  <title>R-pod Owners Forum : Glass Cover over Stove</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Glass Cover over Stove</description>
  <pubDate>Thu, 29 Oct 2026 22:46:24 +0000</pubDate>
  <lastBuildDate>Mon, 30 Jul 2018 08:28:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11956</WebWizForums:feedURL>
   <title>Glass Cover over Stove : I don&amp;#039;t use the stovetop...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112930#112930</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 11956<br /><strong>Posted:</strong> 30 Jul 2018 at 8:28am<br /><br />I don't use the stovetop very often, but I have had it fall once, onto the pan, which probably saved it from breaking. I didn't bother with a fix due to not using it since, but I think maybe I should take a look at this. On my glasstop I was having an issue with the two threaded connectors loosening. They would unscrew from the vibrations from towing. Twice I found the threaded section on the floor after towing the pod home. I put some of the blue (removable) loc-tite on it. Should eliminate another potential break situation before it happens.]]>
   <pubDate>Mon, 30 Jul 2018 08:28:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112930#112930</guid>
   <title>Glass Cover over Stove : Just a thought: maybe try to modify...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112929#112929</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6969" rel="nofollow">wthoms2000</a><br /><strong>Subject:</strong> 11956<br /><strong>Posted:</strong> 30 Jul 2018 at 1:36am<br /><br />Just a thought: maybe try to modify it so that it leans back further. Falling because you are using the steps is way too sensitive, especially when cooking.<br /><br />Good luck!]]>
   <pubDate>Mon, 30 Jul 2018 01:36:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112929#112929</guid>
   <title>Glass Cover over Stove : They started that feature just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112868#112868</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11956<br /><strong>Posted:</strong> 26 Jul 2018 at 2:17pm<br /><br />They started that feature just after we got our RP-179. We thought it was nice, but that it would tend to interfere with actually using the stove. My inclination would be to remove it. I think a better solution is a removable cover or cutting board.<br>]]>
   <pubDate>Thu, 26 Jul 2018 14:17:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112868#112868</guid>
   <title>Glass Cover over Stove : The glass cover over the stove...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112866#112866</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8502" rel="nofollow">BH&MH</a><br /><strong>Subject:</strong> 11956<br /><strong>Posted:</strong> 26 Jul 2018 at 1:13pm<br /><br />The glass cover over the stove in our 180 is nice when it's closed so that it can be used for extra countertop space. But when it's open so the stove can be used, it's easy to bump it and have it close accidentally. Once it fell onto a boiling pot of water and caused a mess. Has anyone come up with a way to keep the glass stove cover securely in the open position? Ours will even fall if we aren't careful stepping on the stairs at the door.]]>
   <pubDate>Thu, 26 Jul 2018 13:13:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11956&amp;PID=112866#112866</guid>
