  <title>R-pod Owners Forum : Toyota pickup V6 vs V8</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Toyota pickup V6 vs V8</description>
  <pubDate>Thu, 29 Oct 2026 20:23:09 +0000</pubDate>
  <lastBuildDate>Mon, 04 Jun 2018 14:58:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11659</WebWizForums:feedURL>
   <title>Toyota pickup V6 vs V8 : I think we need to stick to motors...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110203#110203</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 04 Jun 2018 at 2:58pm<br /><br />I think we need to stick to motors available from dealers and manufacturers.  I can turbo/super my 5.3 Chevy and get 700 HP, so when I not towing I could be running 1/8 miles at the local strip, what's that prove.  The 3.5 Ford is impressive, to me - more impressive than the 5.0 Ford.  I am a Chevy guy:)]]>
   <pubDate>Mon, 04 Jun 2018 14:58:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110203#110203</guid>
   <title>Toyota pickup V6 vs V8 :   Originally posted by furpodLOL.....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110201#110201</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 04 Jun 2018 at 2:44pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by furpod</strong></em><br /><br />LOL.. I ain't no chevy fan boi.. but I promise you, drop a twin turbo on the 5.3, and the adage remains the same. Rebuild that 5.3 with boost in the plan, (as the ecoboost engines are) and that 3.5 is nothing but a spec in the mirror.</td></tr></table>As long as the engine is built for the loads the boost will impart. The EcoBoost engines all have 6-bolt main bearings (four in tension, and two in shear). The high torque will impose a big load on the crank and main journals pretty much like a diesel engine. If the 5.3 has the more typical 2-bolt main bearings, then adding a turbo might just be too much for it.<br>]]>
   <pubDate>Mon, 04 Jun 2018 14:44:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110201#110201</guid>
   <title>Toyota pickup V6 vs V8 : I tow my 2010 171 with a 2013...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110199#110199</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7929" rel="nofollow">DenisP</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 04 Jun 2018 at 2:15pm<br /><br />I tow my 2010 171 with a 2013 Tundra 5.7 L which has no issue except it is thirsty (11.5mpg).&nbsp; The 5.7 L has 381 hp and just over 400 ftlb of torque.&nbsp; It gets it done.]]>
   <pubDate>Mon, 04 Jun 2018 14:15:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110199#110199</guid>
   <title>Toyota pickup V6 vs V8 :    Originally posted by GlueGuy  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110181#110181</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 04 Jun 2018 at 7:21am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by GlueGuy</strong></em><br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by CharlieM</strong></em><br /><br /><font size="3">Big difference in favor or the V8. "There's no substitute for cubes."</font></td></tr></table>The Ford 3.5L V6 EcoBoost will out-tow that Tundra with its eyes closed. It puts out over 400 ft-lbs at only 1800 RPM, and continues with an almost flat torque curve all the way to redline. It will also out-tow Ford's own 5.0L V8.<br></div><div><br></div><div>Turbochargers have been the replacement for displacement for over 20 years.<br></div><div></td></tr></table> <br></div><div><br></div><div>LOL.. I ain't no chevy fan boi.. but I promise you, drop a twin turbo on the 5.3, and the adage remains the same. Rebuild that 5.3 with boost in the plan, (as the ecoboost engines are) and that 3.5 is nothing but a spec in the mirror. <br><br></div><div>More displacement is always the answer for maximum power. Yes you can spin, stuff, build with unobtanium, and electronically control the living crap out of small engines and make some truly remarkable numbers. But starting with a bigger engine, means bigger numbers on the back end.. just plain old physics. <br></div><div><br></div><div>In the case of this discussion it revolves around how much power do you need to get the job done, and how thick is your wallet. <br><br></div>]]>
   <pubDate>Mon, 04 Jun 2018 07:21:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110181#110181</guid>
   <title>Toyota pickup V6 vs V8 :   Originally posted by pnwcamperGlueguy,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110164#110164</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 8:34pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by pnwcamper</strong></em><br /><br /><div>Glueguy, do you know when Ford started offering the Ecoboost? What year?<br></div><div><br></div><div>Thanks</td></tr></table>The original V6 EcoBoost was introduced in 2009. There are now several models; at least a couple of 4-cylinder and at least a couple of 6-cylinder.</div><div><br></div><div>These are not like the turbocharged engines from back in the 80s or 90s. There used to be issues with cool-down, and other things. The Ford V6 EcoBoost engines utilize two separate turbochargers; one for each 3-cylinder bank. That allows them to make them smaller. The advantages are that they spin up faster, and eliminate most of the lag that had been associated with early turbocharged engines. They do really spin though. I've read that the turbos in the 3.5L EcoBoost spin at something like 170,000 RPM.</div><div><br></div><div>The 3.5L EcoBoost is now on the 2nd or 3rd generation, depending on how you count generations. The 2.7L EcoBoost (no slouch at all) is essentially a 2nd generation version.<br></div>]]>
   <pubDate>Sun, 03 Jun 2018 20:34:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110164#110164</guid>
   <title>Toyota pickup V6 vs V8 :   Originally posted by pnwcamperCharlieM,Is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110158#110158</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 7:08pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by pnwcamper</strong></em><br /><br /><div>CharlieM,</div><div><br></div><div>Is your supercharged Tacoma aftermarket or factory installed? If aftermarket how much does it cost parts and labor for a mechanic to install? I assume gas millage compromised?</div><div><br></div><div>Any other pluses or minuses to the supercharge?</div><div><br></div><div>Thanks<br></div><div></td></tr></table> <br></div><div><font size="3">The short answer to all the above is yes. The SC was manufactured and offered by Toyota Racing Development (TRD). For some strange legal/marketing reason the Toyota dealers could not include it with the vehicle purchase but they could sell it afterwards, install it, and guarantee it as if it were part of the original factory 36 mo. warranty. Go figure. I actually bought the SC from a third party Toyota parts dealer (cheaper) and had the dealership shop install it. It was then fully covered by the Toyota warranty. The total cost was around $7000; well worth it to me for high altitude mountain towing. It's my answer to the V8, which Toyota would not put in the mid sized Tacoma. <br></font></div><div><font size="3"><br></font></div><div><font size="3">The advantages are obvious: much better performance. On one trip I was able to maintain 60 MPH towing my LivinLite 21RBS (3500# empty plus full load) climbing a 9% grade in the Sierras. That plus everything I threw at it in the Rockies confirms my initial decision. <br></font></div><div><font size="3"><br></font></div><div><font size="3">Disadvantages are few but it does make a whine that takes some getting used to. I also have to burn premium gas but I always did anyway when towing. So I have to fill up with premium for around town driving but that's not a problem. The Tacoma was bought specifically to tow the camper and sits in the driveway most other times. <br></font></div><div><font size="3"><br></font></div><div><font size="3">As for gas mileage it's the same as any other power upgrade. If you use it you'll pay for it. Keep your foot off and it's no worse than an NA V6. Same would go for a V8 vs V6.</font></div><div><font size="3"><br></font></div><div><font size="3">Toyota stopped offering the SC beginning in 2104. Maybe problems meeting Federal fuel and pollution standards. They also "upgraded" the V6 by increasing the rated RPM. I hate the scream of a 6000 RPM engine. That seems to be today's norm which can only lead to decreased engine life. The old Chevy 350 CID engine is sorely missed <img src="https://www.rpod-owners.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" />.</font><br></div>]]>
   <pubDate>Sun, 03 Jun 2018 19:08:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110158#110158</guid>
   <title>Toyota pickup V6 vs V8 : Glueguy, do you know when Ford...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110154#110154</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4646" rel="nofollow">pnwcamper</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 6:07pm<br /><br /><div>Glueguy, do you know when Ford started offering the Ecoboost? What year?<br></div><div><br></div><div>Thanks<br></div>]]>
   <pubDate>Sun, 03 Jun 2018 18:07:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110154#110154</guid>
   <title>Toyota pickup V6 vs V8 : All true, if you compare engines,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110153#110153</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2715" rel="nofollow">ToolmanJohn</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 6:05pm<br /><br />All true, if you compare engines, you have to categorize whether it's normally aspirated (no turbo or supercharger) or if it is force fed (turbo charger or supercharger).&nbsp;<div><br></div><div>The newer V6 turbocharged engines are very impressive.&nbsp; They operate better at higher elevation and take a much smaller hit on power because of altitude like a non-turbo engine. I'm watching, and when I'm ready for a new vehicle, maybe that's the ticket. They sure do COST a lot more though.<div><br></div><div>I might even give a hard look a the new Dodge Durango V8, good tow specs and a powerful V8 and about 20mpg. Still, they cost near $50K new.&nbsp;</div><div><br></div><div>&nbsp;For the R-pod's any engine putting out near or over 300ft-lbs will be a very good tow experience power wise.&nbsp;</div></div><div><br></div><div>Of course if someone only tows close to home within a 100 miles or so and doesn't do long distance towing or hitting the hills with great frequency, all that power is not really a priority. This subject is so very subjective. It really depends on what someone really needs, think they need, and can live with.</div>]]>
   <pubDate>Sun, 03 Jun 2018 18:05:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110153#110153</guid>
   <title>Toyota pickup V6 vs V8 : CharlieM,Is your supercharged...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110152#110152</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4646" rel="nofollow">pnwcamper</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 6:05pm<br /><br /><div>CharlieM,</div><div><br></div><div>Is your supercharged Tacoma aftermarket or factory installed? If aftermarket how much does it cost parts and labor for a mechanic to install? I assume gas millage compromised?</div><div><br></div><div>Any other pluses or minuses to the supercharge?</div><div><br></div><div>Thanks<br></div>]]>
   <pubDate>Sun, 03 Jun 2018 18:05:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110152#110152</guid>
   <title>Toyota pickup V6 vs V8 :  You have to compare apples to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110150#110150</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 5:21pm<br /><br /><font size="3">You have to compare apples to apples, not to pineapples. SC and TC engines are different than NA engines. That said, I have a supercharger (not TC) on my 4.0L V6 Tacoma. Primarily for higher altitudes where the SC engines doesn't fall off as fast as the NA version. However the OP didn't say anything about an SC and they were not common on Tacomas.</font>]]>
   <pubDate>Sun, 03 Jun 2018 17:21:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110150#110150</guid>
   <title>Toyota pickup V6 vs V8 :   Originally posted by CharlieMBig...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110148#110148</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 5:06pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by CharlieM</strong></em><br /><br /><font size="3">Big difference in favor or the V8. "There's no substitute for cubes."</font></td></tr></table>The Ford 3.5L V6 EcoBoost will out-tow that Tundra with its eyes closed. It puts out over 400 ft-lbs at only 1800 RPM, and continues with an almost flat torque curve all the way to redline. It will also out-tow Ford's own 5.0L V8.<br></div><div><br></div><div>Turbochargers have been the replacement for displacement for over 20 years.<br></div>]]>
   <pubDate>Sun, 03 Jun 2018 17:06:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110148#110148</guid>
   <title>Toyota pickup V6 vs V8 : I don&amp;#039;t know CharlieM.  My...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110145#110145</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 4:00pm<br /><br />I don't know CharlieM.<br /><br />My 5.3 Vortec Chevy V8 has a torque range from 325-335 depending upon generation.  The Ford 3.5 Dual Turbo, 6 cyl - 420-450 torque.  Across the board 100 lbs more torque.]]>
   <pubDate>Sun, 03 Jun 2018 16:00:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110145#110145</guid>
   <title>Toyota pickup V6 vs V8 : Thanks guys, appreciate the input.  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110143#110143</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4646" rel="nofollow">pnwcamper</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 3:47pm<br /><br />Thanks guys, appreciate the input.]]>
   <pubDate>Sun, 03 Jun 2018 15:47:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110143#110143</guid>
   <title>Toyota pickup V6 vs V8 : Big difference in favor or the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110142#110142</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 3:41pm<br /><br /><font size="3">Big difference in favor or the V8. "There's no substitute for cubes."</font>]]>
   <pubDate>Sun, 03 Jun 2018 15:41:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110142#110142</guid>
   <title>Toyota pickup V6 vs V8 : It won&amp;#039;t be about horsepower,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110141#110141</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2715" rel="nofollow">ToolmanJohn</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 3:31pm<br /><br />&nbsp;It won't be about horsepower, it will be about torque. Buy torque for towing. Pretty much anything with over 300 HP will also have plenty of torque too.<div><br></div><div>The V8 makes more torque. Looks like 315 ft-lbs. Pretty good.</div><div>The V6 makes 266 ft-lbs. That's fair, I remember my towing experience with my 2003 4Runner 4.0L v6. Highway speeds were high rpm, I'm sure the engine was fine Toyota's have really bulletproof powertrains, but climbs were slower.</div><div><br></div><div><br></div>]]>
   <pubDate>Sun, 03 Jun 2018 15:31:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110141#110141</guid>
   <title>Toyota pickup V6 vs V8 : TorqueV6 - 266 ft-lbs. @ 4000...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110140#110140</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4646" rel="nofollow">pnwcamper</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 3:24pm<br /><br /><div>Torque<br></div><div><br></div><div>V6 - 266 ft-lbs. @ 4000 rpm</div><div><br></div><div>V8 - 315 @ 3400 RPM</div>]]>
   <pubDate>Sun, 03 Jun 2018 15:24:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110140#110140</guid>
   <title>Toyota pickup V6 vs V8 : what are the torque numbers?  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110134#110134</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 1:39pm<br /><br />what are the torque numbers?]]>
   <pubDate>Sun, 03 Jun 2018 13:39:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110134#110134</guid>
   <title>Toyota pickup V6 vs V8 : Hello fellow r-podders,I currently...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110133#110133</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4646" rel="nofollow">pnwcamper</a><br /><strong>Subject:</strong> 11659<br /><strong>Posted:</strong> 03 Jun 2018 at 1:23pm<br /><br /><div>Hello fellow r-podders,</div><div><br></div><div>I currently own a 2009 Toyota Tacoma 4x4 4.0 V6 and a 177, which I have had for a couple years. I'm out camping 6-10 times a year so have plenty of experience towing with this combo. As many have noted it's a pretty good combo but does have it's limitation when towing in the mountains. The V6 struggles in the hills.</div><div><br></div><div>I'm considering purchasing a 2000-2003 Tundra V8. The horsepower specs are listed below. My questions for those that may have experience is: will I really feel much difference with only 9 horsepower difference? Are the newer V6's almost as powerful as the older V8's?<br></div><div><br></div><div>2009 Tacoma: 236 hp @ 5200 rpm</div><div><br></div><div>2000 Tundra: 245 hp @ 4800 rpm</div><div><br></div><div>Thanks</div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Sun, 03 Jun 2018 13:23:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11659&amp;PID=110133#110133</guid>
