  <title>R-pod Owners Forum : Wish list for dry camping needs</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : Wish list for dry camping needs</description>
  <pubDate>Fri, 23 Oct 2026 05:33:35 +0000</pubDate>
  <lastBuildDate>Tue, 07 Aug 2018 12:35:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12013</WebWizForums:feedURL>
   <title>Wish list for dry camping needs : TravelingTunes.....Welcome! Mark...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12013&amp;PID=113261#113261</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6462" rel="nofollow">Subzilla</a><br /><strong>Subject:</strong> 12013<br /><strong>Posted:</strong> 07 Aug 2018 at 12:35pm<br /><br />TravelingTunes.....Welcome!&nbsp; Mark and Ellen here just over the county line from you south of Concord.&nbsp; Glad to have another Central Carolina person here on the forum!&nbsp;&nbsp;]]>
   <pubDate>Tue, 07 Aug 2018 12:35:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12013&amp;PID=113261#113261</guid>
   <title>Wish list for dry camping needs : I have 130w panel plugged in the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12013&amp;PID=113257#113257</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7667" rel="nofollow">Olddawgsrule</a><br /><strong>Subject:</strong> 12013<br /><strong>Posted:</strong> 07 Aug 2018 at 11:50am<br /><br />I have 130w panel plugged in the side of the camper (Solar on the side plug). I out my controller right the back of the panel. Had no issues on the 46 day run.<div><br></div><div>I also wanted more USB ports, so I made up a couple battery packs of 18650 Lithiums 3200mah x 8 each. That works very well. Re-charge from the truck or from the USB port in the Pod. Runs our USB fans and other items.</div><div><br></div><div>I did mount a 1200w inverter up front below the dinette seat. There's a set of auto-reset breakers under the Pod up front and taped into those. Now, I don't run anything big off it and it also worked very well.</div><div><br></div><div>I debated what you are about to do and found this solution works well for me.</div>]]>
   <pubDate>Tue, 07 Aug 2018 11:50:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12013&amp;PID=113257#113257</guid>
   <title>Wish list for dry camping needs :  Changes: move Zamp solar port...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12013&amp;PID=113252#113252</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8655" rel="nofollow">TravelingTunes</a><br /><strong>Subject:</strong> 12013<br /><strong>Posted:</strong> 07 Aug 2018 at 9:58am<br /><br />Changes: move Zamp solar port to the FRONT of the trailer near the battery. Solar controller should be near the battery and shorter cables can be used to improve efficiency of solar capture.<div><br></div><div>Add: several 12 volt sockets.....to run an inverter, 12 V fans, adds more USB options when dry camping</div><div><br></div><div><br></div>]]>
   <pubDate>Tue, 07 Aug 2018 09:58:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12013&amp;PID=113252#113252</guid>
