  <title>R-pod Owners Forum : Vertical seams showing</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Vertical seams showing</description>
  <pubDate>Fri, 23 Oct 2026 08:55:18 +0000</pubDate>
  <lastBuildDate>Mon, 04 Jun 2018 19:53:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11668</WebWizForums:feedURL>
   <title>Vertical seams showing : +1, Agree. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110231#110231</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 7:53pm<br /><br />+1, Agree.]]>
   <pubDate>Mon, 04 Jun 2018 19:53:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110231#110231</guid>
   <title>Vertical seams showing : We see seams when there is a big...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110227#110227</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 7:39pm<br /><br />We see seams when there is a big temperature change and there is high humidity. Not seams actually, but you can "see" where the aluminum studs are.&nbsp; I'm presuming this is on the outside, and not the inside? A little clarification would be helpful.]]>
   <pubDate>Mon, 04 Jun 2018 19:39:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110227#110227</guid>
   <title>Vertical seams showing : My seams always showed a bit of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110225#110225</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1045" rel="nofollow">marwayne</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 7:14pm<br /><br />My seams always showed a bit of a bump, nothing separated. &nbsp;&nbsp;]]>
   <pubDate>Mon, 04 Jun 2018 19:14:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110225#110225</guid>
   <title>Vertical seams showing : Thanks, I have to admit I&amp;#039;m...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110224#110224</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 7:10pm<br /><br />Thanks, I have to admit I'm not sure what that is.  But if you say so, I'm following.]]>
   <pubDate>Mon, 04 Jun 2018 19:10:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110224#110224</guid>
   <title>Vertical seams showing : Unless it is severe it is not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110222#110222</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 6:27pm<br /><br />Unless it is severe it is not abnormal at all.&nbsp; It's called seam print.&nbsp; Cosmetic is all.&nbsp; I've only seen 1 or 2 R-Pods ever with it so bad that it was warranty viable.]]>
   <pubDate>Mon, 04 Jun 2018 18:27:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110222#110222</guid>
   <title>Vertical seams showing : I doubt normal, would really help...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110205#110205</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 3:06pm<br /><br />I doubt normal, would really help with a pic.  Where are they separating?]]>
   <pubDate>Mon, 04 Jun 2018 15:06:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110205#110205</guid>
   <title>Vertical seams showing : 2015 Rpod 179. Nearly all the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110193#110193</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4021" rel="nofollow">Sdak15</a><br /><strong>Subject:</strong> 11668<br /><strong>Posted:</strong> 04 Jun 2018 at 11:04am<br /><br />2015 Rpod 179. &nbsp;Nearly all the vertical seams are showing on the camper. I don't remember them being that noticeable before this year. &nbsp;I tried taking pictures but, can't get good ones.<div>We have not used the RPod for quite some time so I just don't remember. &nbsp;</div><div><br></div><div><br></div><div>Is it normal for them to show? Thanks...</div><div><br></div>]]>
   <pubDate>Mon, 04 Jun 2018 11:04:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11668&amp;PID=110193#110193</guid>
