  <title>R-pod Owners Forum : Protect tailgate from jack</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Protect tailgate from jack</description>
  <pubDate>Fri, 23 Oct 2026 15:52:39 +0000</pubDate>
  <lastBuildDate>Fri, 26 Oct 2018 14:02:00 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12345</WebWizForums:feedURL>
   <title>Protect tailgate from jack : Out of curiosity I just ran the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116950#116950</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 26 Oct 2018 at 2:02pm<br /><br />Out of curiosity I just ran the towing weight calculator. For my rig without the wd hitch 2 inches more shank would move 10 lbs from the front to the rear axle of my tow vehicle. If you're using a commercial scale the accuracy is about 20 lbs so as furpod says the difference is literally unmeasurable. Interestingly, though, you would have to add 20 lbs more tension to the wd hitch to compensate for the 2 inches and get the 10 lbs back onto the front axle.&nbsp;]]>
   <pubDate>Fri, 26 Oct 2018 14:02:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116950#116950</guid>
   <title>Protect tailgate from jack : Almost everyone likes my ideas......</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116949#116949</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 26 Oct 2018 at 12:57pm<br /><br />Almost everyone likes my ideas... except Mrs Furpod.. she usually makes a funny face at them... <br><br>The difference in lever action caused by a couple inches of shank is almost not measurable, but IF it causes a problem, the setup was right on the edge anyways.. and that is never a good thing.. <br>]]>
   <pubDate>Fri, 26 Oct 2018 12:57:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116949#116949</guid>
   <title>Protect tailgate from jack : Thank you all for the good ideas....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116947#116947</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5896" rel="nofollow">dr2428</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 26 Oct 2018 at 11:43am<br /><br /><div>Thank you all for the good ideas. I favor Furpod's idea, I had thought to look for a longer shank but not sure if the increased length would affect how it tows, doubtful it would be significant. <br></div><div><br></div><div>I don't plan to get a WDH yet as we are going only 20 miles away, sure is nice not to have to mess with it. The new truck pulls the 179 nearly effortlessly but I will set up the WDH before any long trips, better safe than sorry. <br></div><div><br></div><div>For right now I'll make a pad from an old can koozie and some padding.</div><div><br></div><div>Thank you<br></div><div><br></div>]]>
   <pubDate>Fri, 26 Oct 2018 11:43:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116947#116947</guid>
   <title>Protect tailgate from jack : +1, we have plenty of room for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116902#116902</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 25 Oct 2018 at 12:19pm<br /><br />+1, we have &nbsp;plenty of room for the tail gate with the E2.]]>
   <pubDate>Thu, 25 Oct 2018 12:19:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116902#116902</guid>
   <title>Protect tailgate from jack : +1. We use an E2 WDH, and it extends...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116896#116896</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 25 Oct 2018 at 10:15am<br /><br />+1. We use an E2 WDH, and it extends the ball just enough to clear the tailgate.]]>
   <pubDate>Thu, 25 Oct 2018 10:15:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116896#116896</guid>
   <title>Protect tailgate from jack : Adding the WDH helped to lengthen...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116891#116891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8361" rel="nofollow">OldNeumanntapr</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 25 Oct 2018 at 9:27am<br /><br />Adding the WDH helped to lengthen the space, plus I glued a little piece of indoor / outdoor carpeting to the spot on my tailgate that hit the trailer tongue.]]>
   <pubDate>Thu, 25 Oct 2018 09:27:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116891#116891</guid>
   <title>Protect tailgate from jack : Get a longer shank for your ball...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116886#116886</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 25 Oct 2018 at 7:55am<br /><br />Get a longer shank for your ball or WDH, whichever you use. Most don't realize they come in lengths from 8" to about 17".. and rise/drop numbers in the same range or close to it..etrailer is one of many places you can research and order online..<br><div><br></div><div>https://www.etrailer.com/dept-pg-Accessories_and_Parts-sf-Weight_Distribution-pt-Shanks.aspx</div><div><br></div><div>https://www.etrailer.com/dept-pg-Ball_Mounts-sf-Fixed_Ball_Mount-hs-Fits_2_Inch_Hitch.aspx</div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 25 Oct 2018 07:55:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116886#116886</guid>
   <title>Protect tailgate from jack : Any great ideas for protecting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116884#116884</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5896" rel="nofollow">dr2428</a><br /><strong>Subject:</strong> 12345<br /><strong>Posted:</strong> 25 Oct 2018 at 5:58am<br /><br /><div>Any great ideas for protecting the tailgate from the RPod jack? I found the Jack-E-Up: https://www.amazon.com/Jack-E-Up-5048-Black-Universal/dp/B01EVTKAJG/ref=sr_1_1?ie=UTF8&amp;qid=1540465016&amp;sr=8-1&amp;keywords=Jack-E-Up&nbsp; <br></div><div>but seems like a high price to pay despite being convenient. For now I'll pack something firm and rubbery into an old can koozie and keep it handy. I'm too old to lift a full cooler over a closed tailgate.</div><div><br></div><div>Thank you<br></div>]]>
   <pubDate>Thu, 25 Oct 2018 05:58:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12345&amp;PID=116884#116884</guid>
