  <title>R-pod Owners Forum : Tow vehicle not charging</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Tow vehicle not charging</description>
  <pubDate>Fri, 23 Oct 2026 16:29:48 +0000</pubDate>
  <lastBuildDate>Mon, 22 Oct 2018 16:24:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12331</WebWizForums:feedURL>
   <title>Tow vehicle not charging : Wepod,  If I recall correctly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116795#116795</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 22 Oct 2018 at 4:24pm<br /><br />Wepod,<br /><br />If I recall correctly the in line 30A is internal, with the converter.]]>
   <pubDate>Mon, 22 Oct 2018 16:24:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116795#116795</guid>
   <title>Tow vehicle not charging : If your fuses are good are you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116783#116783</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 8:48pm<br /><br />If your fuses are good are you sure you're getting 12V to the trailer side of the 7 pin connector? The pins might not be making good contact. You might also check to be see if you have continuity between the +12V pin on the trailer connector and the + battery terminal.&nbsp; Ditto for the ground connection. That might start to help narrow things down.&nbsp;&nbsp;]]>
   <pubDate>Sun, 21 Oct 2018 20:48:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116783#116783</guid>
   <title>Tow vehicle not charging : Do you know where the 30 amp inline...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116778#116778</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6506" rel="nofollow">Wepod</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 6:56pm<br /><br />Do you know where the 30 amp inline might be I tried to trace the line back to the panel but I couldn't find one. checked the 40s and they are good]]>
   <pubDate>Sun, 21 Oct 2018 18:56:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116778#116778</guid>
   <title>Tow vehicle not charging : If I recall correctly, there is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116758#116758</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 4:05pm<br /><br />If I recall correctly, there is an in-line 30A also.]]>
   <pubDate>Sun, 21 Oct 2018 16:05:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116758#116758</guid>
   <title>Tow vehicle not charging : No problems with the shore power....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116755#116755</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6506" rel="nofollow">Wepod</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 3:26pm<br /><br />No problems with the shore power.  I will check the 40amps.]]>
   <pubDate>Sun, 21 Oct 2018 15:26:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116755#116755</guid>
   <title>Tow vehicle not charging : Does in charge with shore power?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116748#116748</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 11:25am<br /><br />Does in charge with shore power?]]>
   <pubDate>Sun, 21 Oct 2018 11:25:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116748#116748</guid>
   <title>Tow vehicle not charging : Check the two polarity fuses in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116745#116745</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 10:27am<br /><br />Check the two polarity fuses in the 12 distribution panel. &nbsp;There are 2 40 amp fuses that protect the 12v system from reversed polarity. &nbsp;But, if you blew either or both, you need to figure out how you reversed the polarity. &nbsp;<div><br></div>]]>
   <pubDate>Sun, 21 Oct 2018 10:27:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116745#116745</guid>
   <title>Tow vehicle not charging : Hi my 2017 179 is no longer charging...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116744#116744</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6506" rel="nofollow">Wepod</a><br /><strong>Subject:</strong> 12331<br /><strong>Posted:</strong> 21 Oct 2018 at 10:15am<br /><br />Hi my 2017 179 is no longer charging from my 2014 Ram when driving. It has been working fine up until now. I checked the plug on the truck and I am getting power there so there must be a problem with the pod.  Is there a fuse on the trailer line somewhere and where does the power line go in the trailer to connect up to the 12v sustem?<br />Cut]]>
   <pubDate>Sun, 21 Oct 2018 10:15:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12331&amp;PID=116744#116744</guid>
