  <title>R-pod Owners Forum : Water Pump</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Water Pump</description>
  <pubDate>Fri, 23 Oct 2026 10:33:31 +0000</pubDate>
  <lastBuildDate>Tue, 07 Aug 2018 13:37:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=12008</WebWizForums:feedURL>
   <title>Water Pump : +1 with GlueGuy....last trip,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113264#113264</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6462" rel="nofollow">Subzilla</a><br /><strong>Subject:</strong> 12008<br /><strong>Posted:</strong> 07 Aug 2018 at 1:37pm<br /><br />+1 with GlueGuy....last trip, my water pump ran for a LONG time.&nbsp; I waited thinking it the WH was filling up.&nbsp; I finally shut it off, then restarted it.&nbsp; It ran for a few seconds than stopped.&nbsp; I assumed it was air in the line.....]]>
   <pubDate>Tue, 07 Aug 2018 13:37:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113264#113264</guid>
   <title>Water Pump : GreetingsHave you checked the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113233#113233</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8314" rel="nofollow">crankster78</a><br /><strong>Subject:</strong> 12008<br /><strong>Posted:</strong> 06 Aug 2018 at 7:24pm<br /><br /><div>Greetings</div><div>Have you checked the filter on the pump inlet?&nbsp; It sounds like the bowl may be cracked or it's not tight and leaking air.&nbsp; Most dealers have new filters in stock.&nbsp; Check it closely.</div><div><br></div><div>Crankster78</div>]]>
   <pubDate>Mon, 06 Aug 2018 19:24:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113233#113233</guid>
   <title>Water Pump : Well, something&amp;#039;s wrong.......</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113232#113232</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 12008<br /><strong>Posted:</strong> 06 Aug 2018 at 7:10pm<br /><br /><div>Well, something's wrong....&nbsp; I don't know how the pump can run if there's not a faucet open or a leak.&nbsp; But then I don't know why it would shut off.</div><div><br></div><div>Is the water heater full?&nbsp; Look under the trailer to see if there are any drips.&nbsp; Or the bathroom floor.&nbsp; Sometimes the rear of toilet will leak and drain into the shower.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Mon, 06 Aug 2018 19:10:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113232#113232</guid>
   <title>Water Pump :  It&amp;#039;s either a leak, or...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113231#113231</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 12008<br /><strong>Posted:</strong> 06 Aug 2018 at 7:10pm<br /><br /><div>It's either a leak, or your WH is empty. The air in the system (especially the WH) is compressible, so the pump might run for a long time trying to compress it.</div><div><br></div><div>Open up the tap in the kitchen to see if there's any air in the system. If it sputs and spurts a bit, then that is the issue.</div><div><br></div><div>If it doesn't, then you may have a leak, or possibly a faulty pump, or possibly a check valve leaking water back into the holding tank.<br></div>]]>
   <pubDate>Mon, 06 Aug 2018 19:10:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113231#113231</guid>
   <title>Water Pump : Having trouble getting our water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113220#113220</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5843" rel="nofollow">Gary and Maureen</a><br /><strong>Subject:</strong> 12008<br /><strong>Posted:</strong> 06 Aug 2018 at 2:01pm<br /><br />Having trouble getting our water pump to shut off. When I turn it on, it runs until I have the water running for a short time and then it will come on randomly and not shut off until I do the same - run some water. Any thoughts. Thanks Gary]]>
   <pubDate>Mon, 06 Aug 2018 14:01:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=12008&amp;PID=113220#113220</guid>
