  <title>R-pod Owners Forum : 176 t</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : 176 t</description>
  <pubDate>Thu, 24 Sep 2026 01:28:53 +0000</pubDate>
  <lastBuildDate>Mon, 09 Sep 2013 17:31:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=1160</WebWizForums:feedURL>
   <title>176 t : Sorry no pics, but here&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=37899#37899</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2065" rel="nofollow">phil & sue & daisy</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 09 Sep 2013 at 5:31pm<br /><br />Sorry no pics, but here's what I did. &nbsp;Got a piece 1/2 in. cpvc rigid water supply line (Menards) and cut it to the length of the fully extended lid support shaft. Cut a lengthwise groove just wide enough to fit over the shaft and slip it on. The weight of the lid will hold it in place. In bad rain I also have a plastic tarp I hook to the inside of the lid locks that hangs over the back of the tent that I anchor to the stabilizers with bungees. So far so good. &nbsp; Phil]]>
   <pubDate>Mon, 09 Sep 2013 17:31:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=37899#37899</guid>
   <title>176 t : Can you post some pics?  We also...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=37556#37556</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1430" rel="nofollow">ToddLat</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 02 Sep 2013 at 4:50pm<br /><br />Can you post some pics?  We also have had a bit of water in our tent end after huge storms. Would like to see your solution.]]>
   <pubDate>Mon, 02 Sep 2013 16:50:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=37556#37556</guid>
   <title>176 t : Only used our 176t 3 weekends...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=36951#36951</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2065" rel="nofollow">phil & sue & daisy</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 19 Aug 2013 at 12:24pm<br /><br />Only used our 176t 3 weekends so far and had a great time, BUT, during the 18 hr. driving rain storm found the tent to get a little wet inside. a few rain drops in the face woke me up. I suppose anormal rain might not pose this problem, but I did make a tarp to hang from the lid for added protection. Also found the lid to have lowered itself and was rubbing on the tent and probably wore off some rain protection, so I made some supports that fit over the lid supports to prevent it from dropping down.]]>
   <pubDate>Mon, 19 Aug 2013 12:24:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=36951#36951</guid>
   <title>176 t : yes. we&amp;#039;d love to see your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9953#9953</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=459" rel="nofollow">motx72</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 27 Mar 2010 at 9:57pm<br /><br />yes.&nbsp; we'd love to see your pics too.&nbsp; we're leaning towards the 176t ourselves.<br><br>]]>
   <pubDate>Sat, 27 Mar 2010 21:57:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9953#9953</guid>
   <title>176 t : Do you have any pics of the 176t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9952#9952</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=506" rel="nofollow">kotasnana</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 27 Mar 2010 at 8:52pm<br /><br />Do you have any pics of the 176t set up yet?]]>
   <pubDate>Sat, 27 Mar 2010 20:52:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9952#9952</guid>
   <title>176 t : hi      just seemed to lack any...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9934#9934</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=501" rel="nofollow">kiss</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 24 Mar 2010 at 10:19pm<br /><br />&nbsp;hi<br>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; just seemed to lack any kind of quality control ,on the finish. thought i was buying the best.<br>turned into a very expensive mistake. the older one's seemed fine. mine was a 2008. think if you get one with all the bugs out ,from the 80's/90's you might be ok. great history,good design,nice dealer + no quality in finish.<img src="https://www.rpod-owners.com/smileys/smiley18.gif" border="0" alt="Ouch" title="Ouch" />]]>
   <pubDate>Wed, 24 Mar 2010 22:19:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9934#9934</guid>
   <title>176 t : Welcome, let us know about your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9927#9927</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 24 Mar 2010 at 7:53am<br /><br />Welcome, let us know about your first camping trip.]]>
   <pubDate>Wed, 24 Mar 2010 07:53:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9927#9927</guid>
   <title>176 t : A 27 foot Airstream in an Ocean...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9920#9920</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=204" rel="nofollow">Tusten Traveler</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 23 Mar 2010 at 12:11pm<br /><br />A 27 foot Airstream in an Ocean Breeze decor is my DREAM TT! What about it didn't you like?<DIV>&nbsp;</DIV><DIV>Oh yes- and welcome to the forum!</DIV>]]>
   <pubDate>Tue, 23 Mar 2010 12:11:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9920#9920</guid>
   <title>176 t : Welcome to the group!Terry  </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9917#9917</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 23 Mar 2010 at 4:38am<br /><br />Welcome to the group!<br><br>Terry<br>]]>
   <pubDate>Tue, 23 Mar 2010 04:38:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9917#9917</guid>
   <title>176 t : just bought a 176 t.towed it from...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9915#9915</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=501" rel="nofollow">kiss</a><br /><strong>Subject:</strong> 1160<br /><strong>Posted:</strong> 22 Mar 2010 at 5:59pm<br /><br />just bought a 176 t.<br>towed it from ohio to new mexico.<br>sold a 27' airstream.<br>to early to tell yet ,but seems like an improvement.<br>]]>
   <pubDate>Mon, 22 Mar 2010 17:59:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1160&amp;PID=9915#9915</guid>
