  <title>R-pod Owners Forum : using the rpod walls as an electrical chase</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : using the rpod walls as an electrical chase</description>
  <pubDate>Fri, 23 Oct 2026 12:00:41 +0000</pubDate>
  <lastBuildDate>Tue, 28 Aug 2018 10:03:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12119</WebWizForums:feedURL>
   <title>using the rpod walls as an electrical chase : that looks pretty useful... I&amp;#039;ll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114337#114337</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8177" rel="nofollow">banjoman15</a><br /><strong>Subject:</strong> 12119<br /><strong>Posted:</strong> 28 Aug 2018 at 10:03am<br /><br />that looks pretty useful... I'll check it out, thanks]]>
   <pubDate>Tue, 28 Aug 2018 10:03:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114337#114337</guid>
   <title>using the rpod walls as an electrical chase :  Originally posted by banjoman15dang.......</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114336#114336</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 12119<br /><strong>Posted:</strong> 28 Aug 2018 at 10:01am<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by banjoman15</strong></em><br /><br />dang.... that's bad news.... thanks. I guess I'll need to create my own conduit somehow.... it might look awful...</td></tr></table> <br /><br /><br />Think "Wiremold".  Available at Lowes, Home Depot, Amazon, etc.<br /><br /><a href="https://www.legrand.us/organize-cords.aspx" target="_blank">https://www.legrand.us/organize-cords.aspx</a><br /><br />]]>
   <pubDate>Tue, 28 Aug 2018 10:01:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114336#114336</guid>
   <title>using the rpod walls as an electrical chase : dang.... that&amp;#039;s bad news.......</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114334#114334</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8177" rel="nofollow">banjoman15</a><br /><strong>Subject:</strong> 12119<br /><strong>Posted:</strong> 28 Aug 2018 at 7:57am<br /><br />dang.... that's bad news.... thanks. I guess I'll need to create my own conduit somehow.... it might look awful...]]>
   <pubDate>Tue, 28 Aug 2018 07:57:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114334#114334</guid>
   <title>using the rpod walls as an electrical chase : The parts of the wall that don&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114288#114288</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12119<br /><strong>Posted:</strong> 27 Aug 2018 at 8:55am<br /><br />The parts of the wall that don't have 2x2 aluminum tube are filled with closed cell foam insulation. It would be very difficult to drop wire through. Even with a sturdy fish tape it would be a challenge.<br>]]>
   <pubDate>Mon, 27 Aug 2018 08:55:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114288#114288</guid>
   <title>using the rpod walls as an electrical chase :  Hello all !!!!I bought an inverter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114286#114286</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8177" rel="nofollow">banjoman15</a><br /><strong>Subject:</strong> 12119<br /><strong>Posted:</strong> 27 Aug 2018 at 8:53am<br /><br />Hello all !!!!<div>I bought an inverter for boondocking uses. I plan to install it at the dining table, on top of the tiny wood ledge there. Fits perfectly. Good location for coffee pot, laptops, etc.</div><div>I wonder if I can run the heavy cable down through that wood-paneled wall covering? I want to place the inverter and inline fuse breaker on the ledge, drill a hole for the cable, drop it down through the panelling, to a hole going outside to the battery.</div><div>That's the initial plan.... Am I wrong?</div><div><br></div><div>My question is really about the limitations and obstructions in that wall, that might prevent it from being used as a chase.</div><div><br></div><div>2000 w inverter, 40 amp fuse, heavy cables, rpod 171 2010</div>]]>
   <pubDate>Mon, 27 Aug 2018 08:53:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12119&amp;PID=114286#114286</guid>
