#117177</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 12360<br /><strong>Posted:</strong> 30 Oct 2018 at 9:35am<br /><br /><div>Sounds like it was not properly glued to the plywood on the ceiling panels. &nbsp;It it is under warranty, go to the dealer where you bought it and try to get them to fix it. &nbsp;</div>]]>
   <pubDate>Tue, 30 Oct 2018 09:35:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12360&amp;PID=117177#117177</guid>
   <title>Vinyl separation from ceiling : 2018 190.  We have had no leak...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12360&amp;PID=117154#117154</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8766" rel="nofollow">SuziQ</a><br /><strong>Subject:</strong> 12360<br /><strong>Posted:</strong> 29 Oct 2018 at 11:04pm<br /><br />2018 190.  We have had no leak issues and all the seals are good. The vinyl has begun to ripple and pull away from the ceiling. Material behind the vinyl is solid and no water is present.  Any ideas what could cause this and how to repair?  Appears that the glue is not holding.  What kind of material is the the vinyl glued to?]]>
   <pubDate>Mon, 29 Oct 2018 23:04:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12360&amp;PID=117154#117154</guid>
