  <title>R-pod Owners Forum : Pipe prep for cool, fall camping</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Pipe prep for cool, fall camping</description>
  <pubDate>Thu, 29 Oct 2026 21:12:27 +0000</pubDate>
  <lastBuildDate>Thu, 06 Sep 2018 15:43:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12153</WebWizForums:feedURL>
   <title>Pipe prep for cool, fall camping : If you are really concerned, just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114677#114677</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5298" rel="nofollow">riotkayak284</a><br /><strong>Subject:</strong> 12153<br /><strong>Posted:</strong> 06 Sep 2018 at 3:43pm<br /><br />If you are really concerned, just pull the plugs on the waterlines at night.]]>
   <pubDate>Thu, 06 Sep 2018 15:43:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114677#114677</guid>
   <title>Pipe prep for cool, fall camping :   Originally posted by Blender...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114626#114626</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2821" rel="nofollow">Happy Tripping</a><br /><strong>Subject:</strong> 12153<br /><strong>Posted:</strong> 04 Sep 2018 at 5:19pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Blender Bob</strong></em><br /><br />I am expecting a small chance of encountering freezing temps for a few hours before temps return to daytime highs in the 50s.&nbsp;</td></tr></table><div><br></div><div>This subject comes up every fall and spring.</div><div><br></div><div>The most important fact is that water EXPANDS about 9% when it freezes. Once it expands, that's it, it doesn't expand more. However, that expansion is not good for pipe connections.</div><div><br></div><div>It has been shown numerous times, and it happened ONCE with me, temps in the hi 20's overnight, if the daytime temps are above freezing, say in the 40s, do not cause noticeable damage to the r-pod's pipes. (Note I say 'noticeable'.) That expansion certainly did <i>something, </i>though.&nbsp;</div><div><br></div><div>Apparently, there are pipe connections deeper in the r-pod, where it takes a little longer for the water to freeze because of residual daytime heat, and there we find that frozen pipes DO cause damage.&nbsp;</div><div><br></div><div>Hello, that is why we winterize.</div><div><br></div><div>Being risk-averse, if I know the temperature will be below the hi 20's, I winterize. My r-pod may not freeze at mid-20's overnite, but I am not much of a gambler. That's just me.&nbsp;</div><div><br></div><div>Ala Clint Eastwood, "Are you feeling lucky?"</div>]]>
   <pubDate>Tue, 04 Sep 2018 17:19:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114626#114626</guid>
   <title>Pipe prep for cool, fall camping : I&amp;#039;m looking into putting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114623#114623</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 12153<br /><strong>Posted:</strong> 04 Sep 2018 at 4:31pm<br /><br />I'm looking into putting some pipe insulation - that black foam stuff - on the pipe between the fresh water tank and where it enters into the floor. &nbsp;It's exposed and doesn't have much volume. &nbsp;The tank should be ok b/c there's lots of expansion room if it gets a little icy. &nbsp;As for black and gray, same thing, lots of room for expansion and not a lot of tight spots. &nbsp;]]>
   <pubDate>Tue, 04 Sep 2018 16:31:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114623#114623</guid>
   <title>Pipe prep for cool, fall camping :  During the fall we frequently...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114619#114619</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 12153<br /><strong>Posted:</strong> 04 Sep 2018 at 3:26pm<br /><br />During the fall we frequently camp where night time outside temperatures drop to the mid 20's at night (sometimes lower) and we have never had any problems. It is important that the day time temperatures get up to the mid 40's.&nbsp;<div>&nbsp;</div>]]>
   <pubDate>Tue, 04 Sep 2018 15:26:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114619#114619</guid>
   <title>Pipe prep for cool, fall camping : Prepping for a fall trip into...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114618#114618</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8109" rel="nofollow">Blender Bob</a><br /><strong>Subject:</strong> 12153<br /><strong>Posted:</strong> 04 Sep 2018 at 3:22pm<br /><br /><div>Prepping for a fall trip into the Colorado mountains, I reflected back to my April trip to the Utah desert where we awoke to 23F and a nearly frozen water line. (after running the water for a few seconds, the sluggish, part frozen of the line came clear and the warmer water in the fresh tank prevailed. Temps then rose well above freezing in a short while.</div><div><br></div><div>As I prepare for this trip, just above 10,500’, I am expecting a small chance of encountering freezing temps for a few hours before temps return to daytime highs in the 50s. I expect with the hot water heater left on overnight, and the temp inside the Rpod 178 staying above 45F, inside plumbing should be safe, but the few exposed pipes under the cabin need to be addressed. <br>Pretty simple, I enclosed the feed hose from fresh water tank with ¾“ hot water rubber insulation tubing and duct tape. I covered the hose to the black water spray with same. Where piping was not easily covered, I put at least 1-2” of spray insulation and fill any gaps at the end of the insulation tubing. I also placed a bit of insulation behind the outdoor shower cover.</div><div><br></div><div>Anything else one should consider enduring 4-5 hours of mid to high 20Fs?</div><div><br></div><div>Also interesting, I thought I push some air into the black water spray inlet to push any water in the lines into the tank – being it seems to have its own, separate piping to the tank. To my surprise, when released the compressed air side from inlet, I got a good back splash of clear (thankfully) water. The tanks was empty, but still surprising. Does anyone know if there is a back-flow valve in place? How does one winterize that line? &nbsp;</div><div><br></div><div>Thanks! Bob&nbsp;<br></div>]]>
   <pubDate>Tue, 04 Sep 2018 15:22:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12153&amp;PID=114618#114618</guid>
