  <title>R-pod Owners Forum : Keys</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Keys</description>
  <pubDate>Thu, 29 Oct 2026 21:53:38 +0000</pubDate>
  <lastBuildDate>Fri, 25 May 2018 11:35:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11617</WebWizForums:feedURL>
   <title>Keys : Thank you all so much for all...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109745#109745</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8367" rel="nofollow">HockeyDave</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 25 May 2018 at 11:35am<br /><br />Thank you all so much for all the help!!&nbsp; I very much appreciate it!!&nbsp; Yes, unfortunately, I was foolish enough to lose both sets!]]>
   <pubDate>Fri, 25 May 2018 11:35:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109745#109745</guid>
   <title>Keys : did you lose both sets? mine came...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109733#109733</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3036" rel="nofollow">texman</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 25 May 2018 at 8:15am<br /><br />did you lose both sets?&nbsp; mine came with two full sets.&nbsp;]]>
   <pubDate>Fri, 25 May 2018 08:15:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109733#109733</guid>
   <title>Keys : one more to look at. GlueGuy put...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109719#109719</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 24 May 2018 at 6:43pm<br /><br /><div>one more to look at.&nbsp; GlueGuy put me on these locks.&nbsp; Your's may have a different number.</div><div>http://www.rpod-owners.com/forum_posts.asp?TID=11445&amp;KW=key&amp;PID=107858&amp;title=outside-storage-door-lock-question#107858<br></div>]]>
   <pubDate>Thu, 24 May 2018 18:43:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109719#109719</guid>
   <title>Keys : Found the threadhttp://www.rpo...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109718#109718</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 24 May 2018 at 6:33pm<br /><br /><div>Found the thread</div><div>http://www.rpod-owners.com/forum_posts.asp?TID=11321&amp;PID=106504#106504<br></div>]]>
   <pubDate>Thu, 24 May 2018 18:33:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109718#109718</guid>
   <title>Keys : this is mine a G331, for 2017...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109717#109717</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 24 May 2018 at 6:21pm<br /><br /><div>this is mine&nbsp;&nbsp; a G331, for 2017 rp172</div><div>https://www.etrailer.com/s.aspx?qry=rv+lock+331</div><div>I switched out all the locks to it like the post said.<br></div><div>afraid you might have to go with a locksmith, and have key made. <br></div><div><br></div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 24 May 2018 18:21:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109717#109717</guid>
   <title>Keys : I saw on this forum somewhere...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109716#109716</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7163" rel="nofollow">Kup-Pod</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 24 May 2018 at 6:14pm<br /><br />I saw on this forum somewhere (I realize that the lack of specifics is not very helpful :-)) that someone switched to a digital keypad lock set.&nbsp; It fit right in where the key one is.&nbsp; Maybe now is the opportunity for that kind of mod.<div>The only problem you'll have is remembering the code... which can be a challenge for me!</div>]]>
   <pubDate>Thu, 24 May 2018 18:14:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109716#109716</guid>
   <title>Keys : Hey Dave, the number matters....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109715#109715</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 24 May 2018 at 5:39pm<br /><br />Hey Dave, the number matters.  Your storage areas have a standard RV key CH751, pretty much an RV standard,  Your door lock and key is a Baur.  My key is marked 305, not sure other members have same key.  You can try dealer, simple call.  A locksmith can help but most need a key to replicate.  I looked on Baur website and they can provide a replacement key, but they want to know number on present key.  I did not see a number on the Baur lock.  I have not looked inside.  Best I can do for now.]]>
   <pubDate>Thu, 24 May 2018 17:39:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109715#109715</guid>
   <title>Keys : I foolishly lost the keys to my...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109714#109714</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8367" rel="nofollow">HockeyDave</a><br /><strong>Subject:</strong> 11617<br /><strong>Posted:</strong> 24 May 2018 at 5:14pm<br /><br /><div><font size="3"><font face="Arial, Helvetica, sans-serif">I foolishly lost the keys to my 2015 RPod 179.&nbsp; What is the best way to replace the keys?&nbsp; Through the dealer?&nbsp; On-line?&nbsp; Locksmith?&nbsp; <br></font></font></div><div><font size="3"><font face="Arial, Helvetica, sans-serif">If online, what site would you suggest?&nbsp; And what brand of key does the RPod take?</font></font></div><div><font size="3"><font face="Arial, Helvetica, sans-serif">As you can tell, I am very new to this and need a fair amount of guidance!</font></font></div><div><font size="3"><font face="Arial, Helvetica, sans-serif">Any help would be greatly appreciated!</font></font></div><div><font size="3"><font face="Arial, Helvetica, sans-serif"><br></font></font></div><div><font size="3"><font face="Arial, Helvetica, sans-serif">Dave<br></font></font></div>]]>
   <pubDate>Thu, 24 May 2018 17:14:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11617&amp;PID=109714#109714</guid>
