  <title>R-pod Owners Forum : Generator/Surge Protector</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Generator/Surge Protector</description>
  <pubDate>Thu, 29 Oct 2026 20:16:28 +0000</pubDate>
  <lastBuildDate>Thu, 26 Jul 2018 10:32:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11945</WebWizForums:feedURL>
   <title>Generator/Surge Protector : Thank you all for info and thoughts!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112863#112863</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7251" rel="nofollow">Podizzi</a><br /><strong>Subject:</strong> 11945<br /><strong>Posted:</strong> 26 Jul 2018 at 10:32am<br /><br />Thank you all for info and thoughts!]]>
   <pubDate>Thu, 26 Jul 2018 10:32:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112863#112863</guid>
   <title>Generator/Surge Protector : +1 Bum, the invertor shuts itself...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112793#112793</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11945<br /><strong>Posted:</strong> 23 Jul 2018 at 3:49pm<br /><br />+1 Bum, the invertor shuts itself down, mine does, if it's overloaded, not like campground power that can spike.]]>
   <pubDate>Mon, 23 Jul 2018 15:49:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112793#112793</guid>
   <title>Generator/Surge Protector : Yes, if it&amp;#039;s being loaded...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112789#112789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 11945<br /><strong>Posted:</strong> 23 Jul 2018 at 3:30pm<br /><br />Yes, if it's being loaded down enough (e.g. the AC compressor kicking on and you're near capacity when it does). But an inverter won't spike nearly as badly as shore power when the voltage comes back up.]]>
   <pubDate>Mon, 23 Jul 2018 15:30:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112789#112789</guid>
   <title>Generator/Surge Protector : Is there a potential for &amp;#034;under&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112787#112787</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 11945<br /><strong>Posted:</strong> 23 Jul 2018 at 3:01pm<br /><br />Is there a potential for "under" volts??&nbsp;]]>
   <pubDate>Mon, 23 Jul 2018 15:01:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112787#112787</guid>
   <title>Generator/Surge Protector : I don&amp;#039;t really see a need....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112778#112778</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 11945<br /><strong>Posted:</strong> 23 Jul 2018 at 10:40am<br /><br />I don't really see a need. You're not getting voltage that has been stepped down from a higher voltage through a transformer like you have with shore power.]]>
   <pubDate>Mon, 23 Jul 2018 10:40:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112778#112778</guid>
   <title>Generator/Surge Protector : Is it recommended/suggested to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112776#112776</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7251" rel="nofollow">Podizzi</a><br /><strong>Subject:</strong> 11945<br /><strong>Posted:</strong> 23 Jul 2018 at 10:00am<br /><br />Is it recommended/suggested to use a surge protector when using a generator? &nbsp;I never have in past but for some reason this crossed my mind. &nbsp;Thanks!!!]]>
   <pubDate>Mon, 23 Jul 2018 10:00:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11945&amp;PID=112776#112776</guid>
