  <title>R-pod Owners Forum : Which way to go..</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : Which way to go..</description>
  <pubDate>Sat, 24 Oct 2026 05:42:46 +0000</pubDate>
  <lastBuildDate>Fri, 08 Jun 2018 14:07:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11693</WebWizForums:feedURL>
   <title>Which way to go.. : Thanks bp and Sean. Your info...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110396#110396</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8031" rel="nofollow">lgblau</a><br /><strong>Subject:</strong> 11693<br /><strong>Posted:</strong> 08 Jun 2018 at 2:07pm<br /><br />Thanks bp and Sean. Your info is appreciated, and helpful.]]>
   <pubDate>Fri, 08 Jun 2018 14:07:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110396#110396</guid>
   <title>Which way to go.. : With I84 you avoid two very large...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110391#110391</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7950" rel="nofollow">disputin</a><br /><strong>Subject:</strong> 11693<br /><strong>Posted:</strong> 08 Jun 2018 at 11:59am<br /><br />With I84 you avoid two very large passes.&nbsp; On I82 there is Umtanum pass between Yakima and Ellensburg and on I90 you have to go over Snoqualmie.&nbsp; The posted freeway speeds going over Snoqualmie always gives me the willies even in a small car.&nbsp; There is also the optional Tiger Pass to bypass Seattle traffic, but it is 2 lanes for a lot of the way and always seems to have traffic on it.<div><br><div>I-84 follows the Columbia River and is as very flat in comparison, and I5 from Portland to the Gig Harbor exit is also flat.&nbsp; You also get to travel through the town of Hood River.&nbsp; Note: Why isn't there a Rpod Rally in Hood River, it seems the obvious choice...</div><div><br>While the Washington side of the Columbia Gorge (SR-14), is two-lanes, parallels I84, and a bit more hilly, I would recommend it as it's a beautiful drive and you can see the ("where in the Sam Hill") Mary Hill Museum and the Stonehenge as well.</div><div><br></div><div>Sean</div></div>]]>
   <pubDate>Fri, 08 Jun 2018 11:59:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110391#110391</guid>
   <title>Which way to go.. : Via I84 is marginally longer,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110385#110385</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11693<br /><strong>Posted:</strong> 08 Jun 2018 at 10:24am<br /><br />Via I84 is marginally longer, but probably lower elevation and fewer curves. I would have a slight preference for that route, but could be swayed by someone who knows both ways better than I.]]>
   <pubDate>Fri, 08 Jun 2018 10:24:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110385#110385</guid>
   <title>Which way to go.. : Good Morning....Brain picking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110383#110383</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8031" rel="nofollow">lgblau</a><br /><strong>Subject:</strong> 11693<br /><strong>Posted:</strong> 08 Jun 2018 at 9:18am<br /><br />Good Morning....Brain picking time. If you were pulling your R-Pod from Boise, ID to Gig Harbor, WA, would you go I-84 to Portland, or I-82/I-90 to Seatle area. The least long climbs the better. I’m running out time to make a choice. Thanks.&nbsp;]]>
   <pubDate>Fri, 08 Jun 2018 09:18:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11693&amp;PID=110383#110383</guid>
