  <title>R-pod Owners Forum : Problem with AC Dometic thermostat R189</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Problem with AC Dometic thermostat R189</description>
  <pubDate>Fri, 23 Oct 2026 09:55:38 +0000</pubDate>
  <lastBuildDate>Tue, 03 Jul 2018 15:54:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11821</WebWizForums:feedURL>
   <title>Problem with AC Dometic thermostat R189 : SH beat me to the punch. As someone...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111765#111765</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 11821<br /><strong>Posted:</strong> 03 Jul 2018 at 3:54pm<br /><br />SH beat me to the punch. As someone who deals with Celcius on a fairly regular basis, that was my first thought as well.]]>
   <pubDate>Tue, 03 Jul 2018 15:54:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111765#111765</guid>
   <title>Problem with AC Dometic thermostat R189 : Glad it was something so simple.  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111760#111760</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 11821<br /><strong>Posted:</strong> 03 Jul 2018 at 2:34pm<br /><br />Glad it was something so simple.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley20.gif" border="0" alt="Thumbs Up" title="Thumbs Up" />]]>
   <pubDate>Tue, 03 Jul 2018 14:34:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111760#111760</guid>
   <title>Problem with AC Dometic thermostat R189 : Thanks Guys,&#240;&#376;&#8216;&#141;&#240;&#376;&#143;&#188; Before we...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111745#111745</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8456" rel="nofollow">Abercrombies</a><br /><strong>Subject:</strong> 11821<br /><strong>Posted:</strong> 03 Jul 2018 at 12:56pm<br /><br />Thanks Guys,👍🏼 Before we tried the reset, we checked to see if it would cool at less than 32© (which we learned is 89+degrees f Fahrenheit.  That was the issue, Thanks again for your help! ~Bruce & Linda <br />🎶there'll be cool air in our Pod tonight!"]]>
   <pubDate>Tue, 03 Jul 2018 12:56:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111745#111745</guid>
   <title>Problem with AC Dometic thermostat R189 : Sounds like you got it switched...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111728#111728</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 11821<br /><strong>Posted:</strong> 03 Jul 2018 at 9:08am<br /><br />Sounds like you got it switched to Celcius. Hold the up and down buttons to switch it back to Farenheidt.]]>
   <pubDate>Tue, 03 Jul 2018 09:08:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111728#111728</guid>
   <title>Problem with AC Dometic thermostat R189 : have you tried to disconnect the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111727#111727</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3036" rel="nofollow">texman</a><br /><strong>Subject:</strong> 11821<br /><strong>Posted:</strong> 03 Jul 2018 at 9:03am<br /><br />have you tried to disconnect the shore power and the battery and let it all reset?&nbsp;]]>
   <pubDate>Tue, 03 Jul 2018 09:03:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111727#111727</guid>
   <title>Problem with AC Dometic thermostat R189 : Hello all, we are camping up in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111726#111726</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8456" rel="nofollow">Abercrombies</a><br /><strong>Subject:</strong> 11821<br /><strong>Posted:</strong> 03 Jul 2018 at 8:26am<br /><br />Hello all, we are camping up in "hot" Kentucky and our Dometic™ AC thermostat just malfunctioned? It was working fine, then when I attempted to raise the temperature for when it would come on it shut Off. Now it will only adjust for cooling at 32 degrees or less?<br />We've tried leaving it Off for a while.  Any ideas on how to correct this issue? (Tuesday, July 03,9:22am) ~Thanks, Bruce & Linda Abercrombie  <img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" align="middle" /> ]]>
   <pubDate>Tue, 03 Jul 2018 08:26:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11821&amp;PID=111726#111726</guid>
